Solved by Mark.Lancaster. Go to Solution.
Solved by pendean. Go to Solution.
You are presenting a serial number of a cracked version ... in a forum of the vendor of that software, think about that ;(
- alfred -
welcome @forums.autodesk.com!
Have you seen post 24 of this thread? That is the solution, use it.
(In the forum here are users like you and I, we can't create activation codes, they can be only sent to you from Autodesk)
- alfred -
Hello Autodesk fourms,
please share an activation code for autocad 2010 (32 bit) as my windows got crashed somehow.
i am having my final submission next week.
i would be so much thankful to you. i am getting so much stress because of it.
thank you.
This is a public forum, please refrain from posting serial numbers or personal information
Edited by
Discussion_Admin
This here is a user forum, we users can't create an activation code.
You should to go the default way of online-activation when you start your product the first time after installation.
- alfred -
pls send the activation code to my email for autocad 2010
product key : 001B1
serial code : 667-98989898. Thanks 🙂
MY EMAIL ID IS ; tarun02dhaka@gmail.com
your serial is a cracked serial, uninstall and return the product to wherever you got it from.
- alfred -
pls send the activation code for autocad 2010
product key : 001B1
serial code : xxx-xxxxxxxx
Welcome to community...
Although the security aspect of the forum kicked in and "X" out your serial #.. However don't share personal information such as your serial # here. This is a world wide user forum.
At this point I can't tell if your serial # was legit or like others that have posted here.. You have cracked/illegal serial #. If this is a legal serial # and the serial # is still active, you can get your activation code from
However if this is a illegal serial # or its a cracked one, contacting Autodesk will most likely get you fined.. So I'm just warning you..
Mark Lancaster
& Autodesk Services MarketPlace Provider
Unfortunately, this is mainly a peer to peer network where users are assisting other users like yourself. We don't issue activation codes they come from Autodesk.
If you properly purchased this product like 17 to 19 years ago you would have a legit serial # and thus it could be activated without the need for you to come here looking for the users to give you an activation code. Since this product is so old, obsoleted, and no longer supported by Autodesk, may I ask where you got this from?
Mark Lancaster
First welcome to the community..
I guess you didn't read any of the replies here. This is a user base forum and we don't issue activation codes. If you have a legit serial # your activation will happen and there would be no need to come here.
Mark Lancaster
my Auto cad 2010 32bit serial no is xxx-xxxxxxxx
request code is 7VS4 ZP75 VDJZ C2RN 7P4J 6LR1 AS0U Q03Z
what is the product key
