I have searched & completed all the suggestions from autodesk, the forums, & elsewhere
Windows 11
i9-10900X
32gb RAM
Quadro P2200
800gb free
I have downloaded the install & a custom with no luck.
Help!
Autodesk was installed but it was removed weeks ago (don't ask). Prior to trying to install, I removed all remnants via appwiz.cpl, deleted c:\autodesk, c:\program files\autodesk, c:\program files (x86)\autodesk
This is a known issue for years. However, a reboot will typically work. In this case, you can delete the PendingFileRenameOperations from the Registry
We typically, do this for Vault Installs as documented here: "Reboot Needed" when running Vault Server installation system check (autodesk.com)
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
I did not have the key. I did have the auto-update key again, which I removed & it started the install....but it got to 4%. Reversed itself & gave me Error 131133. Which I cannot find any records of?
I have tried all these solutions, but unfortunately, none have worked...is there anyway else to solve this problem?
PC/laptop wipe and reinstall/reimage if an all new user-login "start over" is not working either.
