AutoCAD 2017-Script Error-License-object expected
after i entered the serial number and product key i got this error
TravisNave
What version of IE are you using?
Also, try this: Disconnect from the Internet. Then launch the software
from the acad.exe within the actual program directory and not the Desktop
shortcut. Connect back to the Internet once you attempt to activate.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
IE version 11
i did your steps and the result was like the pictures shown Capture.PNGCapture1.PNGCapture2.PNGCapture3.PNGCapture4.PNG
Mark.Lancaster
@Anonymous
I was just about to tell you not to share serial #s here and then I realize that serial # is associated to "cracking" the code.  Are you doing something illegal here with your Autodesk software?    Hey @TravisNave should we perform an audit at this point?
Mark Lancaster
this is what we do in egypt ,we used to crack any software code ,i'm student by the way and i can't get the student license version
is it possible to be a prisoner in ca !?
Mark.Lancaster
@Anonymous
What do you mean you can't get free Autodesk student licenses in Egypt?  As you can see here there are only a few countries listed due to embargo laws.  So please clarify why you can't get a student license of Autodesk products and you are forced to "crack" codes.
In addition the main users that monitor and support this forum will not provide solutions that allow someone to "crack" Autodesk software.  It is not fair to those who pay money each year to purchase these producta while others are doing illegal activity and want help in doing so.  Granted if you are student and attending a qualified educational institution, you would be getting it free anyways but @@TravisNave and I will not take part in helping you activate your software using illegal serial #s.  In the end if you are not going to do it the right/proper way please don't come here looking for support/assistance.  Smiley Wink
Mark Lancaster
