2016/3/27:16:02:59 TitanmonZ GALOSSIDE === Setup started on GALOSSIDE by TitanmonZ ===
2016/3/27:16:02:59 TitanmonZ GALOSSIDE Path_Length: 162
2016/3/27:16:02:59 TitanmonZ GALOSSIDE Current Directory C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm
2016/3/27:16:02:59 TitanmonZ GALOSSIDE Launch
2016/3/27:16:02:59 TitanmonZ GALOSSIDE CommandLine
2016/3/27:16:02:59 TitanmonZ GALOSSIDE Current Directory C:\Users\TITANM~1\AppData\Local\Temp\_AI751.tmp
2016/3/27:16:03:28 TitanmonZ GALOSSIDE === Setup ended ===
2016/3/27:16:03:08 TitanmonZ GALOSSIDE === Setup started on GALOSSIDE by TitanmonZ ===
2016/3/27:16:03:08 TitanmonZ GALOSSIDE Path_Length: 162
2016/3/27:16:03:08 TitanmonZ GALOSSIDE Current Directory C:\Users\TITANM~1\AppData\Local\Temp\_AI751.tmp
2016/3/27:16:03:08 TitanmonZ GALOSSIDE Launch
2016/3/27:16:03:09 TitanmonZ GALOSSIDE Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\TITANM~1\AppData\Local\Temp\_AI751.tmp\Setup\AcSetup.dll
2016/3/27:16:03:09 TitanmonZ GALOSSIDE Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/3/27:16:03:29 TitanmonZ GALOSSIDE PageOpen LaunchDialog
2016/3/27:16:04:13 TitanmonZ GALOSSIDE PageOpen LicenseDialog
2016/3/27:16:04:21 TitanmonZ GALOSSIDE PageOpen ProductInfoDialog
2016/3/27:16:04:21 TitanmonZ GALOSSIDE PageOpen ProductSelectionDialog2
2016/3/27:16:07:50 TitanmonZ GALOSSIDE PageOpen FullProgressDialog
2016/3/27:16:07:51 TitanmonZ GALOSSIDE Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2016/3/27:16:07:56 TitanmonZ GALOSSIDE Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2016/3/27:16:08:00 TitanmonZ GALOSSIDE PageOpen InstallCompleteDialog
2016/3/27:16:10:29 TitanmonZ GALOSSIDE === Setup ended ===
2016/3/27:16:14:54 TitanmonZ GALOSSIDE === Setup started on GALOSSIDE by TitanmonZ ===
2016/3/27:16:14:54 TitanmonZ GALOSSIDE Path_Length: 162
2016/3/27:16:14:54 TitanmonZ GALOSSIDE Current Directory C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm
2016/3/27:16:14:54 TitanmonZ GALOSSIDE Launch
2016/3/27:16:14:54 TitanmonZ GALOSSIDE CommandLine
2016/3/27:16:14:54 TitanmonZ GALOSSIDE Current Directory C:\Users\TITANM~1\AppData\Local\Temp\_AIF29B.tmp
2016/3/27:16:15:17 TitanmonZ GALOSSIDE === Setup ended ===
2016/3/27:16:15:02 TitanmonZ GALOSSIDE === Setup started on GALOSSIDE by TitanmonZ ===
2016/3/27:16:15:02 TitanmonZ GALOSSIDE Path_Length: 162
2016/3/27:16:15:02 TitanmonZ GALOSSIDE Current Directory C:\Users\TITANM~1\AppData\Local\Temp\_AIF29B.tmp
2016/3/27:16:15:02 TitanmonZ GALOSSIDE Launch
2016/3/27:16:15:02 TitanmonZ GALOSSIDE Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\TITANM~1\AppData\Local\Temp\_AIF29B.tmp\Setup\AcSetup.dll
2016/3/27:16:15:02 TitanmonZ GALOSSIDE Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/3/27:16:15:12 TitanmonZ GALOSSIDE PageOpen LaunchDialog
2016/3/27:16:15:26 TitanmonZ GALOSSIDE PageOpen LicenseDialog
2016/3/27:16:15:31 TitanmonZ GALOSSIDE PageOpen ProductInfoDialog
2016/3/27:16:15:31 TitanmonZ GALOSSIDE PageOpen ProductSelectionDialog2
2016/3/27:16:15:37 TitanmonZ GALOSSIDE PageOpen FullProgressDialog
2016/3/27:16:15:37 TitanmonZ GALOSSIDE Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2016/3/27:16:15:39 TitanmonZ GALOSSIDE Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2016/3/27:16:15:43 TitanmonZ GALOSSIDE PageOpen InstallCompleteDialog
2016/3/27:16:15:49 TitanmonZ GALOSSIDE === Setup ended ===
2016/3/27:16:22:59 TitanmonZ GALOSSIDE === Setup started on GALOSSIDE by TitanmonZ ===
2016/3/27:16:22:59 TitanmonZ GALOSSIDE Path_Length: 162
2016/3/27:16:22:59 TitanmonZ GALOSSIDE Current Directory C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm
2016/3/27:16:22:59 TitanmonZ GALOSSIDE Launch
2016/3/27:16:22:59 TitanmonZ GALOSSIDE CommandLine
2016/3/27:16:22:59 TitanmonZ GALOSSIDE Current Directory C:\Users\TITANM~1\AppData\Local\Temp\_AI56E1.tmp
2016/3/27:16:23:23 TitanmonZ GALOSSIDE === Setup ended ===
2016/3/27:16:23:04 TitanmonZ GALOSSIDE === Setup started on GALOSSIDE by TitanmonZ ===
2016/3/27:16:23:04 TitanmonZ GALOSSIDE Path_Length: 162
2016/3/27:16:23:04 TitanmonZ GALOSSIDE Current Directory C:\Users\TITANM~1\AppData\Local\Temp\_AI56E1.tmp
2016/3/27:16:23:04 TitanmonZ GALOSSIDE Launch
2016/3/27:16:23:06 TitanmonZ GALOSSIDE Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\TITANM~1\AppData\Local\Temp\_AI56E1.tmp\Setup\AcSetup.dll
2016/3/27:16:23:06 TitanmonZ GALOSSIDE Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/3/27:16:23:21 TitanmonZ GALOSSIDE PageOpen LaunchDialog
2016/3/27:16:23:30 TitanmonZ GALOSSIDE PageOpen LicenseDialog
2016/3/27:16:23:35 TitanmonZ GALOSSIDE PageOpen ProductInfoDialog
2016/3/27:16:23:35 TitanmonZ GALOSSIDE PageOpen ProductSelectionDialog2
2016/3/27:16:23:39 TitanmonZ GALOSSIDE PageOpen FullProgressDialog
2016/3/27:16:23:39 TitanmonZ GALOSSIDE Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2016/3/27:16:23:43 TitanmonZ GALOSSIDE Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2016/3/27:16:23:50 TitanmonZ GALOSSIDE PageOpen InstallCompleteDialog
2016/3/27:16:23:55 TitanmonZ GALOSSIDE === Setup ended ===
2016/3/27:16:27:03 TitanmonZ GALOSSIDE === Setup started on GALOSSIDE by TitanmonZ ===
2016/3/27:16:27:03 TitanmonZ GALOSSIDE Path_Length: 162
2016/3/27:16:27:03 TitanmonZ GALOSSIDE Current Directory C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm
2016/3/27:16:27:03 TitanmonZ GALOSSIDE Launch
2016/3/27:16:27:03 TitanmonZ GALOSSIDE CommandLine
2016/3/27:16:27:03 TitanmonZ GALOSSIDE Current Directory C:\Users\TITANM~1\AppData\Local\Temp\_AI12D0.tmp
2016/3/27:16:27:25 TitanmonZ GALOSSIDE === Setup ended ===
2016/3/27:16:27:10 TitanmonZ GALOSSIDE === Setup started on GALOSSIDE by TitanmonZ ===
2016/3/27:16:27:10 TitanmonZ GALOSSIDE Path_Length: 162
2016/3/27:16:27:10 TitanmonZ GALOSSIDE Current Directory C:\Users\TITANM~1\AppData\Local\Temp\_AI12D0.tmp
2016/3/27:16:27:10 TitanmonZ GALOSSIDE Launch
2016/3/27:16:27:10 TitanmonZ GALOSSIDE Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\TITANM~1\AppData\Local\Temp\_AI12D0.tmp\Setup\AcSetup.dll
2016/3/27:16:27:10 TitanmonZ GALOSSIDE Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/3/27:16:27:22 TitanmonZ GALOSSIDE PageOpen LaunchDialog
2016/3/27:16:27:39 TitanmonZ GALOSSIDE PageOpen LicenseDialog
2016/3/27:16:27:39 TitanmonZ GALOSSIDE PageOpen ProductSelectionDialog2
2016/3/27:16:27:44 TitanmonZ GALOSSIDE PageOpen LicenseDialog
2016/3/27:16:27:44 TitanmonZ GALOSSIDE PageOpen LaunchDialog
2016/3/27:16:27:59 TitanmonZ GALOSSIDE PageOpen LicenseDialog
2016/3/27:16:28:02 TitanmonZ GALOSSIDE PageOpen ProductInfoDialog
2016/3/27:16:28:02 TitanmonZ GALOSSIDE PageOpen ProductSelectionDialog2
2016/3/27:16:28:06 TitanmonZ GALOSSIDE PageOpen FullProgressDialog
2016/3/27:16:28:06 TitanmonZ GALOSSIDE Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2016/3/27:16:28:10 TitanmonZ GALOSSIDE Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
Here is the setup log. I did try to manually install Microsoft Visual C++ 2008 SP1 Redistributable (x86) downloaded from microsoft website which gave me "error 997.overlapped I/O operation is in progress"
This happened to both 2016 and 2017 version.
Solved by Mark.Lancaster. Go to Solution.
galos_side
Welcome to the community...
Most likely the versions of C++ Redistributable on your machine is newer than what the installation needs. I would recommend that you uninstall all the versions you have (C++ Redistrubutable 32b/64b) through WIndows Control Panel/Add&Remove Programs and let the installation put them back on. In addition are you using the Autodesk Virtual Agent method where you download the entire software, extract it and then install?
Mark Lancaster
& Autodesk Services MarketPlace Provider
yes, i downloaded with virsual agent full and extracted it. I did uninstall all of my c++ and it still give me the same result. This doesn't happen to the other computer with windows 7 installed though.
2016/3/27:21:41:47 TitanmonZ GALOSSIDE === Setup started on GALOSSIDE by TitanmonZ ===
2016/3/27:21:41:47 TitanmonZ GALOSSIDE Path_Length: 154
2016/3/27:21:41:47 TitanmonZ GALOSSIDE Current Directory C:\Users\TITANM~1\AppData\Local\Temp\_AI24DA.tmp
2016/3/27:21:41:47 TitanmonZ GALOSSIDE Launch
2016/3/27:21:41:48 TitanmonZ GALOSSIDE Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\TITANM~1\AppData\Local\Temp\_AI24DA.tmp\Setup\AcSetup.dll
2016/3/27:21:41:48 TitanmonZ GALOSSIDE Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/3/27:21:41:53 TitanmonZ GALOSSIDE PageOpen LaunchDialog
2016/3/27:21:41:55 TitanmonZ GALOSSIDE PageOpen LicenseDialog
2016/3/27:21:41:59 TitanmonZ GALOSSIDE PageOpen ProductInfoDialog
2016/3/27:21:42:03 TitanmonZ GALOSSIDE PageOpen ProductSelectionDialog2
2016/3/27:21:42:08 TitanmonZ GALOSSIDE PageOpen FullProgressDialog
2016/3/27:21:42:08 TitanmonZ GALOSSIDE Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\AutoCAD_2016_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2016/3/27:21:42:11 TitanmonZ GALOSSIDE Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
See this information that @TravisNave has created..
Mark Lancaster
It happened to me several times!
I solved it by uninstalling all the Microsoft Visual C++ already present on the computer, then run the Autodesk product (it may be AutoCAD or whatever product you're trying to install). The idea is that the product will install its own version of the Microsoft Visual C++ without having to run into conflict with any versions that could have been present.
I hope this helps.
'Autocad 2017 installation fails. Here is the log file
2016/9/7:13:39:48 yasemin DESKTOP-8R7KP51 === Setup started on DESKTOP-8R7KP51 by yasemin ===
2016/9/7:13:39:48 yasemin DESKTOP-8R7KP51 Path_Length: 162
2016/9/7:13:39:48 yasemin DESKTOP-8R7KP51 Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2016/9/7:13:39:48 yasemin DESKTOP-8R7KP51 Launch
2016/9/7:13:39:48 yasemin DESKTOP-8R7KP51 CommandLine /akamai /sid SESSION_ID /skipEULA /trialMode /url "http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Setu..."
2016/9/7:13:39:48 yasemin DESKTOP-8R7KP51 Current Directory C:\Users\yasemin\AppData\Local\Temp\_AI99DE.tmp
2016/9/7:13:41:07 yasemin DESKTOP-8R7KP51 === Setup ended ===
2016/9/7:13:39:49 yasemin DESKTOP-8R7KP51 === Setup started on DESKTOP-8R7KP51 by yasemin ===
2016/9/7:13:39:49 yasemin DESKTOP-8R7KP51 Path_Length: 162
2016/9/7:13:39:49 yasemin DESKTOP-8R7KP51 Current Directory C:\Users\yasemin\AppData\Local\Temp\_AI99DE.tmp
2016/9/7:13:39:49 yasemin DESKTOP-8R7KP51 Launch
2016/9/7:13:40:12 yasemin DESKTOP-8R7KP51 Download Play SETUPMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARKER...
2016/9/7:13:40:13 yasemin DESKTOP-8R7KP51 Download Complete SETUPMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARKER...
2016/9/7:13:40:13 yasemin DESKTOP-8R7KP51 Download Play SETUP_CONFIG http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64.t...
2016/9/7:13:41:07 yasemin DESKTOP-8R7KP51 Download Complete SETUP_CONFIG http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64.t...
2016/9/7:13:41:07 yasemin DESKTOP-8R7KP51 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\yasemin\AppData\Local\Temp\_AI99DE.tmp\Setup\AcSetup.dll
2016/9/7:13:41:07 yasemin DESKTOP-8R7KP51 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/7:13:41:07 yasemin DESKTOP-8R7KP51 PageOpen LaunchDialog
2016/9/7:13:41:15 yasemin DESKTOP-8R7KP51 PageOpen LicenseDialog
2016/9/7:13:41:15 yasemin DESKTOP-8R7KP51 PageOpen ProductInfoDialog
2016/9/7:13:41:15 yasemin DESKTOP-8R7KP51 PageOpen ProductSelectionDialog2
2016/9/7:13:41:28 yasemin DESKTOP-8R7KP51 PageOpen FullProgressDialog
2016/9/7:13:41:29 yasemin DESKTOP-8R7KP51 Download Play STARTMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARKER...
2016/9/7:13:41:29 yasemin DESKTOP-8R7KP51 Download Complete STARTMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARKER...
2016/9/7:13:41:29 yasemin DESKTOP-8R7KP51 Download Play VCREDIST2008SP1X86 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST200...
2016/9/7:13:41:30 yasemin DESKTOP-8R7KP51 Download Complete VCREDIST2008SP1X86 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST200...
2016/9/7:13:41:30 yasemin DESKTOP-8R7KP51 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2016/9/7:13:41:38 yasemin DESKTOP-8R7KP51 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2016/9/7:13:41:39 yasemin DESKTOP-8R7KP51 Download Play VCREDIST2008SP1X64 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST200...
2016/9/7:13:41:40 yasemin DESKTOP-8R7KP51 Download Complete VCREDIST2008SP1X64 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST200...
2016/9/7:13:41:40 yasemin DESKTOP-8R7KP51 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2016/9/7:13:41:45 yasemin DESKTOP-8R7KP51 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2016/9/7:13:41:45 yasemin DESKTOP-8R7KP51 Download Play UCRT http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86.ta...
2016/9/7:13:41:46 yasemin DESKTOP-8R7KP51 Download Complete UCRT http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86.ta...
2016/9/7:13:41:46 yasemin DESKTOP-8R7KP51 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/9/7:13:41:46 yasemin DESKTOP-8R7KP51 Install Universal C Runtime (KB3118401) Succeeded
2016/9/7:13:41:46 yasemin DESKTOP-8R7KP51 Download Play VCREDIST2015X86 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/9/7:13:41:48 yasemin DESKTOP-8R7KP51 Download Complete VCREDIST2015X86 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/9/7:13:41:48 yasemin DESKTOP-8R7KP51 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\yasemin\AppData\Local\Temp\vcredist_x86_2015.log
2016/9/7:13:41:48 yasemin DESKTOP-8R7KP51 Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2016/9/7:13:41:49 yasemin DESKTOP-8R7KP51 Download Play VCREDIST2015X64 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/9/7:13:41:51 yasemin DESKTOP-8R7KP51 Download Complete VCREDIST2015X64 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/9/7:13:41:51 yasemin DESKTOP-8R7KP51 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\yasemin\AppData\Local\Temp\vcredist_x64_2015.log
2016/9/7:13:41:51 yasemin DESKTOP-8R7KP51 Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2016/9/7:13:41:51 yasemin DESKTOP-8R7KP51 Download Play DIRECTX http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.tar...
2016/9/7:13:41:54 yasemin DESKTOP-8R7KP51 Download Complete DIRECTX http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.tar...
2016/9/7:13:41:54 yasemin DESKTOP-8R7KP51 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/9/7:13:42:07 yasemin DESKTOP-8R7KP51 Install DirectX Runtime Succeeded
2016/9/7:13:42:07 yasemin DESKTOP-8R7KP51 Download Play CM http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lzma...
2016/9/7:13:42:34 yasemin DESKTOP-8R7KP51 Download Aborted CM http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lzma...
2016/9/7:13:42:34 yasemin DESKTOP-8R7KP51 Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2016/9/7:13:42:37 yasemin DESKTOP-8R7KP51 Rollback DirectX Runtime Failed Failure is ignored, Result=1618
2016/9/7:13:45:50 yasemin DESKTOP-8R7KP51 === Setup started on DESKTOP-8R7KP51 by yasemin ===
2016/9/7:13:45:50 yasemin DESKTOP-8R7KP51 Path_Length: 162
2016/9/7:13:45:50 yasemin DESKTOP-8R7KP51 Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2016/9/7:13:45:50 yasemin DESKTOP-8R7KP51 Launch
2016/9/7:13:45:50 yasemin DESKTOP-8R7KP51 CommandLine /akamai /sid SESSION_ID /skipEULA /trialMode /url "http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Setu..."
2016/9/7:13:45:50 yasemin DESKTOP-8R7KP51 Current Directory C:\Users\yasemin\AppData\Local\Temp\_AI3425.tmp
2016/9/7:13:45:53 yasemin DESKTOP-8R7KP51 === Setup ended ===
2016/9/7:13:45:51 yasemin DESKTOP-8R7KP51 === Setup started on DESKTOP-8R7KP51 by yasemin ===
2016/9/7:13:45:51 yasemin DESKTOP-8R7KP51 Path_Length: 162
2016/9/7:13:45:51 yasemin DESKTOP-8R7KP51 Current Directory C:\Users\yasemin\AppData\Local\Temp\_AI3425.tmp
2016/9/7:13:45:51 yasemin DESKTOP-8R7KP51 Launch
2016/9/7:13:45:51 yasemin DESKTOP-8R7KP51 Download Skipped SETUPMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARKER...
2016/9/7:13:45:51 yasemin DESKTOP-8R7KP51 Download Skipped SETUP_CONFIG http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64.t...
2016/9/7:13:45:51 yasemin DESKTOP-8R7KP51 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\yasemin\AppData\Local\Temp\_AI3425.tmp\Setup\AcSetup.dll
2016/9/7:13:45:51 yasemin DESKTOP-8R7KP51 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/7:13:45:52 yasemin DESKTOP-8R7KP51 PageOpen LaunchDialog
2016/9/7:13:45:59 yasemin DESKTOP-8R7KP51 PageOpen LicenseDialog
2016/9/7:13:45:59 yasemin DESKTOP-8R7KP51 PageOpen ProductInfoDialog
2016/9/7:13:45:59 yasemin DESKTOP-8R7KP51 PageOpen ProductSelectionDialog2
2016/9/7:13:46:01 yasemin DESKTOP-8R7KP51 PageOpen FullProgressDialog
2016/9/7:13:46:02 yasemin DESKTOP-8R7KP51 Download Play STARTMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARKER...
2016/9/7:13:46:02 yasemin DESKTOP-8R7KP51 Download Complete STARTMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARKER...
2016/9/7:13:46:02 yasemin DESKTOP-8R7KP51 Download Skipped UCRT http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86.ta...
2016/9/7:13:46:02 yasemin DESKTOP-8R7KP51 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/9/7:13:46:02 yasemin DESKTOP-8R7KP51 Install Universal C Runtime (KB3118401) Succeeded
2016/9/7:13:46:02 yasemin DESKTOP-8R7KP51 Download Skipped VCREDIST2015X86 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/9/7:13:46:02 yasemin DESKTOP-8R7KP51 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\yasemin\AppData\Local\Temp\vcredist_x86_2015.log
2016/9/7:13:46:03 yasemin DESKTOP-8R7KP51 Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2016/9/7:13:46:03 yasemin DESKTOP-8R7KP51 Download Skipped VCREDIST2015X64 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/9/7:13:46:03 yasemin DESKTOP-8R7KP51 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\yasemin\AppData\Local\Temp\vcredist_x64_2015.log
2016/9/7:13:46:04 yasemin DESKTOP-8R7KP51 Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2016/9/7:13:46:04 yasemin DESKTOP-8R7KP51 Download Skipped DIRECTX http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.tar...
2016/9/7:13:46:04 yasemin DESKTOP-8R7KP51 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/9/7:13:46:10 yasemin DESKTOP-8R7KP51 Install DirectX Runtime Succeeded
2016/9/7:13:46:10 yasemin DESKTOP-8R7KP51 Download Play CM http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lzma...
2016/9/7:13:46:37 yasemin DESKTOP-8R7KP51 Download Aborted CM http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lzma...
2016/9/7:13:46:37 yasemin DESKTOP-8R7KP51 Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2016/9/7:13:46:37 yasemin DESKTOP-8R7KP51 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/9/7:13:46:37 yasemin DESKTOP-8R7KP51 PageOpen InstallCompleteDialog
2016/9/7:13:46:42 yasemin DESKTOP-8R7KP51 === Setup ended ===
2016/9/7:13:48:17 yasemin DESKTOP-8R7KP51 === Setup started on DESKTOP-8R7KP51 by yasemin ===
2016/9/7:13:48:17 yasemin DESKTOP-8R7KP51 Path_Length: 162
2016/9/7:13:48:17 yasemin DESKTOP-8R7KP51 Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2016/9/7:13:48:17 yasemin DESKTOP-8R7KP51 Launch
2016/9/7:13:48:17 yasemin DESKTOP-8R7KP51 CommandLine /akamai /sid SESSION_ID /skipEULA /trialMode /url "http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Setu..."
2016/9/7:13:48:17 yasemin DESKTOP-8R7KP51 Current Directory C:\Users\yasemin\AppData\Local\Temp\_AI7079.tmp
2016/9/7:13:48:19 yasemin DESKTOP-8R7KP51 === Setup ended ===
2016/9/7:13:48:18 yasemin DESKTOP-8R7KP51 === Setup started on DESKTOP-8R7KP51 by yasemin ===
2016/9/7:13:48:18 yasemin DESKTOP-8R7KP51 Path_Length: 162
2016/9/7:13:48:18 yasemin DESKTOP-8R7KP51 Current Directory C:\Users\yasemin\AppData\Local\Temp\_AI7079.tmp
2016/9/7:13:48:18 yasemin DESKTOP-8R7KP51 Launch
2016/9/7:13:48:18 yasemin DESKTOP-8R7KP51 Download Skipped SETUPMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARKER...
2016/9/7:13:48:18 yasemin DESKTOP-8R7KP51 Download Skipped SETUP_CONFIG http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64.t...
2016/9/7:13:48:18 yasemin DESKTOP-8R7KP51 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\yasemin\AppData\Local\Temp\_AI7079.tmp\Setup\AcSetup.dll
2016/9/7:13:48:18 yasemin DESKTOP-8R7KP51 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/7:13:48:18 yasemin DESKTOP-8R7KP51 PageOpen LaunchDialog
2016/9/7:13:48:23 yasemin DESKTOP-8R7KP51 PageOpen LicenseDialog
2016/9/7:13:48:23 yasemin DESKTOP-8R7KP51 PageOpen ProductInfoDialog
2016/9/7:13:48:23 yasemin DESKTOP-8R7KP51 PageOpen ProductSelectionDialog2
2016/9/7:13:48:34 yasemin DESKTOP-8R7KP51 PageOpen FullProgressDialog
2016/9/7:13:48:35 yasemin DESKTOP-8R7KP51 Download Play STARTMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARKER...
2016/9/7:13:48:35 yasemin DESKTOP-8R7KP51 Download Complete STARTMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARKER...
2016/9/7:13:48:35 yasemin DESKTOP-8R7KP51 Download Skipped UCRT http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86.ta...
2016/9/7:13:48:35 yasemin DESKTOP-8R7KP51 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/9/7:13:48:35 yasemin DESKTOP-8R7KP51 Install Universal C Runtime (KB3118401) Succeeded
2016/9/7:13:48:35 yasemin DESKTOP-8R7KP51 Download Skipped VCREDIST2015X86 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/9/7:13:48:35 yasemin DESKTOP-8R7KP51 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\yasemin\AppData\Local\Temp\vcredist_x86_2015.log
2016/9/7:13:48:36 yasemin DESKTOP-8R7KP51 Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2016/9/7:13:48:36 yasemin DESKTOP-8R7KP51 Download Skipped VCREDIST2015X64 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/9/7:13:48:36 yasemin DESKTOP-8R7KP51 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\yasemin\AppData\Local\Temp\vcredist_x64_2015.log
2016/9/7:13:48:37 yasemin DESKTOP-8R7KP51 Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2016/9/7:13:48:37 yasemin DESKTOP-8R7KP51 Download Skipped DIRECTX http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.tar...
2016/9/7:13:48:37 yasemin DESKTOP-8R7KP51 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/9/7:13:48:41 yasemin DESKTOP-8R7KP51 Install DirectX Runtime Succeeded
2016/9/7:13:48:41 yasemin DESKTOP-8R7KP51 Download Play CM http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lzma...
2016/9/7:13:49:07 yasemin DESKTOP-8R7KP51 Download Aborted CM http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lzma...
2016/9/7:13:49:07 yasemin DESKTOP-8R7KP51 Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2016/9/7:13:49:07 yasemin DESKTOP-8R7KP51 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/9/7:13:49:07 yasemin DESKTOP-8R7KP51 PageOpen InstallCompleteDialog
2016/9/7:13:51:00 yasemin DESKTOP-8R7KP51 === Setup ended ===
2016/9/7:13:56:27 yasemin DESKTOP-8R7KP51 === Setup started on DESKTOP-8R7KP51 by yasemin ===
2016/9/7:13:56:27 yasemin DESKTOP-8R7KP51 Path_Length: 162
2016/9/7:13:56:27 yasemin DESKTOP-8R7KP51 Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2016/9/7:13:56:27 yasemin DESKTOP-8R7KP51 Launch
2016/9/7:13:56:27 yasemin DESKTOP-8R7KP51 CommandLine /akamai /sid SESSION_ID /skipEULA /trialMode /url "http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Setu..."
2016/9/7:13:56:27 yasemin DESKTOP-8R7KP51 Current Directory C:\Users\yasemin\AppData\Local\Temp\_AIEC2F.tmp
2016/9/7:13:56:29 yasemin DESKTOP-8R7KP51 === Setup ended ===
2016/9/7:13:56:28 yasemin DESKTOP-8R7KP51 === Setup started on DESKTOP-8R7KP51 by yasemin ===
2016/9/7:13:56:28 yasemin DESKTOP-8R7KP51 Path_Length: 162
2016/9/7:13:56:28 yasemin DESKTOP-8R7KP51 Current Directory C:\Users\yasemin\AppData\Local\Temp\_AIEC2F.tmp
2016/9/7:13:56:28 yasemin DESKTOP-8R7KP51 Launch
2016/9/7:13:56:28 yasemin DESKTOP-8R7KP51 Download Skipped SETUPMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARKER...
2016/9/7:13:56:28 yasemin DESKTOP-8R7KP51 Download Skipped SETUP_CONFIG http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64.t...
2016/9/7:13:56:28 yasemin DESKTOP-8R7KP51 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\yasemin\AppData\Local\Temp\_AIEC2F.tmp\Setup\AcSetup.dll
2016/9/7:13:56:28 yasemin DESKTOP-8R7KP51 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/7:13:56:28 yasemin DESKTOP-8R7KP51 PageOpen LaunchDialog
2016/9/7:13:56:33 yasemin DESKTOP-8R7KP51 PageOpen LicenseDialog
2016/9/7:13:56:33 yasemin DESKTOP-8R7KP51 PageOpen ProductInfoDialog
2016/9/7:13:56:33 yasemin DESKTOP-8R7KP51 PageOpen ProductSelectionDialog2
2016/9/7:13:56:34 yasemin DESKTOP-8R7KP51 PageOpen FullProgressDialog
2016/9/7:13:56:35 yasemin DESKTOP-8R7KP51 Download Play STARTMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARKER...
2016/9/7:13:56:35 yasemin DESKTOP-8R7KP51 Download Complete STARTMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARKER...
2016/9/7:13:56:35 yasemin DESKTOP-8R7KP51 Download Skipped VCREDIST2008SP1X86 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST200...
2016/9/7:13:56:35 yasemin DESKTOP-8R7KP51 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2016/9/7:13:56:44 yasemin DESKTOP-8R7KP51 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2016/9/7:13:56:44 yasemin DESKTOP-8R7KP51 WebInstaller2016/9/7:13:56:45 yasemin DESKTOP-8R7KP51 Download Skipped VCREDIST2008SP1X64 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST200...
2016/9/7:13:56:45 yasemin DESKTOP-8R7KP51 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2016/9/7:13:56:48 yasemin DESKTOP-8R7KP51 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2016/9/7:13:56:49 yasemin DESKTOP-8R7KP51 Download Play VCREDIST2010SP1X86 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/9/7:13:56:50 yasemin DESKTOP-8R7KP51 Download Complete VCREDIST2010SP1X86 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/9/7:13:56:50 yasemin DESKTOP-8R7KP51 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /l C:\Users\yasemin\AppData\Local\Temp\vcredist_x86_2010.log
2016/9/7:13:56:56 yasemin DESKTOP-8R7KP51 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2016/9/7:13:56:56 yasemin DESKTOP-8R7KP51 Download Play VCREDIST2010SP1X64 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/9/7:13:56:58 yasemin DESKTOP-8R7KP51 Download Complete VCREDIST2010SP1X64 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/9/7:13:56:58 yasemin DESKTOP-8R7KP51 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart /l C:\Users\yasemin\AppData\Local\Temp\vcredist_x64_2010.log
2016/9/7:13:57:03 yasemin DESKTOP-8R7KP51 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2016/9/7:13:57:03 yasemin DESKTOP-8R7KP51 Download Play VCREDIST2012X86UPD4 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/9/7:13:57:04 yasemin DESKTOP-8R7KP51 Download Complete VCREDIST2012X86UPD4 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/9/7:13:57:04 yasemin DESKTOP-8R7KP51 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\yasemin\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2016/9/7:13:57:06 yasemin DESKTOP-8R7KP51 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2016/9/7:13:57:07 yasemin DESKTOP-8R7KP51 Download Play VCREDIST2012X64UPD4 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/9/7:13:57:08 yasemin DESKTOP-8R7KP51 Download Complete VCREDIST2012X64UPD4 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/9/7:13:57:08 yasemin DESKTOP-8R7KP51 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\yasemin\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2016/9/7:13:57:10 yasemin DESKTOP-8R7KP51 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2016/9/7:13:57:10 yasemin DESKTOP-8R7KP51 Download Skipped UCRT http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86.ta...
2016/9/7:13:57:10 yasemin DESKTOP-8R7KP51 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/9/7:13:57:11 yasemin DESKTOP-8R7KP51 Install Universal C Runtime (KB3118401) Succeeded
2016/9/7:13:57:11 yasemin DESKTOP-8R7KP51 Download Skipped VCREDIST2015X86 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/9/7:13:57:11 yasemin DESKTOP-8R7KP51 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\yasemin\AppData\Local\Temp\vcredist_x86_2015.log
2016/9/7:13:57:11 yasemin DESKTOP-8R7KP51 Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2016/9/7:13:57:11 yasemin DESKTOP-8R7KP51 Download Skipped VCREDIST2015X64 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/9/7:13:57:11 yasemin DESKTOP-8R7KP51 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\yasemin\AppData\Local\Temp\vcredist_x64_2015.log
2016/9/7:13:57:12 yasemin DESKTOP-8R7KP51 Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2016/9/7:13:57:12 yasemin DESKTOP-8R7KP51 Download Skipped DIRECTX http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.tar...
2016/9/7:13:57:12 yasemin DESKTOP-8R7KP51 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/9/7:13:57:16 yasemin DESKTOP-8R7KP51 Install DirectX Runtime Succeeded
2016/9/7:13:57:16 yasemin DESKTOP-8R7KP51 Download Play CM http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lzma...
2016/9/7:13:57:42 yasemin DESKTOP-8R7KP51 Download Aborted CM http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lzma...
2016/9/7:13:57:42 yasemin DESKTOP-8R7KP51 Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2016/9/7:13:57:42 yasemin DESKTOP-8R7KP51 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/9/7:13:57:42 yasemin DESKTOP-8R7KP51 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2016/9/7:13:57:42 yasemin DESKTOP-8R7KP51 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2016/9/7:13:57:43 yasemin DESKTOP-8R7KP51 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2016/9/7:13:57:43 yasemin DESKTOP-8R7KP51 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2016/9/7:13:57:43 yasemin DESKTOP-8R7KP51 PageOpen InstallCompleteDialog
2016/9/7:14:03:22 yasemin DESKTOP-8R7KP51 === Setup ended ===
2016/9/7:14:04:56 yasemin DESKTOP-8R7KP51 === Setup started on DESKTOP-8R7KP51 by yasemin ===
2016/9/7:14:04:56 yasemin DESKTOP-8R7KP51 Path_Length: 162
2016/9/7:14:04:56 yasemin DESKTOP-8R7KP51 Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2016/9/7:14:04:56 yasemin DESKTOP-8R7KP51 Launch
2016/9/7:14:04:56 yasemin DESKTOP-8R7KP51 CommandLine /akamai /sid SESSION_ID /skipEULA /trialMode /url "http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Setu..."
2016/9/7:14:04:56 yasemin DESKTOP-8R7KP51 Current Directory C:\Users\yasemin\AppData\Local\Temp\_AIADE7.tmp
2016/9/7:14:04:58 yasemin DESKTOP-8R7KP51 === Setup ended ===
2016/9/7:14:04:56 yasemin DESKTOP-8R7KP51 Download Skipped SETUPMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARKER...
2016/9/7:14:04:56 yasemin DESKTOP-8R7KP51 Download Skipped SETUP_CONFIG http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64.t...
2016/9/7:14:04:56 yasemin DESKTOP-8R7KP51 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\yasemin\AppData\Local\Temp\_AIADE7.tmp\Setup\AcSetup.dll
2016/9/7:14:04:56 yasemin DESKTOP-8R7KP51 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/7:14:04:57 yasemin DESKTOP-8R7KP51 PageOpen LaunchDialog
2016/9/7:14:05:02 yasemin DESKTOP-8R7KP51 PageOpen LicenseDialog
2016/9/7:14:05:02 yasemin DESKTOP-8R7KP51 PageOpen ProductInfoDialog
2016/9/7:14:05:02 yasemin DESKTOP-8R7KP51 PageOpen ProductSelectionDialog2
2016/9/7:14:05:04 yasemin DESKTOP-8R7KP51 PageOpen FullProgressDialog
2016/9/7:14:05:05 yasemin DESKTOP-8R7KP51 Download Play STARTMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARKER...
2016/9/7:14:05:05 yasemin DESKTOP-8R7KP51 Download Complete STARTMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARKER...
2016/9/7:14:05:05 yasemin DESKTOP-8R7KP51 Download Skipped VCREDIST2008SP1X86 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST200...
2016/9/7:14:05:05 yasemin DESKTOP-8R7KP51 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2016/9/7:14:05:08 yasemin DESKTOP-8R7KP51 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2016/9/7:14:05:08 yasemin DESKTOP-8R7KP51 Download Skipped VCREDIST2008SP1X64 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST200...
2016/9/7:14:05:08 yasemin DESKTOP-8R7KP51 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2016/9/7:14:05:11 yasemin DESKTOP-8R7KP51 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2016/9/7:14:05:11 yasemin DESKTOP-8R7KP51 Download Skipped VCREDIST2010SP1X86 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/9/7:14:05:11 yasemin DESKTOP-8R7KP51 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /l C:\Users\yasemin\AppData\Local\Temp\vcredist_x86_2010.log
2016/9/7:14:05:15 yasemin DESKTOP-8R7KP51 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2016/9/7:14:05:15 yasemin DESKTOP-8R7KP51 Download Skipped VCREDIST2010SP1X64 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/9/7:14:05:15 yasemin DESKTOP-8R7KP51 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart /l C:\Users\yasemin\AppData\Local\Temp\vcredist_x64_2010.log
2016/9/7:14:05:21 yasemin DESKTOP-8R7KP51 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2016/9/7:14:05:21 yasemin DESKTOP-8R7KP51 Download Skipped VCREDIST2012X86UPD4 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/9/7:14:05:21 yasemin DESKTOP-8R7KP51 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\yasemin\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2016/9/7:14:05:22 yasemin DESKTOP-8R7KP51 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2016/9/7:14:05:23 yasemin DESKTOP-8R7KP51 Download Skipped VCREDIST2012X64UPD4 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/9/7:14:05:23 yasemin DESKTOP-8R7KP51 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\yasemin\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2016/9/7:14:05:25 yasemin DESKTOP-8R7KP51 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2016/9/7:14:05:25 yasemin DESKTOP-8R7KP51 Download Skipped UCRT http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86.ta...
2016/9/7:14:05:25 yasemin DESKTOP-8R7KP51 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/9/7:14:05:25 yasemin DESKTOP-8R7KP51 Install Universal C Runtime (KB3118401) Succeeded
2016/9/7:14:05:25 yasemin DESKTOP-8R7KP51 Download Skipped VCREDIST2015X86 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/9/7:14:05:25 yasemin DESKTOP-8R7KP51 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\yasemin\AppData\Local\Temp\vcredist_x86_2015.log
2016/9/7:14:05:27 yasemin DESKTOP-8R7KP51 Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2016/9/7:14:05:27 yasemin DESKTOP-8R7KP51 Download Skipped VCREDIST2015X64 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2016/9/7:14:05:27 yasemin DESKTOP-8R7KP51 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\yasemin\AppData\Local\Temp\vcredist_x64_2015.log
2016/9/7:14:05:28 yasemin DESKTOP-8R7KP51 Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2016/9/7:14:05:28 yasemin DESKTOP-8R7KP51 Download Skipped DIRECTX http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.tar...
2016/9/7:14:05:29 yasemin DESKTOP-8R7KP51 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/9/7:14:05:33 yasemin DESKTOP-8R7KP51 Install DirectX Runtime Succeeded
2016/9/7:14:05:33 yasemin DESKTOP-8R7KP51 Download Play CM http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lzma...
2016/9/7:14:05:59 yasemin DESKTOP-8R7KP51 Download Aborted CM http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lzma...
2016/9/7:14:05:59 yasemin DESKTOP-8R7KP51 Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2016/9/7:14:05:59 yasemin DESKTOP-8R7KP51 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
How can I solve this?
@Anonymous
Your installation is failing due to the method you're using...
Download and install per:
1. Access the Autodesk Virtual Agent (link is in my signature) and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
Good luck on your installation.
Mark Lancaster
2016/11/12:16:42:43 lkori DESKTOP-PDJH4R3 === Setup started on DESKTOP-PDJH4R3 by lkori ===
2016/11/12:16:42:43 lkori DESKTOP-PDJH4R3 Path_Length: 155
2016/11/12:16:42:43 lkori DESKTOP-PDJH4R3 Current Directory C:\Users\lkori\AppData\Local\Temp\_AI9F8A.tmp
2016/11/12:16:42:43 lkori DESKTOP-PDJH4R3 Launch
2016/11/12:17:11:22 lkori DESKTOP-PDJH4R3 Download Play SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUPMARK...
2016/11/12:17:11:25 lkori DESKTOP-PDJH4R3 Download Complete SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUPMARK...
2016/11/12:17:11:25 lkori DESKTOP-PDJH4R3 Error downloading. Please Install Now again from the Autodesk website. 2016/11/12:17:11:30 lkori DESKTOP-PDJH4R3 === Setup ended ===
2016/11/12:16:42:42 lkori DESKTOP-PDJH4R3 === Setup started on DESKTOP-PDJH4R3 by lkori ===
2016/11/12:16:42:42 lkori DESKTOP-PDJH4R3 Path_Length: 155
2016/11/12:16:42:42 lkori DESKTOP-PDJH4R3 Current Directory C:\Autodesk\Revit_2017_G1_Win_64bit_wi_en-US
2016/11/12:16:42:42 lkori DESKTOP-PDJH4R3 Launch
2016/11/12:16:42:42 lkori DESKTOP-PDJH4R3 CommandLine /PK 829I1 /SN 900-43923408 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/Revit_2017_G1_Win_64bit_wi_en-US_Setup.exe?dummy..."
2016/11/12:16:42:42 lkori DESKTOP-PDJH4R3 Current Directory C:\Users\lkori\AppData\Local\Temp\_AI9F8A.tmp
2016/11/12:17:24:21 lkori DESKTOP-PDJH4R3 === Setup started on DESKTOP-PDJH4R3 by lkori ===
2016/11/12:17:24:21 lkori DESKTOP-PDJH4R3 Path_Length: 155
2016/11/12:17:24:21 lkori DESKTOP-PDJH4R3 Current Directory C:\Autodesk\Revit_2017_G1_Win_64bit_wi_en-US
2016/11/12:17:24:21 lkori DESKTOP-PDJH4R3 Launch
2016/11/12:17:24:21 lkori DESKTOP-PDJH4R3 CommandLine /PK 829I1 /SN 900-43923408 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/Revit_2017_G1_Win_64bit_wi_en-US_Setup.exe?dummy..."
2016/11/12:17:24:21 lkori DESKTOP-PDJH4R3 Current Directory C:\Users\lkori\AppData\Local\Temp\_AI14B8.tmp
2016/11/12:17:26:17 lkori DESKTOP-PDJH4R3 === Setup ended ===
2016/11/12:17:24:24 lkori DESKTOP-PDJH4R3 === Setup started on DESKTOP-PDJH4R3 by lkori ===
2016/11/12:17:24:24 lkori DESKTOP-PDJH4R3 Path_Length: 155
2016/11/12:17:24:24 lkori DESKTOP-PDJH4R3 Current Directory C:\Users\lkori\AppData\Local\Temp\_AI14B8.tmp
2016/11/12:17:24:24 lkori DESKTOP-PDJH4R3 Launch
2016/11/12:17:25:58 lkori DESKTOP-PDJH4R3 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUPMARK...
2016/11/12:17:25:58 lkori DESKTOP-PDJH4R3 Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP_x64...
2016/11/12:17:26:15 lkori DESKTOP-PDJH4R3 Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP_x64...
2016/11/12:17:26:15 lkori DESKTOP-PDJH4R3 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\lkori\AppData\Local\Temp\_AI14B8.tmp\Setup\RevitSetup.dll
2016/11/12:17:26:15 lkori DESKTOP-PDJH4R3 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/11/12:17:26:20 lkori DESKTOP-PDJH4R3 PageOpen LaunchDialog
2016/11/12:17:26:34 lkori DESKTOP-PDJH4R3 Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\lkori\AppData\Local\Temp\_AI14B8.tmp\Setup\RevitSetup.dll
2016/11/12:17:26:34 lkori DESKTOP-PDJH4R3 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2017. URLTitle= URLLink=
2016/11/12:17:27:30 lkori DESKTOP-PDJH4R3 PageOpen LicenseDialog
2016/11/12:17:27:30 lkori DESKTOP-PDJH4R3 PageOpen ProductInfoDialog
2016/11/12:17:27:30 lkori DESKTOP-PDJH4R3 PageOpen ProductSelectionDialog2
2016/11/12:17:27:45 lkori DESKTOP-PDJH4R3 PageOpen FullProgressDialog
2016/11/12:17:27:46 lkori DESKTOP-PDJH4R3 Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/STARTMARK...
2016/11/12:17:27:46 lkori DESKTOP-PDJH4R3 Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/STARTMARK...
2016/11/12:17:27:46 lkori DESKTOP-PDJH4R3 Download Play VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCREDIST2...
2016/11/12:17:27:47 lkori DESKTOP-PDJH4R3 Download Complete VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCREDIST2...
2016/11/12:17:27:47 lkori DESKTOP-PDJH4R3 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2017\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2016/11/12:17:27:55 lkori DESKTOP-PDJH4R3 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2016/11/12:17:27:56 lkori DESKTOP-PDJH4R3 Download Play VCREDIST2008SP1X64_6161 http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCREDIST2...
2016/11/12:17:27:57 lkori DESKTOP-PDJH4R3 Download Complete VCREDIST2008SP1X64_6161 http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCREDIST2...
2016/11/12:17:27:57 lkori DESKTOP-PDJH4R3 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "C:\Autodesk\WI\Autodesk Revit 2017\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q
2016/11/12:17:28:02 lkori DESKTOP-PDJH4R3 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Failed Installation aborted, Result=1603
2016/11/12:17:28:02 lkori DESKTOP-PDJH4R3 PageOpen InstallCompleteDialog
2016/11/12:17:28:53 lkori DESKTOP-PDJH4R3 === Setup ended ===
2016/11/12:17:34:25 lkori DESKTOP-PDJH4R3 === Setup started on DESKTOP-PDJH4R3 by lkori ===
2016/11/12:17:34:25 lkori DESKTOP-PDJH4R3 Path_Length: 155
2016/11/12:17:34:25 lkori DESKTOP-PDJH4R3 Current Directory C:\Autodesk\Revit_2017_G1_Win_64bit_wi_en-US
2016/11/12:17:34:25 lkori DESKTOP-PDJH4R3 Launch
2016/11/12:17:34:25 lkori DESKTOP-PDJH4R3 CommandLine /PK 829I1 /SN 900-43923408 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/Revit_2017_G1_Win_64bit_wi_en-US_Setup.exe?dummy..."
2016/11/12:17:34:25 lkori DESKTOP-PDJH4R3 Current Directory C:\Users\lkori\AppData\Local\Temp\_AID01C.tmp
2016/11/12:17:34:27 lkori DESKTOP-PDJH4R3 === Setup ended ===
2016/11/12:17:34:26 lkori DESKTOP-PDJH4R3 === Setup started on DESKTOP-PDJH4R3 by lkori ===
2016/11/12:17:34:26 lkori DESKTOP-PDJH4R3 Path_Length: 155
2016/11/12:17:34:26 lkori DESKTOP-PDJH4R3 Current Directory C:\Users\lkori\AppData\Local\Temp\_AID01C.tmp
2016/11/12:17:34:26 lkori DESKTOP-PDJH4R3 Launch
2016/11/12:17:34:26 lkori DESKTOP-PDJH4R3 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUPMARK...
2016/11/12:17:34:26 lkori DESKTOP-PDJH4R3 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP_x64...
2016/11/12:17:34:26 lkori DESKTOP-PDJH4R3 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\lkori\AppData\Local\Temp\_AID01C.tmp\Setup\RevitSetup.dll
2016/11/12:17:34:26 lkori DESKTOP-PDJH4R3 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/11/12:17:34:27 lkori DESKTOP-PDJH4R3 PageOpen LaunchDialog
2016/11/12:17:34:49 lkori DESKTOP-PDJH4R3 Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\lkori\AppData\Local\Temp\_AID01C.tmp\Setup\RevitSetup.dll
2016/11/12:17:34:49 lkori DESKTOP-PDJH4R3 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2017. URLTitle= URLLink=
2016/11/12:17:35:35 lkori DESKTOP-PDJH4R3 PageOpen LicenseDialog
2016/11/12:17:35:35 lkori DESKTOP-PDJH4R3 PageOpen ProductInfoDialog
2016/11/12:17:35:35 lkori DESKTOP-PDJH4R3 PageOpen ProductSelectionDialog2
2016/11/12:17:35:59 lkori DESKTOP-PDJH4R3 PageOpen FullProgressDialog
2016/11/12:17:36:00 lkori DESKTOP-PDJH4R3 Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/STARTMARK...
2016/11/12:17:36:00 lkori DESKTOP-PDJH4R3 Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/STARTMARK...
2016/11/12:17:36:00 lkori DESKTOP-PDJH4R3 Download Skipped VCREDIST2008SP1X64_6161 http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCREDIST2...
2016/11/12:17:36:00 lkori DESKTOP-PDJH4R3 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "C:\Autodesk\WI\Autodesk Revit 2017\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q
2016/11/12:17:36:06 lkori DESKTOP-PDJH4R3 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Failed Installation aborted, Result=1603
2016/11/12:17:36:07 lkori DESKTOP-PDJH4R3 PageOpen InstallCompleteDialog
2016/11/12:17:40:53 lkori DESKTOP-PDJH4R3 === Setup ended ===
2016/11/12:18:22:30 lkori DESKTOP-PDJH4R3 === Setup started on DESKTOP-PDJH4R3 by lkori ===
2016/11/12:18:22:30 lkori DESKTOP-PDJH4R3 Path_Length: 155
2016/11/12:18:22:30 lkori DESKTOP-PDJH4R3 Current Directory C:\Autodesk\Revit_2017_G1_Win_64bit_wi_en-US
2016/11/12:18:22:30 lkori DESKTOP-PDJH4R3 Launch
2016/11/12:18:22:30 lkori DESKTOP-PDJH4R3 CommandLine /PK 829I1 /SN 900-43923408 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/Revit_2017_G1_Win_64bit_wi_en-US_Setup.exe?dummy..."
2016/11/12:18:22:30 lkori DESKTOP-PDJH4R3 Current Directory C:\Users\lkori\AppData\Local\Temp\_AI40D.tmp
2016/11/12:18:22:32 lkori DESKTOP-PDJH4R3 === Setup ended ===
2016/11/12:18:22:31 lkori DESKTOP-PDJH4R3 === Setup started on DESKTOP-PDJH4R3 by lkori ===
2016/11/12:18:22:31 lkori DESKTOP-PDJH4R3 Path_Length: 155
2016/11/12:18:22:31 lkori DESKTOP-PDJH4R3 Current Directory C:\Users\lkori\AppData\Local\Temp\_AI40D.tmp
2016/11/12:18:22:31 lkori DESKTOP-PDJH4R3 Launch
2016/11/12:18:22:32 lkori DESKTOP-PDJH4R3 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUPMARK...
2016/11/12:18:22:32 lkori DESKTOP-PDJH4R3 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP_x64...
2016/11/12:18:22:32 lkori DESKTOP-PDJH4R3 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\lkori\AppData\Local\Temp\_AI40D.tmp\Setup\RevitSetup.dll
2016/11/12:18:22:32 lkori DESKTOP-PDJH4R3 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/11/12:18:22:33 lkori DESKTOP-PDJH4R3 PageOpen LaunchDialog
2016/11/12:18:22:50 lkori DESKTOP-PDJH4R3 Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\lkori\AppData\Local\Temp\_AI40D.tmp\Setup\RevitSetup.dll
2016/11/12:18:22:50 lkori DESKTOP-PDJH4R3 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2017. URLTitle= URLLink=
2016/11/12:18:23:41 lkori DESKTOP-PDJH4R3 PageOpen LicenseDialog
2016/11/12:18:23:41 lkori DESKTOP-PDJH4R3 PageOpen ProductInfoDialog
2016/11/12:18:23:41 lkori DESKTOP-PDJH4R3 PageOpen ProductSelectionDialog2
2016/11/12:18:23:45 lkori DESKTOP-PDJH4R3 PageOpen FullProgressDialog
2016/11/12:18:23:46 lkori DESKTOP-PDJH4R3 Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/STARTMARK...
2016/11/12:18:23:46 lkori DESKTOP-PDJH4R3 Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/STARTMARK...
2016/11/12:18:23:46 lkori DESKTOP-PDJH4R3 Download Skipped VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCREDIST2...
2016/11/12:18:23:46 lkori DESKTOP-PDJH4R3 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2017\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2016/11/12:18:23:50 lkori DESKTOP-PDJH4R3 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2016/11/12:18:23:50 lkori DESKTOP-PDJH4R3 Download Skipped VCREDIST2008SP1X64_6161 http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCREDIST2...
2016/11/12:18:23:50 lkori DESKTOP-PDJH4R3 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "C:\Autodesk\WI\Autodesk Revit 2017\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q
2016/11/12:18:23:58 lkori DESKTOP-PDJH4R3 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Failed Installation aborted, Result=1603
2016/11/12:18:23:58 lkori DESKTOP-PDJH4R3 PageOpen InstallCompleteDialog
2016/11/12:18:24:21 lkori DESKTOP-PDJH4R3 === Setup ended ===
2016/11/12:18:26:56 lkori DESKTOP-PDJH4R3 === Setup started on DESKTOP-PDJH4R3 by lkori ===
2016/11/12:18:26:56 lkori DESKTOP-PDJH4R3 Path_Length: 155
2016/11/12:18:26:56 lkori DESKTOP-PDJH4R3 Current Directory C:\Autodesk\Revit_2017_G1_Win_64bit_wi_en-US
2016/11/12:18:26:56 lkori DESKTOP-PDJH4R3 Launch
2016/11/12:18:26:56 lkori DESKTOP-PDJH4R3 CommandLine /PK 829I1 /SN 900-43923408 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/Revit_2017_G1_Win_64bit_wi_en-US_Setup.exe?dummy..."
2016/11/12:18:26:56 lkori DESKTOP-PDJH4R3 Current Directory C:\Users\lkori\AppData\Local\Temp\_AIF363.tmp
2016/11/12:18:26:58 lkori DESKTOP-PDJH4R3 === Setup ended ===
2016/11/12:18:26:57 lkori DESKTOP-PDJH4R3 === Setup started on DESKTOP-PDJH4R3 by lkori ===
2016/11/12:18:26:57 lkori DESKTOP-PDJH4R3 Path_Length: 155
2016/11/12:18:26:57 lkori DESKTOP-PDJH4R3 Current Directory C:\Users\lkori\AppData\Local\Temp\_AIF363.tmp
2016/11/12:18:26:57 lkori DESKTOP-PDJH4R3 Launch
2016/11/12:18:26:57 lkori DESKTOP-PDJH4R3 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUPMARK...
2016/11/12:18:26:57 lkori DESKTOP-PDJH4R3 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP_x64...
2016/11/12:18:26:57 lkori DESKTOP-PDJH4R3 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\lkori\AppData\Local\Temp\_AIF363.tmp\Setup\RevitSetup.dll
2016/11/12:18:26:57 lkori DESKTOP-PDJH4R3 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/11/12:18:26:58 lkori DESKTOP-PDJH4R3 PageOpen LaunchDialog
2016/11/12:18:27:16 lkori DESKTOP-PDJH4R3 Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\lkori\AppData\Local\Temp\_AIF363.tmp\Setup\RevitSetup.dll
2016/11/12:18:27:16 lkori DESKTOP-PDJH4R3 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2017. URLTitle= URLLink=
2016/11/12:18:28:09 lkori DESKTOP-PDJH4R3 PageOpen LicenseDialog
2016/11/12:18:28:09 lkori DESKTOP-PDJH4R3 PageOpen ProductInfoDialog
2016/11/12:18:28:09 lkori DESKTOP-PDJH4R3 PageOpen ProductSelectionDialog2
2016/11/12:18:28:13 lkori DESKTOP-PDJH4R3 PageOpen FullProgressDialog
2016/11/12:18:28:14 lkori DESKTOP-PDJH4R3 Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/STARTMARK...
2016/11/12:18:28:14 lkori DESKTOP-PDJH4R3 Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/STARTMARK...
2016/11/12:18:28:14 lkori DESKTOP-PDJH4R3 Download Skipped VCREDIST2008SP1X64_6161 http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCREDIST2...
2016/11/12:18:28:14 lkori DESKTOP-PDJH4R3 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "C:\Autodesk\WI\Autodesk Revit 2017\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q
2016/11/12:18:28:21 lkori DESKTOP-PDJH4R3 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Failed Installation aborted, Result=1603
Failure installing Revit 2017. Any ideas of what could be wrong?
this my log:
2017/2/25:16:30:42 Rein Vanitaz DESKTOP-B336GFR Download Complete VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2017/2/25:16:30:42 Rein Vanitaz DESKTOP-B336GFR Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\REINVA~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/2/25:16:30:42 Rein Vanitaz DESKTOP-B336GFR Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2017/2/25:16:30:43 Rein Vanitaz DESKTOP-B336GFR Download Play VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2017/2/25:16:30:48 Rein Vanitaz DESKTOP-B336GFR Download Complete VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2017/2/25:16:30:48 Rein Vanitaz DESKTOP-B336GFR Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\REINVA~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/2/25:16:30:49 Rein Vanitaz DESKTOP-B336GFR Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2017/2/25:16:30:49 Rein Vanitaz DESKTOP-B336GFR Download Play DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2017/2/25:16:30:55 Rein Vanitaz DESKTOP-B336GFR Download Complete DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2017/2/25:16:30:55 Rein Vanitaz DESKTOP-B336GFR Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2017/2/25:16:30:59 Rein Vanitaz DESKTOP-B336GFR Install DirectX Runtime Succeeded
2017/2/25:16:30:59 Rein Vanitaz DESKTOP-B336GFR Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2017/2/25:16:32:40 Rein Vanitaz DESKTOP-B336GFR Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2017/2/25:16:32:40 Rein Vanitaz DESKTOP-B336GFR Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2017/2/25:16:32:40 Rein Vanitaz DESKTOP-B336GFR Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/2/25:16:32:40 Rein Vanitaz DESKTOP-B336GFR Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2017/2/25:16:32:41 Rein Vanitaz DESKTOP-B336GFR Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2017/2/25:16:32:41 Rein Vanitaz DESKTOP-B336GFR Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2017/2/25:16:32:41 Rein Vanitaz DESKTOP-B336GFR Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2017/2/25:16:32:41 Rein Vanitaz DESKTOP-B336GFR PageOpen InstallCompleteDialog
2017/2/25:16:33:02 Rein Vanitaz DESKTOP-B336GFR === Setup ended ===
2017/2/25:16:34:26 Rein Vanitaz DESKTOP-B336GFR === Setup started on DESKTOP-B336GFR by Rein Vanitaz ===
2017/2/25:16:34:26 Rein Vanitaz DESKTOP-B336GFR Path_Length: 162
2017/2/25:16:34:26 Rein Vanitaz DESKTOP-B336GFR Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2017/2/25:16:34:26 Rein Vanitaz DESKTOP-B336GFR Launch
2017/2/25:16:34:26 Rein Vanitaz DESKTOP-B336GFR CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Se..."
2017/2/25:16:34:26 Rein Vanitaz DESKTOP-B336GFR Current Directory C:\Users\REINVA~1\AppData\Local\Temp\_AI8A7F.tmp
2017/2/25:16:34:28 Rein Vanitaz DESKTOP-B336GFR === Setup ended ===
2017/2/25:16:34:27 Rein Vanitaz DESKTOP-B336GFR === Setup started on DESKTOP-B336GFR by Rein Vanitaz ===
2017/2/25:16:34:27 Rein Vanitaz DESKTOP-B336GFR Path_Length: 162
2017/2/25:16:34:27 Rein Vanitaz DESKTOP-B336GFR Current Directory C:\Users\REINVA~1\AppData\Local\Temp\_AI8A7F.tmp
2017/2/25:16:34:27 Rein Vanitaz DESKTOP-B336GFR Launch
2017/2/25:16:34:27 Rein Vanitaz DESKTOP-B336GFR Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2017/2/25:16:34:27 Rein Vanitaz DESKTOP-B336GFR Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2017/2/25:16:34:27 Rein Vanitaz DESKTOP-B336GFR Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\REINVA~1\AppData\Local\Temp\_AI8A7F.tmp\Setup\AcSetup.dll
2017/2/25:16:34:27 Rein Vanitaz DESKTOP-B336GFR Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/2/25:16:34:28 Rein Vanitaz DESKTOP-B336GFR PageOpen LaunchDialog
2017/2/25:16:34:30 Rein Vanitaz DESKTOP-B336GFR PageOpen LicenseDialog
2017/2/25:16:34:30 Rein Vanitaz DESKTOP-B336GFR PageOpen ProductSelectionDialog2
2017/2/25:16:34:38 Rein Vanitaz DESKTOP-B336GFR PageOpen LicenseDialog
2017/2/25:16:34:38 Rein Vanitaz DESKTOP-B336GFR PageOpen LaunchDialog
2017/2/25:16:34:42 Rein Vanitaz DESKTOP-B336GFR PageOpen LicenseDialog
2017/2/25:16:34:42 Rein Vanitaz DESKTOP-B336GFR PageOpen ProductInfoDialog
2017/2/25:16:34:42 Rein Vanitaz DESKTOP-B336GFR PageOpen ProductSelectionDialog2
2017/2/25:16:34:59 Rein Vanitaz DESKTOP-B336GFR PageOpen FullProgressDialog
2017/2/25:16:34:59 Rein Vanitaz DESKTOP-B336GFR Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2017/2/25:16:35:00 Rein Vanitaz DESKTOP-B336GFR Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2017/2/25:16:35:00 Rein Vanitaz DESKTOP-B336GFR Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2017/2/25:16:35:00 Rein Vanitaz DESKTOP-B336GFR Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/2/25:16:35:00 Rein Vanitaz DESKTOP-B336GFR Install Universal C Runtime (KB3118401) Succeeded
2017/2/25:16:35:00 Rein Vanitaz DESKTOP-B336GFR Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2017/2/25:16:35:00 Rein Vanitaz DESKTOP-B336GFR Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\REINVA~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/2/25:16:35:00 Rein Vanitaz DESKTOP-B336GFR Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2017/2/25:16:35:00 Rein Vanitaz DESKTOP-B336GFR Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2017/2/25:16:35:00 Rein Vanitaz DESKTOP-B336GFR Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\REINVA~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/2/25:16:35:01 Rein Vanitaz DESKTOP-B336GFR Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2017/2/25:16:35:01 Rein Vanitaz DESKTOP-B336GFR Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2017/2/25:16:35:01 Rein Vanitaz DESKTOP-B336GFR Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2017/2/25:16:35:04 Rein Vanitaz DESKTOP-B336GFR Install DirectX Runtime Succeeded
2017/2/25:16:35:05 Rein Vanitaz DESKTOP-B336GFR Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2017/2/25:16:36:44 Rein Vanitaz DESKTOP-B336GFR Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2017/2/25:16:36:44 Rein Vanitaz DESKTOP-B336GFR Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2017/2/25:16:36:44 Rein Vanitaz DESKTOP-B336GFR Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/2/25:16:36:44 Rein Vanitaz DESKTOP-B336GFR PageOpen InstallCompleteDialog
2017/2/25:16:37:28 Rein Vanitaz DESKTOP-B336GFR === Setup ended ===
2017/2/25:16:38:16 Rein Vanitaz DESKTOP-B336GFR === Setup started on DESKTOP-B336GFR by Rein Vanitaz ===
2017/2/25:16:38:16 Rein Vanitaz DESKTOP-B336GFR Path_Length: 162
2017/2/25:16:38:16 Rein Vanitaz DESKTOP-B336GFR Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2017/2/25:16:38:16 Rein Vanitaz DESKTOP-B336GFR Launch
2017/2/25:16:38:16 Rein Vanitaz DESKTOP-B336GFR CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Se..."
2017/2/25:16:38:16 Rein Vanitaz DESKTOP-B336GFR Current Directory C:\Users\REINVA~1\AppData\Local\Temp\_AIB39.tmp
2017/2/25:16:38:18 Rein Vanitaz DESKTOP-B336GFR === Setup ended ===
2017/2/25:16:38:17 Rein Vanitaz DESKTOP-B336GFR Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2017/2/25:16:38:17 Rein Vanitaz DESKTOP-B336GFR Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2017/2/25:16:38:17 Rein Vanitaz DESKTOP-B336GFR Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\REINVA~1\AppData\Local\Temp\_AIB39.tmp\Setup\AcSetup.dll
2017/2/25:16:38:17 Rein Vanitaz DESKTOP-B336GFR Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/2/25:16:38:17 Rein Vanitaz DESKTOP-B336GFR PageOpen LaunchDialog
2017/2/25:16:38:49 Rein Vanitaz DESKTOP-B336GFR === Setup ended ===
2017/2/25:16:40:50 Rein Vanitaz DESKTOP-B336GFR === Setup started on DESKTOP-B336GFR by Rein Vanitaz ===
2017/2/25:16:40:50 Rein Vanitaz DESKTOP-B336GFR Path_Length: 162
2017/2/25:16:40:50 Rein Vanitaz DESKTOP-B336GFR Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2017/2/25:16:40:50 Rein Vanitaz DESKTOP-B336GFR Launch
2017/2/25:16:40:50 Rein Vanitaz DESKTOP-B336GFR CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Se..."
2017/2/25:16:40:50 Rein Vanitaz DESKTOP-B336GFR Current Directory C:\Users\REINVA~1\AppData\Local\Temp\_AI672A.tmp
2017/2/25:16:40:53 Rein Vanitaz DESKTOP-B336GFR === Setup ended ===
2017/2/25:16:40:52 Rein Vanitaz DESKTOP-B336GFR === Setup started on DESKTOP-B336GFR by Rein Vanitaz ===
2017/2/25:16:40:52 Rein Vanitaz DESKTOP-B336GFR Path_Length: 162
2017/2/25:16:40:52 Rein Vanitaz DESKTOP-B336GFR Current Directory C:\Users\REINVA~1\AppData\Local\Temp\_AI672A.tmp
2017/2/25:16:40:52 Rein Vanitaz DESKTOP-B336GFR Launch
2017/2/25:16:40:52 Rein Vanitaz DESKTOP-B336GFR Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2017/2/25:16:40:52 Rein Vanitaz DESKTOP-B336GFR Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2017/2/25:16:40:52 Rein Vanitaz DESKTOP-B336GFR Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\REINVA~1\AppData\Local\Temp\_AI672A.tmp\Setup\AcSetup.dll
2017/2/25:16:40:52 Rein Vanitaz DESKTOP-B336GFR Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/2/25:16:40:52 Rein Vanitaz DESKTOP-B336GFR PageOpen LaunchDialog
2017/2/25:16:40:58 Rein Vanitaz DESKTOP-B336GFR PageOpen LicenseDialog
2017/2/25:16:40:58 Rein Vanitaz DESKTOP-B336GFR PageOpen ProductInfoDialog
2017/2/25:16:40:58 Rein Vanitaz DESKTOP-B336GFR PageOpen ProductSelectionDialog2
2017/2/25:16:41:18 Rein Vanitaz DESKTOP-B336GFR PageOpen FullProgressDialog
2017/2/25:16:41:19 Rein Vanitaz DESKTOP-B336GFR Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2017/2/25:16:41:19 Rein Vanitaz DESKTOP-B336GFR Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2017/2/25:16:41:19 Rein Vanitaz DESKTOP-B336GFR Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2017/2/25:16:41:19 Rein Vanitaz DESKTOP-B336GFR Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/2/25:16:41:19 Rein Vanitaz DESKTOP-B336GFR Install Universal C Runtime (KB3118401) Succeeded
2017/2/25:16:41:19 Rein Vanitaz DESKTOP-B336GFR Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2017/2/25:16:41:19 Rein Vanitaz DESKTOP-B336GFR Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\REINVA~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/2/25:16:41:20 Rein Vanitaz DESKTOP-B336GFR Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2017/2/25:16:41:20 Rein Vanitaz DESKTOP-B336GFR Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2017/2/25:16:41:20 Rein Vanitaz DESKTOP-B336GFR Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\REINVA~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/2/25:16:41:20 Rein Vanitaz DESKTOP-B336GFR Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2017/2/25:16:41:20 Rein Vanitaz DESKTOP-B336GFR Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2017/2/25:16:41:21 Rein Vanitaz DESKTOP-B336GFR Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2017/2/25:16:41:25 Rein Vanitaz DESKTOP-B336GFR Install DirectX Runtime Succeeded
2017/2/25:16:41:25 Rein Vanitaz DESKTOP-B336GFR Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2017/2/25:16:41:40 Rein Vanitaz DESKTOP-B336GFR Download User Pause CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2017/2/25:16:41:40 Rein Vanitaz DESKTOP-B336GFR Download Paused CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2017/2/25:16:41:42 Rein Vanitaz DESKTOP-B336GFR Download User Cancel CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2017/2/25:16:41:42 Rein Vanitaz DESKTOP-B336GFR Download Play CANCELMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CANCELMAR...
2017/2/25:16:41:42 Rein Vanitaz DESKTOP-B336GFR Download Complete CANCELMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CANCELMAR...
2017/2/25:16:41:42 Rein Vanitaz DESKTOP-B336GFR PageOpen InstallCompleteDialog
2017/2/25:16:41:45 Rein Vanitaz DESKTOP-B336GFR === Setup ended ===
2017/2/25:16:55:20 Rein Vanitaz DESKTOP-B336GFR === Setup started on DESKTOP-B336GFR by Rein Vanitaz ===
2017/2/25:16:55:20 Rein Vanitaz DESKTOP-B336GFR Path_Length: 162
2017/2/25:16:55:20 Rein Vanitaz DESKTOP-B336GFR Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2017/2/25:16:55:20 Rein Vanitaz DESKTOP-B336GFR Launch
2017/2/25:16:55:20 Rein Vanitaz DESKTOP-B336GFR CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Se..."
2017/2/25:16:55:20 Rein Vanitaz DESKTOP-B336GFR Current Directory C:\Users\REINVA~1\AppData\Local\Temp\_AI9B9A.tmp
2017/2/25:16:55:45 Rein Vanitaz DESKTOP-B336GFR === Setup ended ===
2017/2/25:16:55:21 Rein Vanitaz DESKTOP-B336GFR === Setup started on DESKTOP-B336GFR by Rein Vanitaz ===
2017/2/25:16:55:21 Rein Vanitaz DESKTOP-B336GFR Path_Length: 162
2017/2/25:16:55:21 Rein Vanitaz DESKTOP-B336GFR Current Directory C:\Users\REINVA~1\AppData\Local\Temp\_AI9B9A.tmp
2017/2/25:16:55:21 Rein Vanitaz DESKTOP-B336GFR Launch
2017/2/25:16:55:45 Rein Vanitaz DESKTOP-B336GFR Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2017/2/25:16:55:45 Rein Vanitaz DESKTOP-B336GFR Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2017/2/25:16:55:45 Rein Vanitaz DESKTOP-B336GFR Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\REINVA~1\AppData\Local\Temp\_AI9B9A.tmp\Setup\AcSetup.dll
2017/2/25:16:55:45 Rein Vanitaz DESKTOP-B336GFR Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/2/25:16:55:45 Rein Vanitaz DESKTOP-B336GFR PageOpen LaunchDialog
2017/2/25:16:55:59 Rein Vanitaz DESKTOP-B336GFR PageOpen LicenseDialog
2017/2/25:16:55:59 Rein Vanitaz DESKTOP-B336GFR PageOpen ProductSelectionDialog2
2017/2/25:16:56:11 Rein Vanitaz DESKTOP-B336GFR PageOpen LicenseDialog
2017/2/25:16:56:11 Rein Vanitaz DESKTOP-B336GFR PageOpen LaunchDialog
2017/2/25:16:56:15 Rein Vanitaz DESKTOP-B336GFR PageOpen LicenseDialog
2017/2/25:16:56:15 Rein Vanitaz DESKTOP-B336GFR PageOpen ProductInfoDialog
2017/2/25:16:56:15 Rein Vanitaz DESKTOP-B336GFR PageOpen ProductSelectionDialog2
2017/2/25:16:56:20 Rein Vanitaz DESKTOP-B336GFR PageOpen FullProgressDialog
2017/2/25:16:56:21 Rein Vanitaz DESKTOP-B336GFR Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2017/2/25:16:56:21 Rein Vanitaz DESKTOP-B336GFR Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2017/2/25:16:56:21 Rein Vanitaz DESKTOP-B336GFR Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2017/2/25:16:56:21 Rein Vanitaz DESKTOP-B336GFR Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/2/25:16:56:22 Rein Vanitaz DESKTOP-B336GFR Install Universal C Runtime (KB3118401) Succeeded
2017/2/25:16:56:22 Rein Vanitaz DESKTOP-B336GFR Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2017/2/25:16:56:22 Rein Vanitaz DESKTOP-B336GFR Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\REINVA~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/2/25:16:56:22 Rein Vanitaz DESKTOP-B336GFR Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2017/2/25:16:56:22 Rein Vanitaz DESKTOP-B336GFR Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2017/2/25:16:56:22 Rein Vanitaz DESKTOP-B336GFR Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\REINVA~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/2/25:16:56:23 Rein Vanitaz DESKTOP-B336GFR Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2017/2/25:16:56:23 Rein Vanitaz DESKTOP-B336GFR Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2017/2/25:16:56:23 Rein Vanitaz DESKTOP-B336GFR Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2017/2/25:16:56:35 Rein Vanitaz DESKTOP-B336GFR Install DirectX Runtime Succeeded
2017/2/25:16:56:35 Rein Vanitaz DESKTOP-B336GFR Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2017/2/25:16:58:17 Rein Vanitaz DESKTOP-B336GFR Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2017/2/25:16:58:17 Rein Vanitaz DESKTOP-B336GFR Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2017/2/25:16:58:17 Rein Vanitaz DESKTOP-B336GFR Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/2/25:16:58:18 Rein Vanitaz DESKTOP-B336GFR PageOpen InstallCompleteDialog
2017/2/25:16:58:38 Rein Vanitaz DESKTOP-B336GFR === Setup ended ===
2017/2/25:16:59:50 Rein Vanitaz DESKTOP-B336GFR === Setup started on DESKTOP-B336GFR by Rein Vanitaz ===
2017/2/25:16:59:50 Rein Vanitaz DESKTOP-B336GFR Path_Length: 162
2017/2/25:16:59:50 Rein Vanitaz DESKTOP-B336GFR Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2017/2/25:16:59:50 Rein Vanitaz DESKTOP-B336GFR Launch
2017/2/25:16:59:50 Rein Vanitaz DESKTOP-B336GFR CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Se..."
2017/2/25:16:59:50 Rein Vanitaz DESKTOP-B336GFR Current Directory C:\Users\REINVA~1\AppData\Local\Temp\_AIBA2B.tmp
2017/2/25:16:59:52 Rein Vanitaz DESKTOP-B336GFR === Setup ended ===
2017/2/25:16:59:51 Rein Vanitaz DESKTOP-B336GFR Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2017/2/25:16:59:51 Rein Vanitaz DESKTOP-B336GFR Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2017/2/25:16:59:51 Rein Vanitaz DESKTOP-B336GFR Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\REINVA~1\AppData\Local\Temp\_AIBA2B.tmp\Setup\AcSetup.dll
2017/2/25:16:59:51 Rein Vanitaz DESKTOP-B336GFR Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/2/25:16:59:51 Rein Vanitaz DESKTOP-B336GFR PageOpen LaunchDialog
2017/2/25:16:59:56 Rein Vanitaz DESKTOP-B336GFR PageOpen LicenseDialog
2017/2/25:16:59:56 Rein Vanitaz DESKTOP-B336GFR PageOpen ProductInfoDialog
2017/2/25:16:59:56 Rein Vanitaz DESKTOP-B336GFR PageOpen ProductSelectionDialog2
2017/2/25:17:00:39 Rein Vanitaz DESKTOP-B336GFR PageOpen ProductInfoDialog
2017/2/25:17:00:39 Rein Vanitaz DESKTOP-B336GFR PageOpen LicenseDialog
2017/2/25:17:00:39 Rein Vanitaz DESKTOP-B336GFR PageOpen LaunchDialog
2017/2/25:17:00:40 Rein Vanitaz DESKTOP-B336GFR PageOpen LicenseDialog
2017/2/25:17:00:40 Rein Vanitaz DESKTOP-B336GFR PageOpen ProductInfoDialog
2017/2/25:17:00:40 Rein Vanitaz DESKTOP-B336GFR PageOpen ProductSelectionDialog2
2017/2/25:17:00:45 Rein Vanitaz DESKTOP-B336GFR PageOpen FullProgressDialog
2017/2/25:17:00:45 Rein Vanitaz DESKTOP-B336GFR Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2017/2/25:17:00:45 Rein Vanitaz DESKTOP-B336GFR Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2017/2/25:17:00:45 Rein Vanitaz DESKTOP-B336GFR Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2017/2/25:17:00:45 Rein Vanitaz DESKTOP-B336GFR Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/2/25:17:00:46 Rein Vanitaz DESKTOP-B336GFR Install Universal C Runtime (KB3118401) Succeeded
2017/2/25:17:00:46 Rein Vanitaz DESKTOP-B336GFR Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2017/2/25:17:00:46 Rein Vanitaz DESKTOP-B336GFR Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\REINVA~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/2/25:17:00:46 Rein Vanitaz DESKTOP-B336GFR Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2017/2/25:17:00:46 Rein Vanitaz DESKTOP-B336GFR Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2017/2/25:17:00:46 Rein Vanitaz DESKTOP-B336GFR Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\REINVA~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/2/25:17:00:47 Rein Vanitaz DESKTOP-B336GFR Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2017/2/25:17:00:47 Rein Vanitaz DESKTOP-B336GFR Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2017/2/25:17:00:47 Rein Vanitaz DESKTOP-B336GFR Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2017/2/25:17:00:57 Rein Vanitaz DESKTOP-B336GFR Install DirectX Runtime Succeeded
2017/2/25:17:00:58 Rein Vanitaz DESKTOP-B336GFR Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2017/2/25:17:02:47 Rein Vanitaz DESKTOP-B336GFR Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2017/2/25:17:02:47 Rein Vanitaz DESKTOP-B336GFR Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2017/2/25:17:02:47 Rein Vanitaz DESKTOP-B336GFR Rollback DirectX Runtime Failed Failure is ignored, Result=1619
what happen?
@Anonymous
Welcome to the community..
You asked what happened...
Your installation is simply failing due to the method (web installer) you're using. This method is unreliable and shouldn't be used.
1. Access the Autodesk Virtual Agent and follow the download links to your product.
However if the installation does fail using this method, please post your installation log file here so we can review it. Posting info: Sometimes installation log files contain personal information such as your serial #. Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Dear Mark -- just a word of thanks for your invaluable set of instructions. I was quite frustrated with my installation failure, but this clearly marked route was the path to success.
@Anonymous
Welcome to the community...
What do you think?
Did you read my step by step instructions above in my other reply?
Yes you need all the parts downloaded...
Mark Lancaster
Dear Mr. Mark,
I followed step by step as your instruction. But it's also fail installation. below my log file. Can you help me.
2017/4/24:08:47:33 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:08:47:33 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:08:47:33 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:08:47:33 Administrator LVD-MUC0707SHA Launch
2017/4/24:08:47:33 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:08:47:33 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AID69.tmp
2017/4/24:08:49:52 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:08:47:39 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:08:47:39 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:08:47:39 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AID69.tmp
2017/4/24:08:47:39 Administrator LVD-MUC0707SHA Launch
2017/4/24:08:49:01 Administrator LVD-MUC0707SHA Download Play SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:08:49:01 Administrator LVD-MUC0707SHA Download Complete SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:08:49:02 Administrator LVD-MUC0707SHA Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:08:49:51 Administrator LVD-MUC0707SHA Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:08:49:51 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AID69.tmp\Setup\AcSetup.dll
2017/4/24:08:49:51 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:08:49:52 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:08:50:10 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:08:50:10 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:08:50:10 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:08:50:46 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:08:50:47 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:08:50:48 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:08:50:48 Administrator LVD-MUC0707SHA Download Play VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:08:50:52 Administrator LVD-MUC0707SHA Download Complete VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:08:50:52 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:08:51:12 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:08:51:13 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:08:51:52 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:08:52:43 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:08:52:43 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:08:52:43 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:08:52:43 Administrator LVD-MUC0707SHA Launch
2017/4/24:08:52:43 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:08:52:43 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIC929.tmp
2017/4/24:08:52:53 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:08:52:45 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:08:52:45 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:08:52:45 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIC929.tmp
2017/4/24:08:52:45 Administrator LVD-MUC0707SHA Launch
2017/4/24:08:52:46 Administrator LVD-MUC0707SHA Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:08:52:46 Administrator LVD-MUC0707SHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:08:52:46 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AIC929.tmp\Setup\AcSetup.dll
2017/4/24:08:52:46 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:08:52:47 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:08:53:03 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:08:53:03 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:08:53:03 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:08:53:06 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:08:53:07 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:08:53:08 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:08:53:08 Administrator LVD-MUC0707SHA Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:08:53:08 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:08:53:22 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:08:53:23 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:08:53:33 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:08:55:03 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:08:55:03 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:08:55:03 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:08:55:03 Administrator LVD-MUC0707SHA Launch
2017/4/24:08:55:03 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:08:55:03 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIEBE5.tmp
2017/4/24:08:55:14 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:08:55:05 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:08:55:05 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:08:55:05 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIEBE5.tmp
2017/4/24:08:55:05 Administrator LVD-MUC0707SHA Launch
2017/4/24:08:55:06 Administrator LVD-MUC0707SHA Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:08:55:06 Administrator LVD-MUC0707SHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:08:55:07 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AIEBE5.tmp\Setup\AcSetup.dll
2017/4/24:08:55:07 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:08:55:07 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:08:55:23 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:08:55:23 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:08:55:23 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:08:55:30 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:08:55:31 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:08:55:31 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:08:55:31 Administrator LVD-MUC0707SHA Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:08:55:31 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:08:55:43 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:08:55:44 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:08:59:02 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:01:21 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:01:21 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:01:21 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:09:01:21 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:01:21 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:09:01:21 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIAFEF.tmp
2017/4/24:09:01:30 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:01:24 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:01:24 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:01:24 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIAFEF.tmp
2017/4/24:09:01:24 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:01:25 Administrator LVD-MUC0707SHA Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:09:01:25 Administrator LVD-MUC0707SHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:09:01:25 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AIAFEF.tmp\Setup\AcSetup.dll
2017/4/24:09:01:25 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:09:01:26 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:09:01:43 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:09:01:43 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:09:01:43 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:09:01:46 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:09:01:47 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:01:47 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:01:47 Administrator LVD-MUC0707SHA Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:09:01:47 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:09:01:58 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:09:01:58 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:09:02:06 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:05:36 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:05:36 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:05:36 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:09:05:36 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:05:36 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:09:05:36 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI91F4.tmp
2017/4/24:09:06:21 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:05:38 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:05:38 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:05:38 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI91F4.tmp
2017/4/24:09:05:38 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:05:40 Administrator LVD-MUC0707SHA Download Play SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:09:05:40 Administrator LVD-MUC0707SHA Download Complete SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:09:05:41 Administrator LVD-MUC0707SHA Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:09:06:20 Administrator LVD-MUC0707SHA Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:09:06:20 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI91F4.tmp\Setup\AcSetup.dll
2017/4/24:09:06:20 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:09:06:21 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:09:06:43 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:09:06:43 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:09:06:44 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:09:06:49 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:09:06:50 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:06:51 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:06:51 Administrator LVD-MUC0707SHA Download Play VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:09:06:53 Administrator LVD-MUC0707SHA Download Complete VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:09:06:53 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:09:07:01 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:09:07:02 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:09:07:16 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:08:03 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:08:03 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:08:03 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:09:08:03 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:08:03 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:09:08:03 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AID1D1.tmp
2017/4/24:09:08:14 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:08:05 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:08:05 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:08:05 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AID1D1.tmp
2017/4/24:09:08:05 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:08:07 Administrator LVD-MUC0707SHA Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:09:08:07 Administrator LVD-MUC0707SHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:09:08:07 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AID1D1.tmp\Setup\AcSetup.dll
2017/4/24:09:08:07 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:09:08:08 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:09:08:19 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:09:08:20 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:09:08:20 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:09:08:23 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:09:08:24 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:08:24 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:08:25 Administrator LVD-MUC0707SHA Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:09:08:25 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:09:08:32 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:09:08:33 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:09:09:46 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:10:47 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:10:47 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:10:47 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:09:10:47 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:10:47 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:09:10:47 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI51F8.tmp
2017/4/24:09:10:56 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:10:49 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:10:49 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:10:49 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI51F8.tmp
2017/4/24:09:10:49 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:10:50 Administrator LVD-MUC0707SHA Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:09:10:51 Administrator LVD-MUC0707SHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:09:10:51 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI51F8.tmp\Setup\AcSetup.dll
2017/4/24:09:10:51 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:09:10:52 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:09:11:06 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:09:11:06 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:09:11:06 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:09:11:31 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:09:11:32 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:11:33 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:11:33 Administrator LVD-MUC0707SHA Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:09:11:33 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:09:11:45 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:09:11:45 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:09:12:16 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:13:58 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:13:58 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:13:58 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:09:13:58 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:13:58 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:09:13:58 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI3B2D.tmp
2017/4/24:09:14:08 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:14:00 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:14:00 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:14:00 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI3B2D.tmp
2017/4/24:09:14:00 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:14:01 Administrator LVD-MUC0707SHA Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:09:14:01 Administrator LVD-MUC0707SHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:09:14:01 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI3B2D.tmp\Setup\AcSetup.dll
2017/4/24:09:14:01 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:09:14:02 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:09:14:16 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:09:14:16 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:09:14:16 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:09:14:20 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:09:14:21 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:14:22 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:14:22 Administrator LVD-MUC0707SHA Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:09:14:22 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:09:14:34 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:09:14:35 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:09:15:02 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:20:47 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:20:47 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:20:47 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:09:20:47 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:20:47 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:09:20:47 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI7956.tmp
2017/4/24:09:20:57 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:20:49 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:20:49 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:20:49 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI7956.tmp
2017/4/24:09:20:49 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:20:50 Administrator LVD-MUC0707SHA Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:09:20:50 Administrator LVD-MUC0707SHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:09:20:50 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI7956.tmp\Setup\AcSetup.dll
2017/4/24:09:20:50 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:09:20:51 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:09:21:05 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:09:21:05 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:09:21:05 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:09:21:15 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:09:21:16 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:21:16 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:21:16 Administrator LVD-MUC0707SHA Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:09:21:16 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:09:21:25 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:09:21:25 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:09:23:49 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:24:38 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:24:38 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:24:38 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIF49D.tmp
2017/4/24:09:24:38 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:24:41 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:24:35 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:24:35 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:24:35 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:09:24:35 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:24:35 Administrator LVD-MUC0707SHA CommandLine
2017/4/24:09:24:35 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIF49D.tmp
2017/4/24:09:24:49 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:25:58 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:25:58 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:25:58 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:09:25:58 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:25:58 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:09:25:58 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI389E.tmp
2017/4/24:09:26:10 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:26:01 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:26:01 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:26:01 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI389E.tmp
2017/4/24:09:26:01 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:26:02 Administrator LVD-MUC0707SHA Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:09:26:02 Administrator LVD-MUC0707SHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:09:26:02 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI389E.tmp\Setup\AcSetup.dll
2017/4/24:09:26:02 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:09:26:03 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:09:26:16 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:09:26:16 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:09:26:16 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:09:26:19 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:09:26:20 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:26:20 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:26:20 Administrator LVD-MUC0707SHA Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:09:26:20 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:09:26:33 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:09:26:34 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:09:26:42 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:31:29 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:31:29 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:31:29 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:09:31:29 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:31:29 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:09:31:29 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIC9D.tmp
2017/4/24:09:31:41 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:31:31 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:31:31 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:31:31 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIC9D.tmp
2017/4/24:09:31:31 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:31:34 Administrator LVD-MUC0707SHA Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:09:31:34 Administrator LVD-MUC0707SHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:09:31:34 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AIC9D.tmp\Setup\AcSetup.dll
2017/4/24:09:31:34 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:09:31:36 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:09:31:54 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:09:31:54 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:09:31:54 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:09:31:58 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:09:31:59 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:32:00 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:32:00 Administrator LVD-MUC0707SHA Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:09:32:00 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:09:32:26 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:09:32:29 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:09:33:44 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:38:07 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:38:07 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:38:07 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:09:38:07 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:38:07 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:09:38:07 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI1EA7.tmp
2017/4/24:09:38:16 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:38:09 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:38:09 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:38:09 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI1EA7.tmp
2017/4/24:09:38:09 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:38:10 Administrator LVD-MUC0707SHA Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:09:38:10 Administrator LVD-MUC0707SHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:09:38:10 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI1EA7.tmp\Setup\AcSetup.dll
2017/4/24:09:38:10 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:09:38:11 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:09:38:26 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:09:38:26 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:09:38:26 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:09:38:36 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:09:38:37 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:38:38 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:38:38 Administrator LVD-MUC0707SHA Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:09:38:38 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:09:38:51 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:09:38:52 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:09:39:45 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:52:37 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:52:37 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:52:37 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:09:52:37 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:52:37 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:09:52:37 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI63E1.tmp
2017/4/24:09:52:46 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:52:38 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:52:38 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:52:38 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI63E1.tmp
2017/4/24:09:52:38 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:52:39 Administrator LVD-MUC0707SHA Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:09:52:40 Administrator LVD-MUC0707SHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:09:52:40 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI63E1.tmp\Setup\AcSetup.dll
2017/4/24:09:52:40 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:09:52:41 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:09:52:52 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:09:52:52 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:09:52:52 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:09:52:56 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:09:52:57 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:52:58 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:52:58 Administrator LVD-MUC0707SHA Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:09:52:58 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:09:53:18 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:09:53:19 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:09:53:31 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:12:21:03 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:12:21:03 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:12:21:03 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:12:21:03 Administrator LVD-MUC0707SHA Launch
2017/4/24:12:21:03 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:12:21:03 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI4829.tmp
2017/4/24:12:21:30 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:12:21:09 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:12:21:09 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:12:21:09 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI4829.tmp
2017/4/24:12:21:09 Administrator LVD-MUC0707SHA Launch
2017/4/24:12:21:11 Administrator LVD-MUC0707SHA Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:12:21:11 Administrator LVD-MUC0707SHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:12:21:12 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI4829.tmp\Setup\AcSetup.dll
2017/4/24:12:21:12 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:12:21:14 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:12:21:39 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:12:21:39 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:12:21:39 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:12:21:42 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:12:21:43 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:12:21:44 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:12:21:44 Administrator LVD-MUC0707SHA Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:12:21:44 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:12:22:06 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:12:22:09 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:12:33:59 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:12:35:00 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:12:35:00 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:12:35:00 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:12:35:00 Administrator LVD-MUC0707SHA Launch
2017/4/24:12:35:00 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:12:35:00 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AID6B.tmp
2017/4/24:12:35:10 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:12:35:01 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:12:35:01 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:12:35:01 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AID6B.tmp
2017/4/24:12:35:01 Administrator LVD-MUC0707SHA Launch
2017/4/24:12:35:03 Administrator LVD-MUC0707SHA Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:12:35:03 Administrator LVD-MUC0707SHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:12:35:03 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AID6B.tmp\Setup\AcSetup.dll
2017/4/24:12:35:03 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:12:35:04 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:12:35:59 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:12:35:59 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:12:35:59 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:12:36:01 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:12:36:02 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:12:36:03 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:12:36:03 Administrator LVD-MUC0707SHA Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:12:36:03 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:12:36:12 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:12:36:13 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:13:01:00 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:12:59:36 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:12:59:36 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:12:59:36 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32bit_dlm
2017/4/24:12:59:36 Administrator LVD-MUC0707SHA Launch
2017/4/24:12:59:36 Administrator LVD-MUC0707SHA CommandLine
2017/4/24:12:59:36 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:12:59:56 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:09 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:43 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:44 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:44 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:44 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:44 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:44 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:45 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:45 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:45 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:45 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:46 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:47 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:47 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:47 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:47 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:48 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:48 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:48 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:48 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:48 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:51 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:51 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:52 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:01:16 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:13:01:16 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI93D9.tmp
2017/4/24:13:01:36 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:13:01:21 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:13:01:21 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:13:01:21 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI93D9.tmp
2017/4/24:13:01:21 Administrator LVD-MUC0707SHA Launch
2017/4/24:13:01:22 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI93D9.tmp\Setup\AcSetup.dll
2017/4/24:13:01:22 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:13:01:31 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:13:01:38 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:13:01:57 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:13:03:53 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:13:04:02 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:13:04:02 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\AutoCAD_2016_English_Win_32bit_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:13:04:24 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:13:04:26 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:13:04:36 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:13:17:52 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:13:17:52 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:13:17:52 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32bit_dlm
2017/4/24:13:17:52 Administrator LVD-MUC0707SHA Launch
2017/4/24:13:17:52 Administrator LVD-MUC0707SHA CommandLine
2017/4/24:13:17:52 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI4B46.tmp
2017/4/24:13:18:08 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:13:17:56 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:13:17:56 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:13:17:56 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI4B46.tmp
2017/4/24:13:17:56 Administrator LVD-MUC0707SHA Launch
2017/4/24:13:17:57 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI4B46.tmp\Setup\AcSetup.dll
2017/4/24:13:17:57 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:13:18:06 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:13:18:11 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:13:18:23 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:13:19:00 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:13:19:44 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:13:19:44 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\AutoCAD_2016_English_Win_32bit_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:13:20:02 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/5/30:21:55:07 EngPiero LAPTOP-3MG2Q2F0 === Setup started on LAPTOP-3MG2Q2F0 by EngPiero ===
2017/5/30:21:55:07 EngPiero LAPTOP-3MG2Q2F0 Path_Length: 162
2017/5/30:21:55:07 EngPiero LAPTOP-3MG2Q2F0 Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_wi_en-us
2017/5/30:21:55:07 EngPiero LAPTOP-3MG2Q2F0 Launch
2017/5/30:21:55:07 EngPiero LAPTOP-3MG2Q2F0 CommandLine /akamai /sid a1b3A00000AsbURQAZ /skipEULA /url "http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_wi_en-us_S..."
2017/5/30:21:55:07 EngPiero LAPTOP-3MG2Q2F0 Current Directory C:\Users\EngPiero\AppData\Local\Temp\_AI72EA.tmp
2017/5/30:21:55:48 EngPiero LAPTOP-3MG2Q2F0 === Setup ended ===
2017/5/30:21:55:33 EngPiero LAPTOP-3MG2Q2F0 Download Play SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/SETUP...
2017/5/30:21:55:33 EngPiero LAPTOP-3MG2Q2F0 Download Complete SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/SETUP...
2017/5/30:21:55:33 EngPiero LAPTOP-3MG2Q2F0 Download Play SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/SETUP...
2017/5/30:21:55:47 EngPiero LAPTOP-3MG2Q2F0 Download Complete SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/SETUP...
2017/5/30:21:55:47 EngPiero LAPTOP-3MG2Q2F0 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\EngPiero\AppData\Local\Temp\_AI72EA.tmp\Setup\AcSetup.dll
2017/5/30:21:55:47 EngPiero LAPTOP-3MG2Q2F0 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/5/30:21:55:50 EngPiero LAPTOP-3MG2Q2F0 PageOpen LaunchDialog
2017/5/30:21:56:33 EngPiero LAPTOP-3MG2Q2F0 PageOpen LicenseDialog
2017/5/30:21:56:33 EngPiero LAPTOP-3MG2Q2F0 PageOpen ProductInfoDialog
2017/5/30:21:56:33 EngPiero LAPTOP-3MG2Q2F0 PageOpen ProductSelectionDialog2
2017/5/30:21:56:45 EngPiero LAPTOP-3MG2Q2F0 PageOpen FullProgressDialog
2017/5/30:21:56:45 EngPiero LAPTOP-3MG2Q2F0 Download Play STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/START...
2017/5/30:21:56:45 EngPiero LAPTOP-3MG2Q2F0 Download Complete STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/START...
2017/5/30:21:56:46 EngPiero LAPTOP-3MG2Q2F0 Download Play VCREDIST2008SP1X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2017/5/30:21:56:47 EngPiero LAPTOP-3MG2Q2F0 Download Complete VCREDIST2008SP1X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2017/5/30:21:56:47 EngPiero LAPTOP-3MG2Q2F0 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2017/5/30:21:57:05 EngPiero LAPTOP-3MG2Q2F0 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2017/5/30:21:57:06 EngPiero LAPTOP-3MG2Q2F0 Download Play VCREDIST2010SP1X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2017/5/30:21:57:08 EngPiero LAPTOP-3MG2Q2F0 Download Complete VCREDIST2010SP1X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2017/5/30:21:57:08 EngPiero LAPTOP-3MG2Q2F0 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /l C:\Users\EngPiero\AppData\Local\Temp\vcredist_x86_2010.log
2017/5/30:21:57:19 EngPiero LAPTOP-3MG2Q2F0 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2017/5/30:21:57:19 EngPiero LAPTOP-3MG2Q2F0 Download Play VCREDIST2010SP1X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2017/5/30:21:57:21 EngPiero LAPTOP-3MG2Q2F0 Download Complete VCREDIST2010SP1X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2017/5/30:21:57:21 EngPiero LAPTOP-3MG2Q2F0 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart /l C:\Users\EngPiero\AppData\Local\Temp\vcredist_x64_2010.log
2017/5/30:21:57:29 EngPiero LAPTOP-3MG2Q2F0 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2017/5/30:21:57:30 EngPiero LAPTOP-3MG2Q2F0 Download Play UCRT http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/UCRT_...
2017/5/30:21:57:33 EngPiero LAPTOP-3MG2Q2F0 Download Complete UCRT http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/UCRT_...
2017/5/30:21:57:33 EngPiero LAPTOP-3MG2Q2F0 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/5/30:21:57:33 EngPiero LAPTOP-3MG2Q2F0 Install Universal C Runtime (KB3118401) Succeeded
2017/5/30:21:57:33 EngPiero LAPTOP-3MG2Q2F0 Download Play VCREDIST2015X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2017/5/30:21:57:35 EngPiero LAPTOP-3MG2Q2F0 Download Complete VCREDIST2015X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2017/5/30:21:57:36 EngPiero LAPTOP-3MG2Q2F0 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\EngPiero\AppData\Local\Temp\vcredist_x86_2015.log
2017/5/30:21:57:38 EngPiero LAPTOP-3MG2Q2F0 Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2017/5/30:21:57:41 EngPiero LAPTOP-3MG2Q2F0 Download Play VCREDIST2015X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2017/5/30:21:57:52 EngPiero LAPTOP-3MG2Q2F0 Download Complete VCREDIST2015X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2017/5/30:21:57:52 EngPiero LAPTOP-3MG2Q2F0 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\EngPiero\AppData\Local\Temp\vcredist_x64_2015.log
2017/5/30:21:57:53 EngPiero LAPTOP-3MG2Q2F0 Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2017/5/30:21:57:59 EngPiero LAPTOP-3MG2Q2F0 Download Play DIRECTX http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/DIREC...
2017/5/30:21:58:05 EngPiero LAPTOP-3MG2Q2F0 Download Complete DIRECTX http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/DIREC...
2017/5/30:21:58:05 EngPiero LAPTOP-3MG2Q2F0 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2017/5/30:21:59:09 EngPiero LAPTOP-3MG2Q2F0 Install DirectX Runtime Succeeded
2017/5/30:21:59:09 EngPiero LAPTOP-3MG2Q2F0 Download Play CM http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/CM.ta...
2017/5/30:21:59:31 EngPiero LAPTOP-3MG2Q2F0 Download Aborted CM http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/CM.ta...
2017/5/30:21:59:31 EngPiero LAPTOP-3MG2Q2F0 Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2017/5/30:21:59:31 EngPiero LAPTOP-3MG2Q2F0 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/5/30:21:59:31 EngPiero LAPTOP-3MG2Q2F0 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2017/5/30:21:59:31 EngPiero LAPTOP-3MG2Q2F0 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2017/5/30:21:59:32 EngPiero LAPTOP-3MG2Q2F0 PageOpen InstallCompleteDialog
2017/5/30:22:15:09 EngPiero LAPTOP-3MG2Q2F0 === Setup ended ===
2017/5/30:22:16:19 EngPiero LAPTOP-3MG2Q2F0 === Setup started on LAPTOP-3MG2Q2F0 by EngPiero ===
2017/5/30:22:16:19 EngPiero LAPTOP-3MG2Q2F0 Path_Length: 162
2017/5/30:22:16:19 EngPiero LAPTOP-3MG2Q2F0 Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_wi_en-us
2017/5/30:22:16:19 EngPiero LAPTOP-3MG2Q2F0 Launch
2017/5/30:22:16:19 EngPiero LAPTOP-3MG2Q2F0 CommandLine /akamai /sid a1b3A00000AsbURQAZ /skipEULA /url "http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_wi_en-us_S..."
2017/5/30:22:16:19 EngPiero LAPTOP-3MG2Q2F0 Current Directory C:\Users\EngPiero\AppData\Local\Temp\_AIDD50.tmp
2017/5/30:22:16:22 EngPiero LAPTOP-3MG2Q2F0 === Setup ended ===
2017/5/30:22:16:20 EngPiero LAPTOP-3MG2Q2F0 Download Skipped SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/SETUP...
2017/5/30:22:16:20 EngPiero LAPTOP-3MG2Q2F0 Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/SETUP...
2017/5/30:22:16:20 EngPiero LAPTOP-3MG2Q2F0 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\EngPiero\AppData\Local\Temp\_AIDD50.tmp\Setup\AcSetup.dll
2017/5/30:22:16:20 EngPiero LAPTOP-3MG2Q2F0 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/5/30:22:16:20 EngPiero LAPTOP-3MG2Q2F0 PageOpen LaunchDialog
2017/5/30:22:16:27 EngPiero LAPTOP-3MG2Q2F0 PageOpen LicenseDialog
2017/5/30:22:16:27 EngPiero LAPTOP-3MG2Q2F0 PageOpen ProductInfoDialog
2017/5/30:22:16:27 EngPiero LAPTOP-3MG2Q2F0 PageOpen ProductSelectionDialog2
2017/5/30:22:16:43 EngPiero LAPTOP-3MG2Q2F0 PageOpen FullProgressDialog
2017/5/30:22:16:44 EngPiero LAPTOP-3MG2Q2F0 Download Skipped STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/START...
2017/5/30:22:16:44 EngPiero LAPTOP-3MG2Q2F0 Download Skipped UCRT http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/UCRT_...
2017/5/30:22:16:44 EngPiero LAPTOP-3MG2Q2F0 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/5/30:22:16:44 EngPiero LAPTOP-3MG2Q2F0 Install Universal C Runtime (KB3118401) Succeeded
2017/5/30:22:16:44 EngPiero LAPTOP-3MG2Q2F0 Download Skipped VCREDIST2015X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2017/5/30:22:16:44 EngPiero LAPTOP-3MG2Q2F0 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\EngPiero\AppData\Local\Temp\vcredist_x86_2015.log
2017/5/30:22:16:44 EngPiero LAPTOP-3MG2Q2F0 Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2017/5/30:22:16:44 EngPiero LAPTOP-3MG2Q2F0 Download Skipped VCREDIST2015X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2017/5/30:22:16:44 EngPiero LAPTOP-3MG2Q2F0 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\EngPiero\AppData\Local\Temp\vcredist_x64_2015.log
2017/5/30:22:16:45 EngPiero LAPTOP-3MG2Q2F0 Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2017/5/30:22:16:45 EngPiero LAPTOP-3MG2Q2F0 Download Skipped DIRECTX http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/DIREC...
2017/5/30:22:16:45 EngPiero LAPTOP-3MG2Q2F0 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2017/5/30:22:17:05 EngPiero LAPTOP-3MG2Q2F0 Install DirectX Runtime Succeeded
2017/5/30:22:17:05 EngPiero LAPTOP-3MG2Q2F0 Download Play CM http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/CM.ta...
2017/5/30:22:17:27 EngPiero LAPTOP-3MG2Q2F0 Download Aborted CM http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/CM.ta...
2017/5/30:22:17:27 EngPiero LAPTOP-3MG2Q2F0 Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2017/5/30:22:17:27 EngPiero LAPTOP-3MG2Q2F0 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/5/30:22:17:27 EngPiero LAPTOP-3MG2Q2F0 PageOpen InstallCompleteDialog
2017/5/30:22:17:36 EngPiero LAPTOP-3MG2Q2F0 === Setup ended ===
2017/5/31:16:26:17 EngPiero LAPTOP-3MG2Q2F0 === Setup started on LAPTOP-3MG2Q2F0 by EngPiero ===
2017/5/31:16:26:17 EngPiero LAPTOP-3MG2Q2F0 Path_Length: 162
2017/5/31:16:26:17 EngPiero LAPTOP-3MG2Q2F0 Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_wi_en-us
2017/5/31:16:26:17 EngPiero LAPTOP-3MG2Q2F0 Launch
2017/5/31:16:26:17 EngPiero LAPTOP-3MG2Q2F0 CommandLine /akamai /sid a1b3A00000AsbURQAZ /skipEULA /url "http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_wi_en-us_S..."
2017/5/31:16:26:17 EngPiero LAPTOP-3MG2Q2F0 Current Directory C:\Users\EngPiero\AppData\Local\Temp\_AI8D98.tmp
2017/5/31:16:26:39 EngPiero LAPTOP-3MG2Q2F0 === Setup ended ===
2017/5/31:16:26:20 EngPiero LAPTOP-3MG2Q2F0 === Setup started on LAPTOP-3MG2Q2F0 by EngPiero ===
2017/5/31:16:26:20 EngPiero LAPTOP-3MG2Q2F0 Path_Length: 162
2017/5/31:16:26:20 EngPiero LAPTOP-3MG2Q2F0 Current Directory C:\Users\EngPiero\AppData\Local\Temp\_AI8D98.tmp
2017/5/31:16:26:20 EngPiero LAPTOP-3MG2Q2F0 Launch
2017/5/31:16:26:21 EngPiero LAPTOP-3MG2Q2F0 Download Skipped SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/SETUP...
2017/5/31:16:26:21 EngPiero LAPTOP-3MG2Q2F0 Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/SETUP...
2017/5/31:16:26:22 EngPiero LAPTOP-3MG2Q2F0 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\EngPiero\AppData\Local\Temp\_AI8D98.tmp\Setup\AcSetup.dll
2017/5/31:16:26:22 EngPiero LAPTOP-3MG2Q2F0 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/5/31:16:26:24 EngPiero LAPTOP-3MG2Q2F0 PageOpen LaunchDialog
2017/5/31:16:26:56 EngPiero LAPTOP-3MG2Q2F0 PageOpen LicenseDialog
2017/5/31:16:26:56 EngPiero LAPTOP-3MG2Q2F0 PageOpen ProductInfoDialog
2017/5/31:16:26:56 EngPiero LAPTOP-3MG2Q2F0 PageOpen ProductSelectionDialog2
2017/5/31:16:27:13 EngPiero LAPTOP-3MG2Q2F0 PageOpen FullProgressDialog
2017/5/31:16:27:13 EngPiero LAPTOP-3MG2Q2F0 Download Skipped STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/START...
2017/5/31:16:27:14 EngPiero LAPTOP-3MG2Q2F0 Download Skipped UCRT http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/UCRT_...
2017/5/31:16:27:14 EngPiero LAPTOP-3MG2Q2F0 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/5/31:16:27:14 EngPiero LAPTOP-3MG2Q2F0 Install Universal C Runtime (KB3118401) Succeeded
2017/5/31:16:27:14 EngPiero LAPTOP-3MG2Q2F0 Download Skipped VCREDIST2015X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2017/5/31:16:27:14 EngPiero LAPTOP-3MG2Q2F0 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\EngPiero\AppData\Local\Temp\vcredist_x86_2015.log
2017/5/31:16:27:18 EngPiero LAPTOP-3MG2Q2F0 Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2017/5/31:16:27:18 EngPiero LAPTOP-3MG2Q2F0 Download Skipped VCREDIST2015X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2017/5/31:16:27:18 EngPiero LAPTOP-3MG2Q2F0 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\EngPiero\AppData\Local\Temp\vcredist_x64_2015.log
2017/5/31:16:27:21 EngPiero LAPTOP-3MG2Q2F0 Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2017/5/31:16:27:21 EngPiero LAPTOP-3MG2Q2F0 Download Skipped DIRECTX http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/DIREC...
2017/5/31:16:27:21 EngPiero LAPTOP-3MG2Q2F0 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2017/5/31:16:28:05 EngPiero LAPTOP-3MG2Q2F0 Install DirectX Runtime Succeeded
2017/5/31:16:28:05 EngPiero LAPTOP-3MG2Q2F0 Download Play CM http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/CM.ta...
2017/5/31:16:28:29 EngPiero LAPTOP-3MG2Q2F0 Download Aborted CM http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/CM.ta...
2017/5/31:16:28:29 EngPiero LAPTOP-3MG2Q2F0 Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2017/5/31:16:28:30 EngPiero LAPTOP-3MG2Q2F0 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/5/31:16:28:50 EngPiero LAPTOP-3MG2Q2F0 PageOpen InstallCompleteDialog
2017/5/31:16:30:50 EngPiero LAPTOP-3MG2Q2F0 === Setup ended ===
2017/5/31:19:50:45 EngPiero LAPTOP-3MG2Q2F0 === Setup started on LAPTOP-3MG2Q2F0 by EngPiero ===
2017/5/31:19:50:45 EngPiero LAPTOP-3MG2Q2F0 Path_Length: 162
2017/5/31:19:50:45 EngPiero LAPTOP-3MG2Q2F0 Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_wi_en-us
2017/5/31:19:50:45 EngPiero LAPTOP-3MG2Q2F0 Launch
2017/5/31:19:50:45 EngPiero LAPTOP-3MG2Q2F0 CommandLine /akamai /sid a1b3A00000AsbURQAZ /skipEULA /url "http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_wi_en-us_S..."
2017/5/31:19:50:45 EngPiero LAPTOP-3MG2Q2F0 Current Directory C:\Users\EngPiero\AppData\Local\Temp\_AIC64E.tmp
2017/5/31:19:50:49 EngPiero LAPTOP-3MG2Q2F0 === Setup ended ===
2017/5/31:19:50:46 EngPiero LAPTOP-3MG2Q2F0 === Setup started on LAPTOP-3MG2Q2F0 by EngPiero ===
2017/5/31:19:50:46 EngPiero LAPTOP-3MG2Q2F0 Path_Length: 162
2017/5/31:19:50:46 EngPiero LAPTOP-3MG2Q2F0 Current Directory C:\Users\EngPiero\AppData\Local\Temp\_AIC64E.tmp
2017/5/31:19:50:46 EngPiero LAPTOP-3MG2Q2F0 Launch
2017/5/31:19:50:48 EngPiero LAPTOP-3MG2Q2F0 Download Skipped SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/SETUP...
2017/5/31:19:50:48 EngPiero LAPTOP-3MG2Q2F0 Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/SETUP...
2017/5/31:19:50:48 EngPiero LAPTOP-3MG2Q2F0 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\EngPiero\AppData\Local\Temp\_AIC64E.tmp\Setup\AcSetup.dll
2017/5/31:19:50:48 EngPiero LAPTOP-3MG2Q2F0 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/5/31:19:50:49 EngPiero LAPTOP-3MG2Q2F0 PageOpen LaunchDialog
2017/5/31:19:51:07 EngPiero LAPTOP-3MG2Q2F0 PageOpen LicenseDialog
2017/5/31:19:51:07 EngPiero LAPTOP-3MG2Q2F0 PageOpen ProductInfoDialog
2017/5/31:19:51:07 EngPiero LAPTOP-3MG2Q2F0 PageOpen ProductSelectionDialog2
2017/5/31:19:51:45 EngPiero LAPTOP-3MG2Q2F0 PageOpen FullProgressDialog
2017/5/31:19:51:45 EngPiero LAPTOP-3MG2Q2F0 Download Skipped STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/START...
2017/5/31:19:51:45 EngPiero LAPTOP-3MG2Q2F0 Download Skipped UCRT http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/UCRT_...
2017/5/31:19:51:45 EngPiero LAPTOP-3MG2Q2F0 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/5/31:19:51:46 EngPiero LAPTOP-3MG2Q2F0 Install Universal C Runtime (KB3118401) Succeeded
2017/5/31:19:51:46 EngPiero LAPTOP-3MG2Q2F0 Download Skipped VCREDIST2015X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2017/5/31:19:51:46 EngPiero LAPTOP-3MG2Q2F0 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\EngPiero\AppData\Local\Temp\vcredist_x86_2015.log
2017/5/31:19:51:47 EngPiero LAPTOP-3MG2Q2F0 Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2017/5/31:19:51:47 EngPiero LAPTOP-3MG2Q2F0 Download Skipped VCREDIST2015X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2017/5/31:19:51:47 EngPiero LAPTOP-3MG2Q2F0 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\EngPiero\AppData\Local\Temp\vcredist_x64_2015.log
2017/5/31:19:51:47 EngPiero LAPTOP-3MG2Q2F0 Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2017/5/31:19:51:48 EngPiero LAPTOP-3MG2Q2F0 Download Skipped DIRECTX http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/DIREC...
2017/5/31:19:51:48 EngPiero LAPTOP-3MG2Q2F0 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2017/5/31:19:51:59 EngPiero LAPTOP-3MG2Q2F0 Install DirectX Runtime Succeeded
2017/5/31:19:52:00 EngPiero LAPTOP-3MG2Q2F0 Download Play CM http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/CM.ta...
2017/5/31:19:52:22 EngPiero LAPTOP-3MG2Q2F0 Download Aborted CM http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/CM.ta...
2017/5/31:19:52:22 EngPiero LAPTOP-3MG2Q2F0 Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2017/5/31:19:52:23 EngPiero LAPTOP-3MG2Q2F0 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
