I tried four times to download AutoCad 2017 and always same problem.
System says at one or more files missing. And when I try to install it ."(Error 1326 and Error getting file security.
C:\Users\Lasse\AppData\Roaming\GetLastError:5. Error getting file security.)"
I close my Norton before to download and delete all old Autodesk files.
Where is the problem and How I can fix it.
I need good answer now.
I have Win 7 Pro
x64
Intel i7, CPU 2.20GHz, 4 cores, 8 logical cores.
Ram 16,0 Gt
Regards, Lasse
It seems I am not the only one with this problem.
Why I can´t send a message with reply?
My NET Frame work is 4.6.1 : both in English and Finnish.
I found two Autodesk files : Autodesk Plot style manager and Autodesk Plotter manager,
but I can´t delete those files. Error message is: DLL not found:hcreg13Res.dell
Hello @Gold11Wing,
You provided some helpful information there seems to be a lot of issues based on the xml you provided. I would try to run through these steps below:
I hope this answered your question or resolved the issue, if so please click Kudos or the "thumbs-up!" Did my response help resolve the issue? Please "Accept As Solution" to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
hi, something similar happens to me, I tried to install autoCAD but some "error" dont let me finish the installation, I tried what you said so, when the program AIDA runs appears this messages
Welcome to the community..
For AIDA message, clean out your personal temp (%temp%) folder. Its located here C:\users\<username>\appdata\local\temp. Delete as many files and folders as possible. Also Appdata is a hidden folder and you may need to adjust your viewing settings.
Also there's no need for the AIDA to troubleshoot your installation issue. Did you install using the Autodesk Virtual Agent method? If not please follows these instructions.
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
However if the installation does fail using this method, please post your installation log file here so we can review it. Posting info: Sometimes installation log files contain personal information such as your serial #. Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Very nice !
