Access violation at address 01504207 in module 'SBD.exe'. Read of address 00000000
michael.maksour
Observer Observer
Message 1 of 9
michael.maksour
Observer
Observer
I keep receiving this error when I click on the "structure loads" tab.
Once the error pops up, I cannot proceed using the program.
Does anyone know how to rectify this issue?
I am using version 20.2.140.0.
Replies (8)
Message 2 of 9
leowarren34
Hi @michael.maksour,
What GPU are you running?
This article directly pertains to Structural Bridge Analysis so is probably a good start: https://knowledge.autodesk.com/support/structural-bridge-design/troubleshooting/caas/sfdcarticles/sf...
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 3 of 9
simon_hooper
Hi Michael
Does this error occur with a particular file?  If so please zip and attach so that we can investigate.
Simon
Simon Hooper
Software Development
Message 4 of 9
michael.maksour
Observer
Observer
Hi Simon,
See attached.
Message 5 of 9
simon_hooper
Hi Michael
Thanks for the file.  The problem seems to be in the definition of the longitudinal beams....I will see if I can repair.
Simon Hooper
Message 6 of 9
simon_hooper
Here is a version with the longitudinal beams cleared out.  I no longer get the AV.  You probably don't need to redefine the longitudinal beams in this non-standard grillage.
Simon Hooper
Message 7 of 9
simon_hooper
I attach the details of the original longitudinal beam elements in case needed (with the data in error removed)
Simon Hooper
Message 8 of 9
simon_hooper
We have put in a fix to soon to be released version to stop the AV.  Note that there was reference to a zero length member (which doesn't seem to exist)...
Simon
Simon Hooper
Message 9 of 9
michael.maksour
Observer
Observer
Many thanks Simon. You have saved me lots of trouble.
