I have send a request to Autodesk in relation to my new PC
Autodesk,
I have recently purchased a new PC and wanted to install my AutoCad Architectural 2008 sofware but have been unable to load the software as the PC is 64bit and your AutoCad Software is 32bit . What do I need to do?
There responce was
We are able to provide the Physical Media for an eligible Previous Version (typically 3 versions back). The serial number ***-****** that you provided to us is attached to the license for the product AutoCAD Architecture 2008. Therefore, kindly put the comment in the Forums regarding your request and hopefully you will get the physical media or the download links for your software.
What do I do next ??
Hi leothebuilder
thanks for the link.
I downloaded the software and proceeded to install the programme however I received the same error
" PC is 64bit and your AutoCad Software is 32bit"
Have I gone wrong somewhere ?
Well....if you're PC is a 64bit system you should download and install 64 bit Autocad Architecture.......not the 32 bit version
yea there was no Autocad Architecture 2008 64 bit back then
Autocad Architecture wasn't available for 64 bit until 2009
and to get 2008 to install on a 64 bit OS was to do this workaround
DarrenP
hi i am vidya can i get the link for revit 2009 as i searched alot as my pc supports 32 bit only this is my mail id vidyamakehappy@gmail.com
Welcome to the Autodesk User's Community..
First you shouldn't really share your personal information here in an open forum.
Next that version of Revit is retired and no longer supported by Autodesk. There's no live download for it. If you never owned in the past you will not get a version of it. In addition if you're a student you are not entitled to that version either.
Mark Lancaster
& Autodesk Services MarketPlace Provider
