hello i m trying to install education version of this but having this error pls help. 2016/5/31:00:48:01 ASUS DESKTOP-67ITT8B === Setup started on DESKTOP-67ITT8B by ASUS === 2016/5/31:00:48:01 ASUS DESKTOP-67ITT8B Path_Length: 148 2016/5/31:00:48:01 ASUS DESKTOP-67ITT8B Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-US 2016/5/31:00:48:01 ASUS DESKTOP-67ITT8B Launch 2016/5/31:00:48:01 ASUS DESKTOP-67ITT8B CommandLine /akamai /sid a1b3A000009A2MZQA0 /skipEULA /skipPI /url "
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_... 2016/5/31:00:48:01 ASUS DESKTOP-67ITT8B Path_Length: 148 2016/5/31:00:48:01 ASUS DESKTOP-67ITT8B Current Directory C:\Users\ASUS\AppData\Local\Temp\_AIEC80.tmp 2016/5/31:00:48:18 ASUS DESKTOP-67ITT8B === Setup ended === 2016/5/31:00:48:02 ASUS DESKTOP-67ITT8B === Setup started on DESKTOP-67ITT8B by ASUS === 2016/5/31:00:48:02 ASUS DESKTOP-67ITT8B Path_Length: 148 2016/5/31:00:48:02 ASUS DESKTOP-67ITT8B Current Directory C:\Users\ASUS\AppData\Local\Temp\_AIEC80.tmp 2016/5/31:00:48:02 ASUS DESKTOP-67ITT8B Launch 2016/5/31:00:48:03 ASUS DESKTOP-67ITT8B Download Play SETUP_CONFIG
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SET... 2016/5/31:00:48:18 ASUS DESKTOP-67ITT8B Download Complete SETUP_CONFIG
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SET... 2016/5/31:00:48:18 ASUS DESKTOP-67ITT8B PageOpen LaunchDialog 2016/5/31:00:48:24 ASUS DESKTOP-67ITT8B PageOpen LicenseDialog 2016/5/31:00:48:24 ASUS DESKTOP-67ITT8B PageOpen ProductSelectionDialog2 2016/5/31:00:48:52 ASUS DESKTOP-67ITT8B PageOpen FullProgressDialog 2016/5/31:00:48:52 ASUS DESKTOP-67ITT8B Installing Autodesk® 3ds Max 2015 SDK: TRANSFORMS="C:\Users\ASUS\AppData\Local\Temp\_AIEC80.tmp\x64\Tools\MAXSDK\SDK_3DSMAX2015-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" INSTALLDIR="D:\3ds Max 2015 SDK\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/5/31:00:49:09 ASUS DESKTOP-67ITT8B Install Autodesk® 3ds Max 2015 SDK Succeeded 2016/5/31:00:49:09 ASUS DESKTOP-67ITT8B Installing Network License Manager: ALLUSERS=1 INSTALLDIR="D:\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/5/31:00:49:09 ASUS DESKTOP-67ITT8B Install Network License Manager Succeeded 2016/5/31:00:49:09 ASUS DESKTOP-67ITT8B PageOpen InstallCompleteDialog 2016/5/31:00:49:17 ASUS DESKTOP-67ITT8B === Setup ended === 2016/5/31:00:51:18 ASUS DESKTOP-67ITT8B === Setup started on DESKTOP-67ITT8B by ASUS === 2016/5/31:00:51:18 ASUS DESKTOP-67ITT8B Path_Length: 148 2016/5/31:00:51:18 ASUS DESKTOP-67ITT8B Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-US 2016/5/31:00:51:18 ASUS DESKTOP-67ITT8B Launch 2016/5/31:00:51:18 ASUS DESKTOP-67ITT8B CommandLine /akamai /sid a1b3A000009A2MZQA0 /skipEULA /skipPI /url "
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_... 2016/5/31:00:51:18 ASUS DESKTOP-67ITT8B Path_Length: 148 2016/5/31:00:51:18 ASUS DESKTOP-67ITT8B Current Directory C:\Users\ASUS\AppData\Local\Temp\_AIEF21.tmp 2016/5/31:00:51:20 ASUS DESKTOP-67ITT8B === Setup ended === 2016/5/31:00:51:19 ASUS DESKTOP-67ITT8B === Setup started on DESKTOP-67ITT8B by ASUS === 2016/5/31:00:51:19 ASUS DESKTOP-67ITT8B Path_Length: 148 2016/5/31:00:51:19 ASUS DESKTOP-67ITT8B Current Directory C:\Users\ASUS\AppData\Local\Temp\_AIEF21.tmp 2016/5/31:00:51:19 ASUS DESKTOP-67ITT8B Launch 2016/5/31:00:51:19 ASUS DESKTOP-67ITT8B Download Skipped SETUP_CONFIG
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SET... 2016/5/31:00:51:20 ASUS DESKTOP-67ITT8B PageOpen LaunchDialog 2016/5/31:00:51:29 ASUS DESKTOP-67ITT8B PageOpen LicenseDialog 2016/5/31:00:51:29 ASUS DESKTOP-67ITT8B PageOpen ProductInfoDialog 2016/5/31:00:52:11 ASUS DESKTOP-67ITT8B PageOpen ProductSelectionDialog2 2016/5/31:00:52:27 ASUS DESKTOP-67ITT8B PageOpen FullProgressDialog 2016/5/31:00:52:28 ASUS DESKTOP-67ITT8B Download Play VCREDIST2005SP1ATLX86
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR... 2016/5/31:00:52:30 ASUS DESKTOP-67ITT8B Download Complete VCREDIST2005SP1ATLX86
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR... 2016/5/31:00:52:30 ASUS DESKTOP-67ITT8B Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ASUS\AppData\Local\Temp\vcredist_x86_2005.log"" " 2016/5/31:00:52:34 ASUS DESKTOP-67ITT8B Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded 2016/5/31:00:52:35 ASUS DESKTOP-67ITT8B Download Play VCREDIST2005SP1ATLX64
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR... 2016/5/31:00:52:37 ASUS DESKTOP-67ITT8B Download Complete VCREDIST2005SP1ATLX64
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR... 2016/5/31:00:52:37 ASUS DESKTOP-67ITT8B Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ASUS\AppData\Local\Temp\vcredist_x64_2005.log"" " 2016/5/31:00:52:41 ASUS DESKTOP-67ITT8B Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded 2016/5/31:00:52:41 ASUS DESKTOP-67ITT8B Download Play VCREDIST2008SP1X86
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR... 2016/5/31:00:52:45 ASUS DESKTOP-67ITT8B Download Complete VCREDIST2008SP1X86
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR... 2016/5/31:00:52:45 ASUS DESKTOP-67ITT8B Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q 2016/5/31:00:52:52 ASUS DESKTOP-67ITT8B Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded 2016/5/31:00:52:53 ASUS DESKTOP-67ITT8B Download Play VCREDIST2008SP1X64
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR... 2016/5/31:00:52:56 ASUS DESKTOP-67ITT8B Download Complete VCREDIST2008SP1X64
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR... 2016/5/31:00:52:56 ASUS DESKTOP-67ITT8B Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q 2016/5/31:00:53:02 ASUS DESKTOP-67ITT8B Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded 2016/5/31:00:53:03 ASUS DESKTOP-67ITT8B Download Play VCREDIST2012X86
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR... 2016/5/31:00:53:07 ASUS DESKTOP-67ITT8B Download Complete VCREDIST2012X86
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR... 2016/5/31:00:53:07 ASUS DESKTOP-67ITT8B Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart 2016/5/31:00:53:14 ASUS DESKTOP-67ITT8B Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded 2016/5/31:00:53:15 ASUS DESKTOP-67ITT8B Download Play VCREDIST2012X64
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR... 2016/5/31:00:53:18 ASUS DESKTOP-67ITT8B Download Complete VCREDIST2012X64
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR... 2016/5/31:00:53:18 ASUS DESKTOP-67ITT8B Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart 2016/5/31:00:53:26 ASUS DESKTOP-67ITT8B Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded 2016/5/31:00:53:26 ASUS DESKTOP-67ITT8B Download Play DIRECTX
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIR... 2016/5/31:00:53:29 ASUS DESKTOP-67ITT8B Download Complete DIRECTX
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIR... 2016/5/31:00:53:29 ASUS DESKTOP-67ITT8B Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\DirectX\DXSETUP.exe" /silent 2016/5/31:00:53:32 ASUS DESKTOP-67ITT8B Install DirectX® Runtime Succeeded 2016/5/31:00:53:32 ASUS DESKTOP-67ITT8B Download Play CM
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.... 2016/5/31:00:53:50 ASUS DESKTOP-67ITT8B Download Aborted CM
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.... 2016/5/31:00:53:50 ASUS DESKTOP-67ITT8B Install Autodesk® Material Library 2015 Failed Download Failed, Installation aborted, Result=1603 2016/5/31:00:53:50 ASUS DESKTOP-67ITT8B Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2016/5/31:00:53:50 ASUS DESKTOP-67ITT8B Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619 2016/5/31:00:53:50 ASUS DESKTOP-67ITT8B Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619 2016/5/31:00:53:50 ASUS DESKTOP-67ITT8B Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1619 2016/5/31:00:53:50 ASUS DESKTOP-67ITT8B Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1619 2016/5/31:00:53:50 ASUS DESKTOP-67ITT8B Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619 2016/5/31:00:53:50 ASUS DESKTOP-67ITT8B Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619 2016/5/31:01:07:09 ASUS DESKTOP-67ITT8B === Setup started on DESKTOP-67ITT8B by ASUS === 2016/5/31:01:07:09 ASUS DESKTOP-67ITT8B Path_Length: 148 2016/5/31:01:07:09 ASUS DESKTOP-67ITT8B Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-US 2016/5/31:01:07:09 ASUS DESKTOP-67ITT8B Launch 2016/5/31:01:07:09 ASUS DESKTOP-67ITT8B CommandLine /akamai /sid a1b3A000009A2TLQA0 /skipEULA /skipPI /url "
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_... 2016/5/31:01:07:09 ASUS DESKTOP-67ITT8B Path_Length: 148 2016/5/31:01:07:09 ASUS DESKTOP-67ITT8B Current Directory C:\Users\ASUS\AppData\Local\Temp\_AIE881.tmp 2016/5/31:01:07:10 ASUS DESKTOP-67ITT8B === Setup ended === 2016/5/31:01:07:09 ASUS DESKTOP-67ITT8B === Setup started on DESKTOP-67ITT8B by ASUS === 2016/5/31:01:07:09 ASUS DESKTOP-67ITT8B Path_Length: 148 2016/5/31:01:07:09 ASUS DESKTOP-67ITT8B Current Directory C:\Users\ASUS\AppData\Local\Temp\_AIE881.tmp 2016/5/31:01:07:09 ASUS DESKTOP-67ITT8B Launch 2016/5/31:01:07:10 ASUS DESKTOP-67ITT8B Download Skipped SETUP_CONFIG
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SET... 2016/5/31:01:07:10 ASUS DESKTOP-67ITT8B PageOpen LaunchDialog 2016/5/31:01:07:15 ASUS DESKTOP-67ITT8B PageOpen LicenseDialog 2016/5/31:01:07:15 ASUS DESKTOP-67ITT8B PageOpen ProductInfoDialog 2016/5/31:01:07:43 ASUS DESKTOP-67ITT8B PageOpen ProductSelectionDialog2 2016/5/31:01:08:08 ASUS DESKTOP-67ITT8B PageOpen FullProgressDialog 2016/5/31:01:08:08 ASUS DESKTOP-67ITT8B Download Skipped VCREDIST2005SP1ATLX86
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR... 2016/5/31:01:08:09 ASUS DESKTOP-67ITT8B Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ASUS\AppData\Local\Temp\vcredist_x86_2005.log"" " 2016/5/31:01:08:13 ASUS DESKTOP-67ITT8B Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded 2016/5/31:01:08:13 ASUS DESKTOP-67ITT8B Download Skipped VCREDIST2005SP1ATLX64
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR... 2016/5/31:01:08:13 ASUS DESKTOP-67ITT8B Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ASUS\AppData\Local\Temp\vcredist_x64_2005.log"" " 2016/5/31:01:08:16 ASUS DESKTOP-67ITT8B Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded 2016/5/31:01:08:16 ASUS DESKTOP-67ITT8B Download Skipped VCREDIST2008SP1X86
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR... 2016/5/31:01:08:16 ASUS DESKTOP-67ITT8B Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q 2016/5/31:01:08:20 ASUS DESKTOP-67ITT8B Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded 2016/5/31:01:08:20 ASUS DESKTOP-67ITT8B Download Skipped VCREDIST2008SP1X64
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR... 2016/5/31:01:08:20 ASUS DESKTOP-67ITT8B Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q 2016/5/31:01:08:23 ASUS DESKTOP-67ITT8B Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded 2016/5/31:01:08:25 ASUS DESKTOP-67ITT8B Download Play VCREDIST2010SP1X86
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR... 2016/5/31:01:08:29 ASUS DESKTOP-67ITT8B Download Complete VCREDIST2010SP1X86
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR... 2016/5/31:01:08:29 ASUS DESKTOP-67ITT8B Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart 2016/5/31:01:08:35 ASUS DESKTOP-67ITT8B Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded 2016/5/31:01:08:35 ASUS DESKTOP-67ITT8B Download Play VCREDIST2010SP1X64
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR... 2016/5/31:01:08:38 ASUS DESKTOP-67ITT8B Download Complete VCREDIST2010SP1X64
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR... 2016/5/31:01:08:38 ASUS DESKTOP-67ITT8B Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart 2016/5/31:01:08:44 ASUS DESKTOP-67ITT8B Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded 2016/5/31:01:08:44 ASUS DESKTOP-67ITT8B Download Skipped VCREDIST2012X86
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR... 2016/5/31:01:08:44 ASUS DESKTOP-67ITT8B Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart 2016/5/31:01:08:47 ASUS DESKTOP-67ITT8B Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded 2016/5/31:01:08:47 ASUS DESKTOP-67ITT8B Download Skipped VCREDIST2012X64
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR... 2016/5/31:01:08:47 ASUS DESKTOP-67ITT8B Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart 2016/5/31:01:08:49 ASUS DESKTOP-67ITT8B Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded 2016/5/31:01:08:49 ASUS DESKTOP-67ITT8B Download Skipped DIRECTX
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIR... 2016/5/31:01:08:49 ASUS DESKTOP-67ITT8B Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\DirectX\DXSETUP.exe" /silent 2016/5/31:01:08:52 ASUS DESKTOP-67ITT8B Install DirectX® Runtime Succeeded 2016/5/31:01:08:52 ASUS DESKTOP-67ITT8B Download Play CM
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.... 2016/5/31:01:09:08 ASUS DESKTOP-67ITT8B Download Complete CM
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.... 2016/5/31:01:09:08 ASUS DESKTOP-67ITT8B Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/5/31:01:09:18 ASUS DESKTOP-67ITT8B Install Autodesk® Material Library 2015 Succeeded 2016/5/31:01:09:18 ASUS DESKTOP-67ITT8B Download Play CMILB
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMI... 2016/5/31:01:09:40 ASUS DESKTOP-67ITT8B Download Complete CMILB
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMI... 2016/5/31:01:09:40 ASUS DESKTOP-67ITT8B Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/5/31:01:09:46 ASUS DESKTOP-67ITT8B Install Autodesk® Material Library 2015 - Base Image Library Succeeded 2016/5/31:01:09:47 ASUS DESKTOP-67ITT8B Download Play CMILM
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMI... 2016/5/31:01:14:40 ASUS DESKTOP-67ITT8B Download Aborted CMILM
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMI... 2016/5/31:01:14:40 ASUS DESKTOP-67ITT8B Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603 2016/5/31:01:14:46 ASUS DESKTOP-67ITT8B Rollback Autodesk® Material Library 2015 - Base Image Library Succeeded 2016/5/31:01:15:01 ASUS DESKTOP-67ITT8B Rollback Autodesk® Material Library 2015 Succeeded 2016/5/31:01:15:01 ASUS DESKTOP-67ITT8B Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2016/5/31:01:15:01 ASUS DESKTOP-67ITT8B Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619 2016/5/31:01:15:01 ASUS DESKTOP-67ITT8B Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619 2016/5/31:01:15:01 ASUS DESKTOP-67ITT8B Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619 2016/5/31:01:15:01 ASUS DESKTOP-67ITT8B Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619 2016/5/31:01:15:01 ASUS DESKTOP-67ITT8B Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1619 2016/5/31:01:15:01 ASUS DESKTOP-67ITT8B Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1619 2016/5/31:01:15:01 ASUS DESKTOP-67ITT8B Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619 2016/5/31:01:15:01 ASUS DESKTOP-67ITT8B Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619 2016/5/31:01:15:02 ASUS DESKTOP-67ITT8B PageOpen InstallCompleteDialog 2016/5/31:01:16:52 ASUS DESKTOP-67ITT8B === Setup ended === 2016/5/31:17:55:35 ASUS DESKTOP-67ITT8B === Setup started on DESKTOP-67ITT8B by ASUS === 2016/5/31:17:55:35 ASUS DESKTOP-67ITT8B Path_Length: 148 2016/5/31:17:55:35 ASUS DESKTOP-67ITT8B Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-US 2016/5/31:17:55:35 ASUS DESKTOP-67ITT8B Launch 2016/5/31:17:55:35 ASUS DESKTOP-67ITT8B CommandLine /akamai /sid a1b3A000009AEzxQAG /skipEULA /skipPI /url "
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_... 2016/5/31:17:55:35 ASUS DESKTOP-67ITT8B Path_Length: 148 2016/5/31:17:55:35 ASUS DESKTOP-67ITT8B Current Directory C:\Users\ASUS\AppData\Local\Temp\_AI29E6.tmp 2016/5/31:17:55:38 ASUS DESKTOP-67ITT8B === Setup ended === 2016/5/31:17:55:36 ASUS DESKTOP-67ITT8B === Setup started on DESKTOP-67ITT8B by ASUS === 2016/5/31:17:55:36 ASUS DESKTOP-67ITT8B Path_Length: 148 2016/5/31:17:55:36 ASUS DESKTOP-67ITT8B Current Directory C:\Users\ASUS\AppData\Local\Temp\_AI29E6.tmp 2016/5/31:17:55:36 ASUS DESKTOP-67ITT8B Launch 2016/5/31:17:55:36 ASUS DESKTOP-67ITT8B Download Skipped SETUP_CONFIG
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SET... 2016/5/31:17:55:36 ASUS DESKTOP-67ITT8B PageOpen LaunchDialog 2016/5/31:17:56:08 ASUS DESKTOP-67ITT8B PageOpen LicenseDialog 2016/5/31:17:56:08 ASUS DESKTOP-67ITT8B PageOpen ProductInfoDialog 2016/5/31:17:56:39 ASUS DESKTOP-67ITT8B PageOpen ProductSelectionDialog2 2016/5/31:17:56:54 ASUS DESKTOP-67ITT8B PageOpen FullProgressDialog 2016/5/31:17:56:54 ASUS DESKTOP-67ITT8B Download Skipped VCREDIST2012X86
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR... 2016/5/31:17:56:54 ASUS DESKTOP-67ITT8B Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart 2016/5/31:17:56:55 ASUS DESKTOP-67ITT8B Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded 2016/5/31:17:56:55 ASUS DESKTOP-67ITT8B Download Skipped VCREDIST2012X64
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR... 2016/5/31:17:56:55 ASUS DESKTOP-67ITT8B Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart 2016/5/31:17:56:55 ASUS DESKTOP-67ITT8B Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded 2016/5/31:17:56:56 ASUS DESKTOP-67ITT8B Download Skipped DIRECTX
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIR... 2016/5/31:17:56:56 ASUS DESKTOP-67ITT8B Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\DirectX\DXSETUP.exe" /silent 2016/5/31:17:56:58 ASUS DESKTOP-67ITT8B Install DirectX® Runtime Succeeded 2016/5/31:17:56:58 ASUS DESKTOP-67ITT8B Download Skipped CM
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.... 2016/5/31:17:56:58 ASUS DESKTOP-67ITT8B Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/5/31:17:57:15 ASUS DESKTOP-67ITT8B Install Autodesk® Material Library 2015 Succeeded 2016/5/31:17:57:15 ASUS DESKTOP-67ITT8B Download Skipped CMILB
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMI... 2016/5/31:17:57:15 ASUS DESKTOP-67ITT8B Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/5/31:17:57:39 ASUS DESKTOP-67ITT8B Install Autodesk® Material Library 2015 - Base Image Library Succeeded 2016/5/31:17:57:42 ASUS DESKTOP-67ITT8B Download Play CMILM
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMI... 2016/5/31:18:02:22 ASUS DESKTOP-67ITT8B Download Aborted CMILM
http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMI... 2016/5/31:18:02:22 ASUS DESKTOP-67ITT8B Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603 2016/5/31:18:02:29 ASUS DESKTOP-67ITT8B Rollback Autodesk® Material Library 2015 - Base Image Library Succeeded 2016/5/31:18:02:43 ASUS DESKTOP-67ITT8B Rollback Autodesk® Material Library 2015 Succeeded 2016/5/31:18:02:43 ASUS DESKTOP-67ITT8B Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2016/5/31:18:02:43 ASUS DESKTOP-67ITT8B Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619 2016/5/31:18:02:43 ASUS DESKTOP-67ITT8B Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
