I'm trying to create a package on software center for AutoCAD 2007. I followed instructions provided by AutoDesk here: https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/sfdcarticles/sfdcarticles/How-t...
This is the command line I used for the deployment: AdminImage\deploy.exe /W /Q /I AdminImage\Setup.ini /Lang en-US
When running the install through the software center, it fails with the error attached. When running the install manually using deploy.exe it also fails with the popup attached. The only workaround we've found was to create a shortcut that points to the deploy.exe
We are currently using Windows 7/10 (Which aren't in the specifications for the application) and are only able to install it manually.
If anyone has seen this issue or have any ideas/advice to troubleshoot that would be awesome 🙂
Thank you,
Patrick
