3D Studio Max issues
3d Studio Max 2017 Student (on Windows 10) crashes. Either the program just freezes and it's not possible to click on anything or it says "program doesn't answer" and it looks like it is trying to load something.
I'm getting a lot of different error messeges in the event viewer under program and system. At first there was only one error when the program froze and then I changed the driver settings in 3ds and it started working (it was as if the program was overloaded when zooming in too quickly or using materials etc). After that it worked for about a week and then it started crashing and I got a bunch of new errors. I did all the things listed on "
Troubleshooting 3ds Max problems when running under Windows 10" and I also updated the graphic drivers.
At one point I got warnings when it was about to start and then I clicked ok and it started, and froze. I can't remember what it said and I don't get it now (without changing anything)
Now it crashed after I open a file (new or saved).
I have this laptop https://rog.asus.com/articles/news/asus-introduces-the-republic-of-gamers-g750-laptop/
Here are some of the recent error messages (They are in Swedish and I have absolutely no idea how to translate. I don't know much about computers).
Programmet 3dsmax.exe, version 19.2.472.0, avslutades eftersom det slutade samverka med Windows. Ytterligare information kan finnas i problemhistoriken i Säkerhet och underhåll på Kontrollpanelen.
Process-ID: 2784
Starttid: 01d2ce78a04e6087
Avslutningstid: 30
Programsökväg: C:\Program Files\Autodesk\3ds Max 2017\3dsmax.exe
Rapport-ID: 3ea9f6b2-3a79-11e7-88ea-bcee7b1807ec
Fullständigt namn på felaktigt paket:
Program-ID relativt till felaktigt paket:
Unable to recover from a kernel exception. The application must close.
Error code: 3 (subcode 7)
(pid=8524 tid=4236 3dsmax.exe 64bit)
Visit http://www.nvidia.com/page/support.html for more information.
Servern {AB8902B4-09CA-4BB6-B78D-A8F59079A8D5} registrerades inte med DCOM inom erforderlig timeout.
Application: 3dsmax.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.AccessViolationException
at <Module>.AppUI.RunNonBlockingMessageLoop(AppUI*)
at <Module>.AppUI.RunMessageLoop(AppUI*)
at <Module>.wWinMainCRTStartup()
Felet uppstod i programmet med namn: 3dsmax.exe, version 19.2.472.0, tidsstämpel 0x5784122b
, felet uppstod i modulen med namn: ntdll.dll, version 10.0.14393.479, tidsstämpel 0x5825887f
Undantagskod: 0xc0000374
Felförskjutning: 0x00000000000f8283
Process-ID: 0x22c8
Programmets starttid: 0x01d2cda94c1b3388
Sökväg till program: C:\Program Files\Autodesk\3ds Max 2017\3dsmax.exe
Sökväg till modul: C:\WINDOWS\SYSTEM32\ntdll.dll
Rapport-ID: a0b2824a-f458-4cdd-9a15-9407967e3ea5
Felet uppstod i programmet med namn: WSCommCntr4.exe, version 4.0.3.0, tidsstämpel 0x558a3b31
, felet uppstod i modulen med namn: ucrtbase.dll, version 10.0.14393.0, tidsstämpel 0x578997b5
Undantagskod: 0xc0000409
Felförskjutning: 0x000000000006ea1e
Process-ID: 0x1ef4
Programmets starttid: 0x01d2cda677c92a9b
Sökväg till program: C:\Program Files\Common Files\Autodesk Shared\WSCommCntr4\Lib\WSCommCntr4.exe
Sökväg till modul: C:\WINDOWS\System32\ucrtbase.dll
Rapport-ID: 01160dc8-75eb-44a6-b6ea-7a2000158c06
Anropet OnIdentity() i systemskrivarobjektet misslyckades för tjänsten Cryptographic Services.
Details:
AddLegacyDriverFiles: Unable to back up image of binary Microsoft Link-Layer Discovery Protocol.
System Error:
Åtkomst nekad.
Program-popup: vrlservice.exe: Start Error : WibuKey runtime system is not installed!
Grafikdrivrutinen nvlddmkm slutade svara och har återställts.
Det gick inte att aktivera filsystemfiltret wcifs (version 10.0, ‎2016‎-‎09‎-‎15T18:42:03.000000000Z) på volymen \Device\HarddiskVolumeShadowCopy1. Filtret returnerade status 0xC000000D som inte är standard. Det här filtret och/eller dess stödprogram bör hantera problemet. Kontakta återförsäljaren om problemet kvarstår.
Behörighetsinställningarna programspecifik ger inte Lokal behörigheten Aktivering för COM-serverprogrammet med CLSID
{D63B10C5-BB46-4990-A94F-E40B9D520160}
och APPID
{9CA88EE3-ACB7-47C8-AFC4-AB702511C276}
till användaren NT instans\SYSTEM SID (S-1-5-18) från adress LocalHost (med LRPC) som körs i programbehållaren Inte tillgänglig SID (Inte tillgänglig).
Det går att ändra säkerhetsbehörigheten med hjälp av administrationsverktyget Komponenttjänster.
: Den inbäddade styrenheten (EC) returnerade data när det inte begärdes. Det kan bero på att BIOS försöker få åtkomst till styrenheten utan att synkronisera med operativsystemet. Data kommer att ignoreras. Du behöver inte göra något mer, men du bör be datortillverkaren om en BIOS-uppgradering.
Felet uppstod i programmet med namn: SystemSettings.exe, version 10.0.14393.82, tidsstämpel 0x57a55dc6
, felet uppstod i modulen med namn: KERNELBASE.dll, version 10.0.14393.1198, tidsstämpel 0x5902808f
Undantagskod: 0xc0000002
Felförskjutning: 0x0000000000033c58
Process-ID: 0x1ae8
Programmets starttid: 0x01d2d214f32de09a
Sökväg till program: C:\WINDOWS\ImmersiveControlPanel\SystemSettings.exe
Sökväg till modul: C:\WINDOWS\System32\KERNELBASE.dll
Rapport-ID: 99027281-ec73-472c-9352-2d93323b3186
Fullständigt namn på felaktigt paket: windows.immersivecontrolpanel_6.2.0.0_neutral_neutral_cw5n1h2txyewy
Program-ID relativt till felaktigt paket: microsoft.windows.immersivecontrolpanel
Aktiveringen av appen Microsoft.Windows.ContentDeliveryManager_cw5n1h2txyewy!App misslyckades med felet: Appen startade inte. Mer information finns i loggen Microsoft-Windows-TWinUI/Operational.
Thanks in advance
Isa
pendean
Community Legend
Community Legend
The correct forum for your post is over here https://forums.autodesk.com/t5/3ds-max/ct-p/area-c1
I don't really understand. The link you posted was the same page I was first on when posting. On your link, I clicked "new post" and it ended up here (wherever here is...).
Alfred.DeFlaminis
Hello @Anonymous and welcome to the community,
I apologize for the delay here, this is the general 3ds max forum.  We do have a place for installation and licensing questions and I will move this thread there now.  Due to the volume in the general Max forum it takes a bit of time to reply to all threads and I just got to yours and noticed your issue.  Again, I am sorry for the delay.
Best Regards,
