I INSTALLED AUTODESK REVIT MEP AT TWO CUSTOMERS.
I HAVE ACTIVE A CUSTOMER WITH NO PROBLEM AT ALL. FOR THE SECOND CUSTOMER THE PAGE OF ACTIVATION IS WHITE. SEE ATTACHED FILE. I SPECIFY THAT ARE TWO DIFFERENT LICENSES. REGARDS
this has been discussed many times
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617
DarrenP
For more information on this known Autodesk Support Knowledge Base article, please follow this link:
Additional discussion about this issue can be found here:
http://forums.autodesk.com/t5/Installation-Licensing/Blank-Activation-Screen/td-p/2862508
