I am trying to launch Revit 2017, and I receive the same error each time I try to launch: " A software problem has caused Revit 2017 to close unexpectedly." I have tried to send a report to Autodesk and they sent to me an update file, I installed it but still the same message appears.
I have tried to reinstall alot of times. And i tried with at new autodesk user. But its still the same. Can any one help?
Solved by natasha.l. Go to Solution.
Solved by dembkod. Go to Solution.
@Anonymous
First welcome to the community..
Next the image of the Autodesk Crash Report is useless to us. I know that you sent the report information to Autodesk, but if you like I can review your crash report and hopefully I can pin point your problem. Please private message me if you want me to review your crash report. To private message me, hover over my aviator and select send message. Once I see your PM I will tell you your next step.
Mark Lancaster
& Autodesk Services MarketPlace Provider
I see you are crashing and that you have already uninstalled. However, there may be problems with the residuals that you did not know about. I would suggest the following:
C:\Program Files\Autodesk\Program Name
C:\Program Files (x86)\Autodesk
C:\ProgramData\Autodesk\Revit
C:\ProgramData\Autodesk\RVT
C:\Program Files\Common Files\Autodesk Shared
C:\Users\YOUR USERID\AppData\Local\Autodesk
C:\Users\YOUR USERID\AppData\Roaming\Autodesk
This should give you a pretty clean installation. At this stage I would also update the graphics drivers – can’t hurt.
Hello @Anonymous,
Just to add to this. Try reviewing the steps below usually this message is associated with one of these issues. Conduct one step and proceed to the other if it does not resolve it.
Thank you for posting.
Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Hello @Anonymous,
Have you resolved the issue? I hope you were able to resolve this error message with a suggestion that was provided. If not please let us know how you are doing and if you need some more help. Thanks.
Natasha
Helpful Links:
I had a similar issue on my Autodesk programs, and I came to find out it was a Microsoft.NET Framework 4.7 update behind it all. So if you see the same update around the time the error happened, you may want to uninstall the update version and reinstall version Microsoft.NET Framework 4.62. And wait for version 7.1 or higher before you update this version.
Good luck.
