AutoCAD 2016 Crash
AutoCAD 2016 Crash
Message 1 of 14
AutoCAD 2016 Crash
Good evening! I have problems with the trial version of AutoCAD 2016. I installed the program on my personal computer, but it does not work and does not respond. The cursor disappears in the program field, the buttons look wrong, I cannot click on them, I cannot close the program or minimize it. I attach a screenshot to show how the program looks during the work.
I suppose that my computer is not powerful enough to work at AutoCAD 2016. Its characteristics are:
Screen resolution - 1366 * 768
Operating system - Windows 10
Windows version - 1803
Device name - LAPTOP-EMIDGN
Processor - Intel (R) Core (TM) i3 - 5005U CPU
2.00GHz
RAM - 4 GB
The device code is 61C8BE68-4AA7-4ACA-82BF-E59070D9E072
Product Code - 00327-30000-00000-AAOEM
System Type - 64-bit operating system
Please tell me what the problem is and whether I can contact by phone (I live in Russia) with customer support.
Replies (13)
Message 2 of 14
pendean
Community Legend
Community Legend
Yes, your laptop is underpowered, start GRAPHICSCONFIG command and turn off hardware acceleration to see if that helps.
Trial of AutoCAD2016? you cannot buy a new license for that today, you do know that, correct?
R2016 is also not well suited for Windows10 https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Windows-...
Message 3 of 14
What exactly is the problem in my computer, does it need more RAM or is it something else?
So, Windows 10 works best with  AutoCAD 2017, 2018 and 2019?
Message 4 of 14
I would like to know which versions of the AutoCAD program (maybe AutoCAD 2013 or AutoCAD 2010) can theoretically work with the operating system Windows 7 and the characteristics of my computer?
Message 5 of 14
pendean
Community Legend
Community Legend
Try what I suggest starting with the first one then see if your problem goes away: your video card is inadequate/choking.
Other issues: your processor is a low end model (made for word processing duties), plus your ram is insuficient for a 64bit OS, and you lack a quality upgraded video card. Explore this link for what makes a better laptop for autocad https://picknotebook.com/blog/the-best-laptop-for-autocad/
Message 6 of 14
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
Recent Windows 10 security updates like around Oct 9/10th have caused AutoCAD to lock up on some machines.  Do you have an recent Windows security update like this 2018-11-01_13-53-22.jpg
Mark Lancaster
Message 7 of 14
I don't know, how to check this, which folder and where in my computer should I open?
Message 8 of 14
Mark.Lancaster
@Anonymous
There's no folder for you to check..
Go into Windows/Control Panel/Program and Features/Add & Remove programs and select Window updates (upper left) and scroll down to see security updates that was applied to Windows.
Mark Lancaster
Message 9 of 14
Yes, I have this update of security, what should I do now?
Message 10 of 14
I don't know, how to start GRAPHICSCONFIG command and turn off hardware acceleration, can you explain me in more details, how to do it, please?
Message 11 of 14
natasha.l
Hello @Anonymous,
 Type the command GRAPHICSCONFIG > then turn off Hardware Acceleration.
Let us know how it goes.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 12 of 14
Unfortunately, I can not do this, the program does not respond, I can not press the buttons and get some kind of response
Message 13 of 14
Mark.Lancaster
@Anonymous
Can you remove/uninstall that update as I pointed out?
Mark Lancaster
Message 14 of 14
Yes, I've already uninstalled this update. By the way, my problem was solved: I installed AutoCAD 2018, and it works very good even on the underpowered computer. I don't know, why, but I'm just very happy. Do you know, what is the reason?
And thank you very much!
