3ds max installing and opening problem.
Here I have 2 problem which is Opening and Installing problem.
First is the installing problem, I use download now and i get Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_wi_en-US_Setup_webinstall.exe
When I open this webinstall and even i use administrator, it never show anything, look like when i open it auto close down.
After that I use Browser download
After i use this browser download it will auto download 2gb file, Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_001_002.sfx.exe
But after finish and i open it also nothing happen.
Last I use download now
It give me a AutodeskDownloadManagerSetup.exe
After done install this download manager, it will auto help me download the 7GB+ 3ds Max 2017.
After finish this 3ds Max 2017 setup and after i install this setup, the problem come up which is opening problem.
when I open the 3dsmax.exe
It come up a startup and after few second it will auto close down like i never open it before.
I don know why every time i reinstall this 3ds max, at the end i will get the same thing.
Can I know the problem?
Thank you.
This is a public forum, please refrain from posting serial numbers or personal information
Edited by
Discussion_Admin
natasha.l
Hello @Anonymous,
Thank you for taking part in the community, I understand you are having issues installing your 3ds Max 2017 software. I will need some more information, please locate your Windows TEMP folder. You can do this by going to the Windows Start > type Run in search box (shortcut Win.key+R) and typing %TEMP% into the box and clicking OK.
Sort by Date or Name and find the Autodesk product and save the installation ____.log file. Please attach this file to your reply.
This will help us determine the possible issue preventing you from installing your software.
natasha.l
Hello @Anonymous,
At this point, I can provide a workaround for this issue since I do not have a log file.
You can download your software via the Autodesk Virtual Agent.
Please proceed as follows:
  • Logon as an Administrator.
  • Empty your TEMP folder.  To open the TEMP folder, type %TEMP% in the address bar of Windows Explorer and hit Enter.
  • Disable your Antivirus software.
  • Disable UAC.
W7: http://windows.microsoft.com/en-ca/windows7/turn-user-account-control-on-or-off
W10: http://winaero.com/blog/how-to-turn-off-and-disable-uac-in-windows-10/
  • Download all of the parts
  • Locate the download folder and extract (double click) part _001_00X.sfx.exe. If you have a permission issue right click and select, Run as administrator.
  • Files will be directed to C:\Autodesk
  • Follow the prompts to install the program
I hope this answered your question or resolved the issue, if so please click Kudos or the "thumbs-up!" Did my response help resolve the issue? Please "Accept As Solution" to help others in the community.
