Activation error 123
Dear Autodesk Education Team,
I’m trying to activate AutoCAD but get this error. Am I doing something wrong?
Also, when mailing via the Contact Customer Support link, the response from the mailserver is : Mailbox Full.
Otto
Hello ict
It looks like you are receiving Error 123 - "The serial number you entered is not valid for the product you are trying to activate."
For help with this issue, please contact Education Community Support.
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Darin.Green
@Anonymous
You're trying to install the software as a Standalone version. Instead, you need to install as a Network version because that's what your serial number was created for...
If this information was helpful, please consider using the Accept Solution
gmland
I'm having the same issues. I am a one man office, no network needed. I've tried installing it both ways and for the network option its asking me questions I have no idea how to answer. On my old computer it was a simple installation and started working right away, now I'm locked out of it and can't access it at all. Trying to get help from Autodesk is impossible, I just want to talk to someone and instead have to navigate a website that points you in every direction except for the simplest option.
