Installation & Licensing
AutoCAD 2016 would not open in Windows 10
5 REPLIES 5
1013 Views, 5 Replies
Hey guys,
I have a huge problem regarding my AutoCAD 2016 installation after I had upgraded to Windows 10.
First, the AutoCAD program that I had installed was not installed properly and I got redirected to an error page where it said that a software problem had caused AutoCAD 2016 to stop working. Nevertheless it was marked as completed so I tried to open it. The splash screen loads, but after that, the program crashes. That meant thatcould not access the activation page and actually start opening my projects.
Other Autodesk programs are working fine. It's just this program that is not working. I had uninstalled of the Autodesk Content in the computer and even went to the registry to delete all the Autodesk Files.
Computer Specs: Acer Aspire ES1-512-P0SY
OS Version: Windows 10
Graphics: Intel (R)HD Graphics
Carl
5 REPLIES 5
Otto
Hello carlalexandre42 and welcome to the Autodesk community!
It looks like you're unable to launch AutoCAD 2016 after installation. This issue may occur due to AutoCAD running on DirectX 11 instead of DirectX 9. The following article(s) should help you resolve the problem:
How to make AutoCAD run with DirectX 9
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
ampster40
looks like the helpbot got into the liquor cabinet again - totally missed the part about "Windows 10". SP1 for Acad 2016 might help or solve this issue - I can't say for sure since we're not running 2016 yet but there's a post about SP1 making 2016 compatible with Win10 made recently. HTH
in reply to: ampster40
I had installed the update, but it still doesn't work. I'll try the first solution.
Even with the DirectX 9 setting was applied (1st reply to the solution), the application still crashed. I think this is a new problem that I haven't seen in the other Autodesk Applications before. I still haven't received any solutions from the Autodesk CER in the mail so I'm suspecting that this might be one.
Anyone with a solution? I'm still facing all the problems in the computer even after installing and reinstalling.
Error in the licensing.
2684 2015/10/03 22:06:50 Reason=License import
2684 2015/10/03 22:06:50 ComputerName=大多喜城
2684 2015/10/03 22:06:50 OS=6.2.9200.
2684 2015/10/03 22:06:50 XmlCode=PRODUCT=ACD;VERSION=2016_0;RELEASE_TYPE=F;DEPLOY_TYPE=S;FUL_TYPE=FL
2684 2015/10/03 22:06:50 LicenseStatus=1.1.0
2684 2015/10/03 22:06:58 Reason=Fatal error
2684 2015/10/03 22:06:58 ComputerName=大多喜城
2684 2015/10/03 22:06:58 OS=6.2.9200.
2684 2015/10/03 22:06:58 File=AdlmFlxActAppLicenseStateHandler.cpp,Line=378
2684 2015/10/03 22:06:58 AdlmActError=306 [Fatal error from Register Today call]
2684 2015/10/03 22:06:58 File=ltuManager.cpp,Line=170
2684 2015/10/03 22:06:58 VendorID=2 [ADLMACT]
2684 2015/10/03 22:06:58 VendorError=306 [Fatal error from Register Today call]
2684 2015/10/03 22:06:58 File=ltuManager.cpp,Line=171
2684 2015/10/03 22:06:58 LTUError=1 [LTU import or export failed]
13284 2015/10/03 22:07:10 Reason=License import
13284 2015/10/03 22:07:10 ComputerName=大多喜城
13284 2015/10/03 22:07:10 OS=6.2.9200.
13284 2015/10/03 22:07:10 XmlCode=PRODUCT=ACD;VERSION=2016_0;RELEASE_TYPE=F;DEPLOY_TYPE=S;FUL_TYPE=FL
13284 2015/10/03 22:07:10 LicenseStatus=1.1.0
13284 2015/10/03 22:07:26 Reason=License import
13284 2015/10/03 22:07:26 ComputerName=大多喜城
13284 2015/10/03 22:07:26 OS=6.2.9200.
13284 2015/10/03 22:07:26 XmlCode=PRODUCT=ACD;VERSION=2016_0;RELEASE_TYPE=F;DEPLOY_TYPE=S;FUL_TYPE=FL
13284 2015/10/03 22:07:26 LicenseStatus=1.1.0
13284 2015/10/03 22:07:47 Reason=Fatal error
13284 2015/10/03 22:07:47 ComputerName=大多喜城
13284 2015/10/03 22:07:47 OS=6.2.9200.
13284 2015/10/03 22:07:47 File=ltuManager.cpp,Line=170
13284 2015/10/03 22:07:47 VendorID=2 [ADLMACT]
13284 2015/10/03 22:07:47 VendorError=2 [An operation is cancelled]
13284 2015/10/03 22:07:47 File=ltuManager.cpp,Line=171
13284 2015/10/03 22:07:47 LTUError=1 [LTU import or export failed]
Administrator Productivity
