Previous Version Support
Welcome to Autodesk’s Previous Version Support Forums. Share your knowledge, ask questions, and explore Previous Version Support topics.
AutoCAD 2013 serial number and product key
200 REPLIES 200
Message 1 of 201
549069 Views, 200 Replies
Good Day,
I am about to install AutoCAD 2013 x64 that came with my AutoDesk Product Design Suite Ultimate. I noticed that it is has its pwn installer, but is it part of the Suite?
Would I use the same serial number and the suite product key or same serial number and the AutoCAD product key for 2013?
Sean
Tags (1)
200 REPLIES 200
Message 141 of 201
in reply to: Mark.Lancaster
    Thank you for your assistance with the 2013 AutoCAD problem - it is working again.
Deon
Message 142 of 201
auto cad product key 001E1 , plz give me serial no
Message 143 of 201
Mark.Lancaster
@Anonymous
Welcome to the community..
This is a peer to peer network where users are assisting other users like yourself.  We do not issue serial #s.  They come from Autodesk.   How did you obtain this legacy version of AutoCAD 2013?  Why are you using a retired/unsupported product, meaning why do you need this version?
Mark Lancaster
Message 144 of 201
I am not sure this is a real. But where did you get it?
Message 145 of 201
I have installed AutoCAD 2013, product key 001E1 , but no activate , error is showing serial key is incorrect
Message 146 of 201
Mark.Lancaster
@Anonymous
It all depends on the history of this serial #.  Did you purchase this product years ago and you're trying to reinstall it?  Or did someone give you this copy?
Mark Lancaster
Message 147 of 201
I have many time installed plz give me serial key sir . thank you
Message 148 of 201
Mark.Lancaster
@Anonymous
I guess you don't read replies!!!  We don't issue serial #s here.  This is a user to user forum.  Serial #s come from Autodesk and we are not Autodesk!!!  Just because you installed AutoCAD 2013 doesn't mean you automatically get a serial #.  So stop demanding one.
If you want support then you need to tell us how you got this legacy/retired/unsupported AutoCAD 2013 version.   If you obtain this product illegally then Autodesk is not going to issue a serial # to you.
You still haven't answered any questions I have asked about how you got this product and you keep demanding a serial #.  Which leads me to suspicion in how you obtain this product.  Smiley Wink  Answer the questions and we will kindly direct you to the correct solution.
Mark Lancaster
Message 149 of 201
saadatia2004
64bit plzz give me autocad product ker nd serial number
Message 150 of 201
@saadatia2004
Product keys are common for everybody and can be found here:  https://knowledge.autodesk.com/customer-service/download-install/activate/find-serial-number-product...
But you just can't come here demanding we the users issue you serial # for your product.  Serial #s come directly from Autodesk and will reside under your Autodesk Account.  However when I see question like this I have to wonder where you got your AutoCAD product.   In addition serial #s are also based on the yearly release, which you haven't even indicated in your posting.
Mark Lancaster
Message 151 of 201
natasha.l
in reply to: saadatia2004
Hello @saadatia2004,
All other User Software
Navigate to SignIn on the top right, select  Autodesk Account to view products. Serial_number_Autodesk_acct.png
Educational Software
-Sign-in or Create an account on the Autodesk.com site, select Educational Community under Sign in
-Select the Version, Operating System, Language (LT versions are not available to students)
-A Serial Number & product key are generated and emailed to you (the same Serial # is used for product version 2014-2017)Educational Account.png
Thank you.
Message 152 of 201
in reply to: jessica.t
Hi,I have the product key but I do not have the serial number,pleas help me 😞 the product is Autocad plant 3D 2013.
Message 153 of 201
Mark.Lancaster
@Anonymous
When I see postings like this where you are asking for a serial # of a given product...
My first question is..  If you properly purchased this product 3 or 4 year ago you would've been issued a serial #.  So when did you purchase this?
The 2013 product line is retired by Autodesk and no longer supported.  So why do you need an out-dated version?
Mark Lancaster
Message 154 of 201
what is serial number ?
Message 155 of 201
Mark.Lancaster
@Anonymous
You need a serial # to activate an Autodesk Product.   Is that all you need or are you asking for something else?  Your posting is very generic...  Smiley Wink
Mark Lancaster
Message 156 of 201
javeedcsml
Respected Sir,
Please send us autocad 2013 32 it product key 768E1 , Serial number___________________
thanks
@Anonymous wrote:
This is realy helpful! Thanks
Message 157 of 201
Mark.Lancaster
in reply to: javeedcsml
@javeedcsml
First welcome to the community..
Second thing..  Did you read any of the replies in this posting?  If you did you would realize a few things...  Smiley Wink
  • This is a user based forum, we don't issue serial #s to other users.  This information comes from Autodesk and we are not Autodesk..
  • AutoCAD 2013 is retired and no longer supported by Autodesk.
  • If you didn't purchase this software 4 to 5 years ago through a proper Autodesk channel then you will not be issued a serial #.
May I ask where you got this outdated versions and when?  If it was recently did you pay for it?  If you did you most likely got ripped off.
Mark Lancaster
Message 158 of 201
in reply to: camilo.lemos
hi sir. can you help me about my autodesk autocad 2013. i click the activate to avtivate my autocad 2013 and its written the serial number you entered is not valid. and can you help me also how can i block this software for accessing internet so that the cannot detect my product serial number im using window 7 ultimate. thanks guys
Message 159 of 201
Mark.Lancaster
@Anonymous
So are you trying to say you are doing something illegally here?  Activation do not come from here..  This is a user forum..   AutoCAD 2013 is retired and no longer support.   Just because you have a serial # doesn't mean its good.
Mark Lancaster
Message 160 of 201
Where did you get the product? I guess the product is not authorized by
autodesk..
Administrator Productivity
