Installation & Licensing
3dsmax 2017 mentalray.dlz on Windows 10
12 REPLIES 12
Message 1 of 13
ariodeh
3759 Views, 12 Replies
I downloaded 3dsmax 2017 demo, and installed on Windows 10. The program was running fine, everything was works. Untill one day I started max, and mentalray.dlz failed to initialize (error 127) specific procedure cannot be found.
I did try to reinstall max, delete all user data but it's still give me an erorr 127 for mentalray.dlz.
Next, I tried to reinstall all VC Redist 2005,2008,2010,2012,2013,2015 and .Net repair.....still no change....
Uninstall windows update and try the windows restore point..... still give error 127 for mentalray.dlz
I downloaded fresh copy 3dsmax 2017 demo, and try fresh installation still give me error 127....
Already did sfc /scannow and dism /restorehealth and the result is good (no windows file system violations)
Try to uninstall mentalray, and reinstall the renderer and plugin feature (found in 3dsmax installation folder) still no luck....
Can anyone help me on this ??
Thank You
12 REPLIES 12
Message 2 of 13
Otto
in reply to: ariodeh
Hello ariodeh and welcome to the Autodesk community!
It looks like you are seeing Error 127. The following article(s) should help you resolve the problem:
How to reset AutoCAD to defaults
Alternatively, please make sure you have the latest service pack installed before attempting to install the software.
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 13
asburyj
in reply to: Otto
Based on the troubleshooting you've done it doesn't sound like a corrupt install. You may want to try resetting your 3ds max settings.  Also, if you have recently installed any firewall or security software make sure it isn't blocking port 7000-7001.
Jeffry Asbury
Message 4 of 13
kthalas
Hi! I have the same issue. Any advice?
Message 5 of 13
Hi @ariodeh,
I know this is a very late response, but I saw your thread and wanted to see if this suggestion might help.
If possible, try copying all of the contents from Plugins\NVIDIA\Bin folder directly in the root directory: C:\Program Files\Autodesk\3ds Max 2017. (Do not Cut the contents from the folder.) Start 3ds Max again and the error should not appear.
Hopefully this will help, as this happened on my machine previously. I copying and pasting these contents I was finally able to get mentalray and iray installed and working great with no mentalray.dlz error.
Thanks!
Please Accept as Solution if a reply has helped resolved the issue or answered your question, to help others in the community.
Kindest regards,
Dominique Bouthillette
Principal Specialist, Industry Support & Escalation
Entertainment & Media Solutions
Message 6 of 13
I tried to reinstall 3ds max and this error still remains 😞
I am not sure why it was so important to discard mental ray from 3ds max
because right now I have none...
I tried reinstalled it, remove it, install service pack, remove it, move the file from plugins/Nvidia to the max root.
Nothing helped.
Message 7 of 13
natasha.l
in reply to: panfotograf
Hello @panfotograf,
Sorry for the inconvenience. It seems like you had it installed already and you removed it. This is a known issue that can be resolved by conducting one of the following.
  1. Install 3ds Max again and make sure you have selected during the install in the drop down. In the "Control Panel" sort by date make sure you have it installed on your system.
2. If you have selected it then try Resetting 3ds Max / 3ds Max Design to default user profile settings
Please let me know how it goes. Smiley Happy
Message 8 of 13
natasha.l
Hello @panfotograf,
Let us know if you resolved the issue and need further assistance with this.
Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
Message 9 of 13
AtleOdegaard
in reply to: natasha.l
I have the same issue, it happened after unstalling the new security fix last night. Have tried uninstalling/reinstalling 3ds max, resetting 3ds max to default, copying plugin files to root folder, reinstalling mentalray / iray plugins.
The "missing" file is indeed present in its appropriate folder.
Message 10 of 13
AtleOdegaard
Any news on this one? I guess the next step to try is the completely clean uninstall explained in natashal84 's signature link, I just would like to know if there is any hope it will solve the problem.
Message 11 of 13
jon.bell
in reply to: AtleOdegaard
@AtleOdegaard,
Have you tried downloading and installing the newest version of mental ray (3.14.1.4) from your Autodesk Account?
Please let us know if this helps!
Best regards,
Jon A. Bell
Autodesk Technical Support
Jon A. Bell
Senior Technical Support Specialist, 3ds Max
Message 12 of 13
AtleOdegaard
in reply to: jon.bell
Thank you for your follow-up. It turned out I had installed the wrong version of mental ray. I thought I had to use the SP3 one for my perpetual license, which I now discovered was not the case. Works like a charm now!
Message 13 of 13
That didn't work for me, but what DID work was copying "mentalray.dlz" from the installer folder:
\x64\Mentalray\Program Files\Autodesk\Plugins\NVIDIA\Plugins
to this location, replacing the file that was already there: C:\Program Files\Autodesk\3ds Max 2017\Plugins\NVIDIA\Plugins
error gone and now able to render with mental ray and my mental ray proxies are rendering (which they would not before)
Administrator Productivity
