I understand. That's called the "feature code".
It would make sense that you could use a more expensive Revit license to run
plain AutoCAD... but there's no such "hierarchy" in the license file
(AutoCAD <= Revit).
But, you said you had a few vanilla AutoCAD licenses. If so, you can
combine them with the Revit licenses to get at least some of the behavior
you want.
--Cy--
wrote in message news:4929156@discussion.autodesk.com...
Thx for the reply, but that doesn't help. That just gives me 1 lic. file.
The problem is the vanilla acad.exe is hardcoded to look for the string
"48800ACD_2006_0F" in the .lic file & the Acad/Revit series 8 acad.exe is
hardcoded to look for "50300REVITS_8_0F" I have vanilla acad.exe on all the
PC's so it doesn't know to look for "50300REVITS_8_0F"
