AutoCad 2016-Softlock license manager error
F.Camargo
Advisor Advisor
Message 1 of 8
F.Camargo
Hello guys,
My autocad isn't working. I don't know what's happening!
two alert appears on the screen.
I found this link:
https://forums.autodesk.com/t5/installation-licensing/security-system-softlock-license-manager-error...
This step isn't working for me:
It seems that all you have to do is:
                                                              1) Close any running applications or files or internet browsers
                                                              2) Cut the actual "FLEXnet" file ( found at C:\ProgramData )
                                                              3) Paste this file onto your desktop
                                                              4) Startup AutoCad and it should be running without issue"
Replies (7)
Message 2 of 8
Otto
Hello F.Camargo
It looks like you're getting a Softlock License Manager error. This error can have several causes. The following article(s) should help you resolve the problem:
Launching program results in Softlock License Manager error
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 8
Mark.Lancaster
@F.Camargo
This is a English speaking forum so we have no way of converting your first message..  Please convert into English so we have a full understanding of the message.
Also check out this article because it has some additional information where-as the posting you provided doesn't.
Mark Lancaster
Message 4 of 8
F.Camargo
@Mark.Lancaster
@Otto
Thank you for replay.
I couldn't find the first step.
In portuguese I think it is a different input for "services."
I've already translate to portuguese and isn't help me.
Could you help me, please?
Maybe a image will be good.
Message 5 of 8
F.Camargo
I reset my autocad
And isn't working...
Message 6 of 8
Mark.Lancaster
@F.Camargo
You can't reset something that isn't activated..  Smiley Wink
Select the Windows start button on your keyboard along with the R key and you should see Run dialog.
Type comexp.msc and that will bring up Windows Services.
Mark Lancaster
Message 7 of 8
natasha.l
Hello @F.Camargo,
You can type it in the Windows Start search and Type "Services".
Message 8 of 8
F.Camargo
Thanks you guys!!
The problem was solved! I'm very happy.
Fabricio
