- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I can't install Autocad on my Dell Inspiron Laptop (64 bit windows 7)
I installed this succesfully before but I had to reformat my laptop so I had to install it once again..and now, it fails repeatedly. I'm not sure if its because of any uninstalled updates or graphics (I use Intel HD graphics which I think is okay though)...I have an installation log, so if anyone could help me with this, I would very much appreciate it š
2017/2/17:21:38:00 dell inspiron DELLINSPIRON-PC === Setup started on DELLINSPIRON-PC by dell inspiron ===
2017/2/17:21:38:00 dell inspiron DELLINSPIRON-PC Path_Length: 162
2017/2/17:21:38:00 dell inspiron DELLINSPIRON-PC Current Directory C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm
2017/2/17:21:38:00 dell inspiron DELLINSPIRON-PC Launch
2017/2/17:21:38:00 dell inspiron DELLINSPIRON-PC CommandLine
2017/2/17:21:38:00 dell inspiron DELLINSPIRON-PC Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AI5DCC.tmp
2017/2/17:21:38:30 dell inspiron DELLINSPIRON-PC === Setup ended ===
2017/2/17:21:38:09 dell inspiron DELLINSPIRON-PC === Setup started on DELLINSPIRON-PC by dell inspiron ===
2017/2/17:21:38:09 dell inspiron DELLINSPIRON-PC Path_Length: 162
2017/2/17:21:38:09 dell inspiron DELLINSPIRON-PC Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AI5DCC.tmp
2017/2/17:21:38:09 dell inspiron DELLINSPIRON-PC Launch
2017/2/17:21:38:11 dell inspiron DELLINSPIRON-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\DELLIN~1\AppData\Local\Temp\_AI5DCC.tmp\Setup\AcSetup.dll
2017/2/17:21:38:11 dell inspiron DELLINSPIRON-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/2/17:21:38:32 dell inspiron DELLINSPIRON-PC PageOpen LaunchDialog
2017/2/17:21:39:07 dell inspiron DELLINSPIRON-PC PageOpen LicenseDialog
2017/2/17:21:39:13 dell inspiron DELLINSPIRON-PC PageOpen ProductInfoDialog
2017/2/17:21:39:13 dell inspiron DELLINSPIRON-PC PageOpen ProductSelectionDialog2
2017/2/17:21:39:22 dell inspiron DELLINSPIRON-PC PageOpen FullProgressDialog
2017/2/17:21:39:23 dell inspiron DELLINSPIRON-PC Installing .NET Framework Runtime 4.6: "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\dotNetFramework\46\dotNetFx46_Full_x86_x64.exe" /q /norestart
2017/2/17:21:41:00 dell inspiron DELLINSPIRON-PC Install .NET Framework Runtime 4.6 Failed Failure is ignored, Result=1603
2017/2/17:21:41:00 dell inspiron DELLINSPIRON-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/2/17:21:41:43 dell inspiron DELLINSPIRON-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2017/2/17:21:41:43 dell inspiron DELLINSPIRON-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2017/2/17:21:42:19 dell inspiron DELLINSPIRON-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2017/2/17:21:42:19 dell inspiron DELLINSPIRON-PC Installing Universal C Runtime (KB3118401): "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/2/17:21:42:51 dell inspiron DELLINSPIRON-PC Install Universal C Runtime (KB3118401) Failed Failure is ignored, Result=2
2017/2/17:21:42:52 dell inspiron DELLINSPIRON-PC Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\DELLIN~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/2/17:21:44:08 dell inspiron DELLINSPIRON-PC Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=23
2017/2/17:21:44:08 dell inspiron DELLINSPIRON-PC Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\DELLIN~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/2/17:21:44:51 dell inspiron DELLINSPIRON-PC Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=23
2017/2/17:21:44:51 dell inspiron DELLINSPIRON-PC Installing DirectX Runtime: "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2017/2/17:21:45:39 dell inspiron DELLINSPIRON-PC Install DirectX Runtime Succeeded
2017/2/17:21:45:39 dell inspiron DELLINSPIRON-PC Installing Autodesk Material Library 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® 2017" SETUP_PACKAGECODE={12D88A40-9001-4FBB-8B99-92A0C62B981C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D1D649A4-B389-4176-9834-82D80CA33683} ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/2/17:21:47:07 dell inspiron DELLINSPIRON-PC Install Autodesk Material Library 2017 Succeeded
2017/2/17:21:47:07 dell inspiron DELLINSPIRON-PC Installing Autodesk Material Library 2017 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® 2017" SETUP_PACKAGECODE={12D88A40-9001-4FBB-8B99-92A0C62B981C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D1D649A4-B389-4176-9834-82D80CA33683} ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/2/17:21:47:47 dell inspiron DELLINSPIRON-PC Install Autodesk Material Library 2017 - Base Image Library Succeeded
2017/2/17:21:47:47 dell inspiron DELLINSPIRON-PC Installing AutodeskĀ® Material Library 2017 - Advanced Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® 2017" SETUP_PACKAGECODE={12D88A40-9001-4FBB-8B99-92A0C62B981C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={D1D649A4-B389-4176-9834-82D80CA33683} ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/2/17:21:48:03 dell inspiron DELLINSPIRON-PC Install AutodeskĀ® Material Library 2017 - Advanced Image Library Succeeded
2017/2/17:21:48:05 dell inspiron DELLINSPIRON-PC Installing AutoCAD 2017 Core: TRANSFORMS="C:\Users\DELLIN~1\AppData\Local\Temp\_AI5DCC.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2017\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/2/17:21:57:50 dell inspiron DELLINSPIRON-PC Install AutoCAD 2017 Core Succeeded
2017/2/17:21:57:51 dell inspiron DELLINSPIRON-PC Installing AutoCAD 2017 Language Core: TRANSFORMS="C:\Users\DELLIN~1\AppData\Local\Temp\_AI5DCC.tmp\x64\en-us\acad\AcadLP\AcadLP-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2017\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/2/17:21:58:48 dell inspiron DELLINSPIRON-PC Install AutoCAD 2017 Language Core Succeeded
2017/2/17:21:58:54 dell inspiron DELLINSPIRON-PC Installing ACA & MEP 2017 Object Enabler: TRANSFORMS="C:\Users\DELLIN~1\AppData\Local\Temp\_AI5DCC.tmp\x64\ACAOE\AcaOE-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2017\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/2/17:21:59:05 dell inspiron DELLINSPIRON-PC Install ACA & MEP 2017 Object Enabler Succeeded
2017/2/17:21:59:06 dell inspiron DELLINSPIRON-PC Installing AutoCAD 2017: TRANSFORMS="C:\Users\DELLIN~1\AppData\Local\Temp\_AI5DCC.tmp\x64\ACADPRIVATE\AcadPrivate-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2017\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/2/17:21:59:18 dell inspiron DELLINSPIRON-PC Install AutoCAD 2017 Succeeded
2017/2/17:21:59:18 dell inspiron DELLINSPIRON-PC Installing Cloud License Manager: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® 2017" SETUP_PACKAGECODE={12D88A40-9001-4FBB-8B99-92A0C62B981C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D1D649A4-B389-4176-9834-82D80CA33683} ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/2/17:22:00:07 dell inspiron DELLINSPIRON-PC Install Cloud License Manager Succeeded
2017/2/17:22:00:13 dell inspiron DELLINSPIRON-PC Installing AutodeskĀ® AutoCADĀ® 2017: TRANSFORMS="C:\Users\DELLIN~1\AppData\Local\Temp\_AI5DCC.tmp\x64\en-us\acad\AcadPS\AcadPS-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2017\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/2/17:22:01:14 dell inspiron DELLINSPIRON-PC Install AutodeskĀ® AutoCADĀ® 2017 Succeeded
2017/2/17:22:01:14 dell inspiron DELLINSPIRON-PC Installing SketchUp Import plug-in: ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® 2017" SETUP_PACKAGECODE={12D88A40-9001-4FBB-8B99-92A0C62B981C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D1D649A4-B389-4176-9834-82D80CA33683} ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/2/17:22:01:24 dell inspiron DELLINSPIRON-PC Install SketchUp Import plug-in Succeeded
2017/2/17:22:01:24 dell inspiron DELLINSPIRON-PC Installing Uninstalling all previous ReCap/ReCap 360 installations: "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\Setup\UninstallReqCheck_x64.exe" /uninstall_updgrade_codes {31ABA3F2-1000-1033-0102-111D43815377};{7B511E9E-1000-1033-0102-30C7CD025838};{F6FD1651-1000-1033-0102-387BAF9B3B0A};{16D3DACE-1000-1033-0102-C33330B7D65D};
2017/2/17:22:01:24 dell inspiron DELLINSPIRON-PC Install Uninstalling all previous ReCap/ReCap 360 installations Succeeded
2017/2/17:22:01:26 dell inspiron DELLINSPIRON-PC Installing FARO LS 5.5.0.44203: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® 2017" SETUP_PACKAGECODE={12D88A40-9001-4FBB-8B99-92A0C62B981C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D1D649A4-B389-4176-9834-82D80CA33683} ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/2/17:22:02:13 dell inspiron DELLINSPIRON-PC Install FARO LS 5.5.0.44203 Succeeded
2017/2/17:22:02:13 dell inspiron DELLINSPIRON-PC Installing AutodeskĀ® ReCap 360ā¢: INSTALLDIR="C:\Program Files\Autodesk\Autodesk ReCap 360\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® 2017" SETUP_PACKAGECODE={12D88A40-9001-4FBB-8B99-92A0C62B981C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Uninstalling all previous ReCap/ReCap 360 installations,Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161,Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161,Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),Microsoft Visual C++ 2012 Redistributable (x86) Update 4,Microsoft Visual C++ 2012 Redistributable (x64) Update 4,Microsoft Visual C++ 2015 Redistributable (x86),Microsoft Visual C++ 2015 Redistributable (x64),.NET Framework Runtime 4.0,{8834451B-6209-4E02-9EF4-4EF9E3C1F70F},;;;;" PACKAGEUPI={D1D649A4-B389-4176-9834-82D80CA33683} ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/2/17:22:04:16 dell inspiron DELLINSPIRON-PC Install Autodesk® ReCap 360⢠Succeeded
2017/2/17:22:04:17 dell inspiron DELLINSPIRON-PC Installing Exchange App Manager: ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® 2017" SETUP_PACKAGECODE={12D88A40-9001-4FBB-8B99-92A0C62B981C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D1D649A4-B389-4176-9834-82D80CA33683} ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/2/17:22:04:24 dell inspiron DELLINSPIRON-PC Install Exchange App Manager Succeeded
2017/2/17:22:04:25 dell inspiron DELLINSPIRON-PC Installing Exchange Featured Apps plug-in: ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® 2017" SETUP_PACKAGECODE={12D88A40-9001-4FBB-8B99-92A0C62B981C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D1D649A4-B389-4176-9834-82D80CA33683} ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/2/17:22:04:29 dell inspiron DELLINSPIRON-PC Install Exchange Featured Apps plug-in Succeeded
2017/2/17:22:04:29 dell inspiron DELLINSPIRON-PC Installing AutodeskĀ® AutoCADĀ® Performance Reporting Tool: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® 2017" SETUP_PACKAGECODE={12D88A40-9001-4FBB-8B99-92A0C62B981C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D1D649A4-B389-4176-9834-82D80CA33683} ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/2/17:22:04:33 dell inspiron DELLINSPIRON-PC Install AutodeskĀ® AutoCADĀ® Performance Reporting Tool Succeeded Reboot is required
2017/2/17:22:04:33 dell inspiron DELLINSPIRON-PC Installing Autodesk® BIM 360⢠Add-in for AutoCAD® 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2017" SETUP_PACKAGECODE={12D88A40-9001-4FBB-8B99-92A0C62B981C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D1D649A4-B389-4176-9834-82D80CA33683} ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/2/17:22:04:42 dell inspiron DELLINSPIRON-PC Install Autodesk® BIM 360⢠Add-in for AutoCAD® 2017 Failed Failure is ignored, Result=1603
2017/2/17:22:04:43 dell inspiron DELLINSPIRON-PC Installing A360 Desktop: TRANSFORMS="C:\Users\DELLIN~1\AppData\Local\Temp\_AI5DCC.tmp\x64\Components\Cloudsync\AdSync-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/2/17:22:07:00 dell inspiron DELLINSPIRON-PC Install A360 Desktop Succeeded Reboot is required
2017/2/17:22:07:00 dell inspiron DELLINSPIRON-PC Installing Autodesk Desktop App: "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\x86\ADSKAPP\AdApplicationManager-WebInstaller.exe"
2017/2/17:22:17:50 dell inspiron DELLINSPIRON-PC Install Autodesk Desktop App Succeeded
2017/2/17:22:17:57 dell inspiron DELLINSPIRON-PC PageOpen InstallCompleteDialog
2017/2/17:22:35:13 dell inspiron DELLINSPIRON-PC === Setup ended ===
2017/3/14:00:22:19 dell inspiron DELLINSPIRON-PC === Setup started on DELLINSPIRON-PC by dell inspiron ===
2017/3/14:00:22:19 dell inspiron DELLINSPIRON-PC Path_Length: 162
2017/3/14:00:22:19 dell inspiron DELLINSPIRON-PC Current Directory C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm
2017/3/14:00:22:19 dell inspiron DELLINSPIRON-PC Launch
2017/3/14:00:22:19 dell inspiron DELLINSPIRON-PC CommandLine
2017/3/14:00:22:19 dell inspiron DELLINSPIRON-PC Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AIBD84.tmp
2017/3/14:00:24:09 dell inspiron DELLINSPIRON-PC === Setup ended ===
2017/3/14:00:22:44 dell inspiron DELLINSPIRON-PC === Setup started on DELLINSPIRON-PC by dell inspiron ===
2017/3/14:00:22:44 dell inspiron DELLINSPIRON-PC Path_Length: 162
2017/3/14:00:22:44 dell inspiron DELLINSPIRON-PC Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AIBD84.tmp
2017/3/14:00:22:44 dell inspiron DELLINSPIRON-PC Launch
2017/3/14:00:22:48 dell inspiron DELLINSPIRON-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\DELLIN~1\AppData\Local\Temp\_AIBD84.tmp\Setup\AcSetup.dll
2017/3/14:00:22:48 dell inspiron DELLINSPIRON-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/14:00:24:12 dell inspiron DELLINSPIRON-PC PageOpen LaunchDialog
2017/3/14:00:29:40 dell inspiron DELLINSPIRON-PC PageOpen LicenseDialog
2017/3/14:01:01:44 dell inspiron DELLINSPIRON-PC PageOpen ProductInfoDialog
2017/3/14:01:01:44 dell inspiron DELLINSPIRON-PC PageOpen ProductSelectionDialog2
2017/3/14:01:01:47 dell inspiron DELLINSPIRON-PC PageOpen FullProgressDialog
2017/3/14:01:01:48 dell inspiron DELLINSPIRON-PC Installing .NET Framework Runtime 4.6: "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\dotNetFramework\46\dotNetFx46_Full_x86_x64.exe" /q /norestart
2017/3/14:01:20:13 dell inspiron DELLINSPIRON-PC Install .NET Framework Runtime 4.6 Succeeded
2017/3/14:01:20:14 dell inspiron DELLINSPIRON-PC Installing Universal C Runtime (KB3118401): "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/3/14:01:22:57 dell inspiron DELLINSPIRON-PC Install Universal C Runtime (KB3118401) Succeeded
2017/3/14:01:22:57 dell inspiron DELLINSPIRON-PC Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\DELLIN~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/3/14:01:26:00 dell inspiron DELLINSPIRON-PC Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=-2147023436
2017/3/14:01:26:00 dell inspiron DELLINSPIRON-PC Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\DELLIN~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/3/14:01:29:03 dell inspiron DELLINSPIRON-PC Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=-2147023436
2017/3/14:01:29:03 dell inspiron DELLINSPIRON-PC Installing DirectX Runtime: "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/14:01:30:21 dell inspiron DELLINSPIRON-PC Install DirectX Runtime Succeeded
2017/3/14:01:30:22 dell inspiron DELLINSPIRON-PC Installing Autodesk Material Library 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® 2017" SETUP_PACKAGECODE={12D88A40-9001-4FBB-8B99-92A0C62B981C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D1D649A4-B389-4176-9834-82D80CA33683} ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/14:01:30:22 dell inspiron DELLINSPIRON-PC Install Autodesk Material Library 2017 Failed Installation aborted, Result=1622
2017/3/14:01:30:25 dell inspiron DELLINSPIRON-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/3/14:01:30:25 dell inspiron DELLINSPIRON-PC Rollback .NET Framework Runtime 4.6 Failed Failure is ignored, Result=1619
2017/3/14:01:30:40 dell inspiron DELLINSPIRON-PC PageOpen InstallCompleteDialog
2017/3/14:01:43:57 dell inspiron DELLINSPIRON-PC === Setup ended ===
2017/3/14:01:59:13 dell inspiron DELLINSPIRON-PC === Setup started on DELLINSPIRON-PC by dell inspiron ===
2017/3/14:01:59:13 dell inspiron DELLINSPIRON-PC Path_Length: 162
2017/3/14:01:59:13 dell inspiron DELLINSPIRON-PC Current Directory C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm
2017/3/14:01:59:13 dell inspiron DELLINSPIRON-PC Launch
2017/3/14:01:59:13 dell inspiron DELLINSPIRON-PC CommandLine
2017/3/14:01:59:13 dell inspiron DELLINSPIRON-PC Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AI8058.tmp
2017/3/14:02:00:41 dell inspiron DELLINSPIRON-PC === Setup ended ===
2017/3/14:01:59:27 dell inspiron DELLINSPIRON-PC === Setup started on DELLINSPIRON-PC by dell inspiron ===
2017/3/14:01:59:27 dell inspiron DELLINSPIRON-PC Path_Length: 162
2017/3/14:01:59:27 dell inspiron DELLINSPIRON-PC Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AI8058.tmp
2017/3/14:01:59:27 dell inspiron DELLINSPIRON-PC Launch
2017/3/14:01:59:32 dell inspiron DELLINSPIRON-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\DELLIN~1\AppData\Local\Temp\_AI8058.tmp\Setup\AcSetup.dll
2017/3/14:01:59:32 dell inspiron DELLINSPIRON-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/14:02:00:46 dell inspiron DELLINSPIRON-PC PageOpen LaunchDialog
2017/3/14:02:02:27 dell inspiron DELLINSPIRON-PC PageOpen LicenseDialog
2017/3/14:02:04:57 dell inspiron DELLINSPIRON-PC PageOpen ProductInfoDialog
2017/3/14:02:04:58 dell inspiron DELLINSPIRON-PC PageOpen ProductSelectionDialog2
2017/3/14:02:05:04 dell inspiron DELLINSPIRON-PC PageOpen FullProgressDialog
2017/3/14:02:05:05 dell inspiron DELLINSPIRON-PC Installing Universal C Runtime (KB3118401): "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/3/14:02:05:28 dell inspiron DELLINSPIRON-PC Install Universal C Runtime (KB3118401) Succeeded
2017/3/14:02:05:28 dell inspiron DELLINSPIRON-PC Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\DELLIN~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/3/14:02:08:31 dell inspiron DELLINSPIRON-PC Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=-2147023436
2017/3/14:02:08:31 dell inspiron DELLINSPIRON-PC Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\DELLIN~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/3/14:02:11:36 dell inspiron DELLINSPIRON-PC Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=-2147023436
2017/3/14:02:11:36 dell inspiron DELLINSPIRON-PC Installing DirectX Runtime: "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/14:02:13:40 dell inspiron DELLINSPIRON-PC Install DirectX Runtime Succeeded
2017/3/14:02:13:40 dell inspiron DELLINSPIRON-PC Installing Autodesk Material Library 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® 2017" SETUP_PACKAGECODE={12D88A40-9001-4FBB-8B99-92A0C62B981C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D1D649A4-B389-4176-9834-82D80CA33683} ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/14:02:13:40 dell inspiron DELLINSPIRON-PC Install Autodesk Material Library 2017 Failed Installation aborted, Result=1622
2017/3/14:02:13:43 dell inspiron DELLINSPIRON-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/3/14:02:13:48 dell inspiron DELLINSPIRON-PC PageOpen InstallCompleteDialog
2017/3/14:02:15:07 dell inspiron DELLINSPIRON-PC === Setup ended ===
2017/3/26:14:15:22 dell inspiron DELLINSPIRON-PC === Setup started on DELLINSPIRON-PC by dell inspiron ===
2017/3/26:14:15:22 dell inspiron DELLINSPIRON-PC Path_Length: 162
2017/3/26:14:15:22 dell inspiron DELLINSPIRON-PC Current Directory C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm
2017/3/26:14:15:22 dell inspiron DELLINSPIRON-PC Launch
2017/3/26:14:15:22 dell inspiron DELLINSPIRON-PC CommandLine
2017/3/26:14:15:22 dell inspiron DELLINSPIRON-PC Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AIF4AA.tmp
2017/3/26:14:16:16 dell inspiron DELLINSPIRON-PC === Setup ended ===
2017/3/26:14:15:37 dell inspiron DELLINSPIRON-PC === Setup started on DELLINSPIRON-PC by dell inspiron ===
2017/3/26:14:15:37 dell inspiron DELLINSPIRON-PC Path_Length: 162
2017/3/26:14:15:37 dell inspiron DELLINSPIRON-PC Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AIF4AA.tmp
2017/3/26:14:15:37 dell inspiron DELLINSPIRON-PC Launch
2017/3/26:14:15:38 dell inspiron DELLINSPIRON-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\DELLIN~1\AppData\Local\Temp\_AIF4AA.tmp\Setup\AcSetup.dll
2017/3/26:14:15:38 dell inspiron DELLINSPIRON-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/26:14:16:02 dell inspiron DELLINSPIRON-PC PageOpen LaunchDialog
2017/3/26:14:16:25 dell inspiron DELLINSPIRON-PC PageOpen LicenseDialog
2017/3/26:15:05:25 dell inspiron DELLINSPIRON-PC PageOpen ProductInfoDialog
2017/3/26:15:05:25 dell inspiron DELLINSPIRON-PC PageOpen ProductSelectionDialog2
2017/3/26:15:05:30 dell inspiron DELLINSPIRON-PC PageOpen FullProgressDialog
2017/3/26:15:05:31 dell inspiron DELLINSPIRON-PC Installing Universal C Runtime (KB3118401): "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/3/26:15:05:34 dell inspiron DELLINSPIRON-PC Install Universal C Runtime (KB3118401) Succeeded
2017/3/26:15:05:34 dell inspiron DELLINSPIRON-PC Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\DELLIN~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/3/26:15:08:39 dell inspiron DELLINSPIRON-PC Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=-2147023436
2017/3/26:15:08:39 dell inspiron DELLINSPIRON-PC Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\DELLIN~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/3/26:15:11:41 dell inspiron DELLINSPIRON-PC Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=-2147023436
2017/3/26:15:11:41 dell inspiron DELLINSPIRON-PC Installing DirectX Runtime: "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/26:15:13:21 dell inspiron DELLINSPIRON-PC Install DirectX Runtime Succeeded
2017/3/26:15:13:21 dell inspiron DELLINSPIRON-PC Installing Autodesk Material Library 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® 2017" SETUP_PACKAGECODE={12D88A40-9001-4FBB-8B99-92A0C62B981C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D1D649A4-B389-4176-9834-82D80CA33683} ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/26:15:13:21 dell inspiron DELLINSPIRON-PC Install Autodesk Material Library 2017 Failed Installation aborted, Result=1622
2017/3/26:15:13:22 dell inspiron DELLINSPIRON-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/3/26:15:13:24 dell inspiron DELLINSPIRON-PC PageOpen InstallCompleteDialog
2017/3/26:15:25:15 dell inspiron DELLINSPIRON-PC === Setup ended ===
2017/3/27:20:16:04 dell inspiron DELLINSPIRON-PC === Setup started on DELLINSPIRON-PC by dell inspiron ===
2017/3/27:20:16:04 dell inspiron DELLINSPIRON-PC Path_Length: 162
2017/3/27:20:16:04 dell inspiron DELLINSPIRON-PC Current Directory C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm
2017/3/27:20:16:04 dell inspiron DELLINSPIRON-PC Launch
2017/3/27:20:16:04 dell inspiron DELLINSPIRON-PC CommandLine
2017/3/27:20:16:04 dell inspiron DELLINSPIRON-PC Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AIC59F.tmp
2017/3/27:20:17:33 dell inspiron DELLINSPIRON-PC === Setup ended ===
2017/3/27:20:16:31 dell inspiron DELLINSPIRON-PC === Setup started on DELLINSPIRON-PC by dell inspiron ===
2017/3/27:20:16:31 dell inspiron DELLINSPIRON-PC Path_Length: 162
2017/3/27:20:16:31 dell inspiron DELLINSPIRON-PC Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AIC59F.tmp
2017/3/27:20:16:31 dell inspiron DELLINSPIRON-PC Launch
2017/3/27:20:16:33 dell inspiron DELLINSPIRON-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\DELLIN~1\AppData\Local\Temp\_AIC59F.tmp\Setup\AcSetup.dll
2017/3/27:20:16:33 dell inspiron DELLINSPIRON-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/27:20:17:35 dell inspiron DELLINSPIRON-PC PageOpen LaunchDialog
2017/3/27:20:19:19 dell inspiron DELLINSPIRON-PC PageOpen LicenseDialog
2017/3/27:20:20:31 dell inspiron DELLINSPIRON-PC PageOpen ProductInfoDialog
2017/3/27:20:20:31 dell inspiron DELLINSPIRON-PC PageOpen ProductSelectionDialog2
2017/3/27:20:20:55 dell inspiron DELLINSPIRON-PC PageOpen FullProgressDialog
2017/3/27:20:20:56 dell inspiron DELLINSPIRON-PC Installing Universal C Runtime (KB3118401): "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/3/27:20:20:57 dell inspiron DELLINSPIRON-PC Install Universal C Runtime (KB3118401) Succeeded
2017/3/27:20:20:57 dell inspiron DELLINSPIRON-PC Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\DELLIN~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/3/27:20:23:59 dell inspiron DELLINSPIRON-PC Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=-2147023436
2017/3/27:20:23:59 dell inspiron DELLINSPIRON-PC Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\DELLIN~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/3/27:20:27:02 dell inspiron DELLINSPIRON-PC Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=-2147023436
2017/3/27:20:27:02 dell inspiron DELLINSPIRON-PC Installing DirectX Runtime: "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/27:20:29:19 dell inspiron DELLINSPIRON-PC Install DirectX Runtime Succeeded
2017/3/27:20:29:19 dell inspiron DELLINSPIRON-PC Installing Autodesk Material Library 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® 2017" SETUP_PACKAGECODE={12D88A40-9001-4FBB-8B99-92A0C62B981C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D1D649A4-B389-4176-9834-82D80CA33683} ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/27:20:29:19 dell inspiron DELLINSPIRON-PC Install Autodesk Material Library 2017 Failed Installation aborted, Result=1622
2017/3/27:20:29:22 dell inspiron DELLINSPIRON-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
