While installing AutoCAD 2015 the installation process gets to the Direct-X installation phase. The progress bar moves all the way to the end indicating that particular process is complete but will not move on to the next step. The installation is at a perpetual hang.
How do I get around this?
Window 7 Enterprise
Note: I have already changed the .net version from 4.6.01055 to 4.5 in the registry because I was getting an error regarding .net.
@Anonymous
Welcome to the community...
What process are you using to install your application? Install now?
You may want to cancel your installation and follow these steps:
Download and install per:
1a. Pre-2018 Version: Access the Autodesk Virtual Agent and follow the download links to your product.
1b. 2018 Version: See this posting
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
However if the installation does fail using this method, please post your installation log file here so we can review it. Posting info: Sometimes installation log files contain personal information such as your serial #. Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Mark Lancaster
& Autodesk Services MarketPlace Provider
I downloaded the installation from the Virtual Agent site.
Where do I find the installation log file?
@Anonymous
You will find the installation log file in your Windows TEMP folder. Enter %TEMP% at the address bar of a Windows File Explorer window and press the Enter key at your keyboard.
You will need to look for a file with the file extension .log and the word install or setup in the filename.
Frank Lemus
Technical Support Specialist
Graitec USA
Here's the contents of the log file relevant to this installation.
2017/4/21:09:47:46 oleal USAUS1WS00010 === Setup started on USAUS1Wxxx by oleal ===
2017/4/21:09:47:46 oleal USAUS1WS00010 Path_Length: 157
2017/4/21:09:47:46 oleal USAUS1WS00010 Current Directory C:\Users\oleal\AppData\Local\Temp\_AIE5A3.tmp
2017/4/21:09:47:46 oleal USAUS1WS00010 Launch
2017/4/21:09:47:47 oleal USAUS1WS00010 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\oleal\AppData\Local\Temp\_AIE5A3.tmp\Setup\AcSetup.dll
2017/4/21:09:47:47 oleal USAUS1Wxxx Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/21:09:47:56 oleal USAUS1Wxxx PageOpen LaunchDialog
2017/4/21:09:47:58 oleal USAUS1WSxxx PageOpen LicenseDialog
2017/4/21:09:48:02 oleal USAUS1WSxxx PageOpen ProductInfoDialog
Approximately how long should this installation take?
Attached is a screen shot of the installation screen. I noticed that the constantly changing screen section has stopped. At this point, hitting "cancel" does not cancel. I have to close this with the Task Manager.
The only way I can get past this point is if I modify the setup.ini file and remove references to DirectX.
I also noticed that DXSETUP.EXE was a process still running in Task Manager after I aborted the installation.
Hello @Anonymous,
I understand you called them out but these are needed to successfully run AutoCAD. If you run into an issue because you do not have the Direct X runtimes installed you can try the steps below.
Let us know how its going.
Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Thanks for the suggestion, however I have already tried this and the AutoCAD installation still hangs during DirectX installation even though I installed DirectX independently.
Hello @Anonymous,
Thank you for reporting back. Try following the steps below, then download & install your software again.
Let us know how it goes.
Natasha
Helpful Links:
