Good Day,
I am about to install AutoCAD 2013 x64 that came with my AutoDesk Product Design Suite Ultimate. I noticed that it is has its pwn installer, but is it part of the Suite?
Would I use the same serial number and the suite product key or same serial number and the AutoCAD product key for 2013?
Sean
Solved by jessica.t. Go to Solution.
Hi Don!
You can re-download your software at anytime directly through our Virtual Agent. If you need further assistance please let me know. Thank you!
DarrenP
Hi Don,
Please check this list to find your applicable 2013 product key. We're here if you have further questions!
Hi Don,
Is your Serial Number a Commercial License or Student License? If it's a Commercial License, Serial Number is incorrect error usually comes up if that Licence has been Upgraded to a newer version.
Please send me a Private Message (click on my joane.bonghanoy profile name and then “Send this user a private message”) with your Serial Number so I can check further.
Respected sir I m using Autocad 2013 32 bit and 64 bit I want serial no and product key for the same Its very urgent. Plzzzzzzzzzzz send me soon as it is possible for u
it good to instal autocad, when u r gona to atemp the pdf, then u will find two options, 1- yes, and other one is, no, so u have to click over the yes option, then u will find the instalation processer
thanks
Hi @Anonymous,
Have you been able to request a serial number from the Education Community? Just register and then select your software from the "Free Software" tab on the left side of the home page. Please let me know if you need further assistance. Thanks!
Hello @Anonymous and welcome to the Autodesk Community!
Are you a student, or did you purchase a license and are unable to recover it?
You're most very welcome @Anonymous and please don't hesitate to let us know if anything else comes up!
