Have you tried the solution here: "A fatal error has occurred...0xc0000005 EXCEPTION ACCESS VIOLATION" and crash when saving the file ...
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
Could also be related to a Windows Update. See this thread: Solved: Re: AutoCAD 2017 keeps crashing with error code 0xc0000005 - Autodesk Community - AutoCAD
Darin Green
Hi @patilal.yadav
Thanks a lot for posting your question to the forums! Has the solution suggested by @Darin.Green helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
: AutoCAD 2017 keeps crashing with error code 0xc0000005 fix this problum
