I need the 64-bit installer for AutoCAD LT 2013 as I recently upgraded from WindowsXP to Windows7.
Solved by philip.s. Go to Solution.
Solved by pendean. Go to Solution.
If you are just looking for a product download you should be able to find it at the Autodesk Customer Service Virtual Agent:
1. Go to http://www.autodesk.com
2. Click on Contact Us at the bottom of the page
3. Click on Customer Service
4. Click on Virtual Agent “Ask”
5. Once the Virtual Agent window opens: Select the choice "Download Links".
6. Select your product, then variant, then version as applicable.
7. You should now be presented with the choice to download your software.
Please let me know how to installed the 64-bit installer.
I could not find out the download way.
Hi Ray!
To download supported current and previous version software from the Autodesk Virtual Agent (also linked in our How to download or re-download software solution), simply click on the Download Links option and select your product.
Here to help if additional clarification is needed, otherwise please accept as a solution so that others can benefit from this information.
Hi Ray!
Hello @Anonymous and welcome to the Autodesk Community!
Can you please provide some additional info so that I can troubleshoot accordingly. Are you a student? Did you purchase a license and are unable to recover it? Let me know!
I cannot find a 64bit installer program to install Autocad Electrical 2015.
Welcome to the community @Anonymous!
Did you try downloading from the previously mentioned Autodesk Virtual Agent (also linked in our How to download or re-download software solution) by simply clicking on the Download Links option and select your product?
I want to install Autodesk DWG Trueview 2015 to convert my drawings to 2010 and it doesn't want to installed.
there is a message tells me that i'm using a 32-bit installer on a 64-bit OS.
how to solve it ?
how to solve it ?
Where can I find the Virtual Agent "Ask"? I can find it after I clicked the Customer Service.
HI , ive dowloaded auto cad 2014 64 bit but cant install it on my windows 10.please how do i rectify this situation.
@Anonymous
Welcome to the community and hopefully my (or someone else) reply will be beneficially to you.
Not sure if you knew this or not, but this is a worldwide (public) user forum where users are assisting others. For future postings, do not include any personal information (such as your serial #) in any information that you share (include screen shots) with us.
Offically AutoCAd 2014 is not supported under Windows 10 but others have it running. When you say "can't install it". What's the problem? Give us details of why you can't install it. Are there any error messages?
Mark Lancaster
& Autodesk Services MarketPlace Provider
@Anonymous
Mark Lancaster
Dear Sir, following the issue "required for 64 Bit Installer"
I went to the link, searched for product Autocad 2017 but it appeared to be as follow:
[An error occurred while processing your request.
Reference #50.6f011a3a.1469246391.d75a9b3]
Please advise on what should i do next...
