before 2 days from now it works smoothly & yesterday it is saying "license manager is not functioning or is improperly installed. AutoCAD will shut down"
i hv tried ur solutions --
& also tried to re-install it but again after re-installing same problem persists
Hi @knarender239,
Welcome to the Community.
Check out and try out the suggested troubleshooting steps mentioned in this article and see if that resolves your issue:
The License Manager is not functioning or is improperly installed.
Hope this information helps, let us know how it goes. Thanks.
I stole this wording/reply from my buddy Darin Green, so he takes all the credit for the steps..
This should help get your application working. Assuming you have a valid serial number/contract.
Close the application
Please note, folders of C:\Programdata and C:\Users\[Username]\Appdata (listed below) are hidden folders and you may need to adjust your viewing settings.
On your computer, navigate to: C:\ProgramData\Autodesk\CLM\LGS\<Product_Key>_2017.0.0.F [<Product Key> is the product key of the Autodesk Application you have]
Delete the LGS.data file.
Navigate to C:\Users\[username]\AppData\Roaming\Autodesk\ folder
Delete the ADUT folder and it's contents
Start the application.
When you start the application, it will prompt you to choose one of the following:
Login - 30 day trial licenses
Serial Number - Standalone and Single-User activation
Network - Network License server for obtaining licenses from a machine on your network
Choose the option that matches your license. Students will always select serial #.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hello @knarender239,
I hope you resolved the issue. Please let us know if you need some more help.
Thanks for posting.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
