Installation & Licensing
3ds max 2014 student version shows error
3 REPLIES 3
356 Views, 3 Replies
i installed 3ds max 2014 student version
download and installation was totally proper
but when i click on the max icon
it shows a error
here is the screen shot.
what should i do?
3 REPLIES 3
Darin.Green
Right-click the shortcut, and choose Properties. Navigate to the Compatibility tab and change the compatibility mode to Windows 7 or Vista SP1 then try launching the application again.
If this information was helpful, please consider using the Accept Solution
in reply to: Darin.Green
still its the same
Darin.Green
Try each of the following and test whether or not MAX will open after each change:
  1. Run a repair on the application, then try starting MAX.
  2. Check the following registry key to see if the LoadAppInit_DLLs key is set to 1, if so change it to 0
    • HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows
  3. Log in as a different user to see if the application will run.
Administrator Productivity
