I've tried to reinstall / repair my 3Ds MAX 2015 which has stopped working due to missing dll (I have no idea how this could have happened).
First of all the reinstallation didn't work it said that another dll was missing, so I tried to uninstall every autodesk application from my PC according to your guide on site - Removing All Products from a Windows System. After this I used all kind of installation but everytime I ended up with either successfull installation but no files and no 3D Max folder at all or with connection problem which I've solved by turning off the firewall.
Long story short - Successfull Installation = NO 3Ds MAX folder only Inventor Server, DirectConnect, BackBurner.
What should I do ? Reinstall whole OS ? 😄
Solved by Grimmaldus. Go to Solution.
Solved by TravisNave. Go to Solution.
I've resolved the problem with installation with Microsoft Fixit however the old problem with the software re-emerged.
3Ds MAX 2015 doesn't want to lunch due to missing adlmint.dll this occurs when you install Service packs 2 and 3.
How to solve this ?
Reinstall. Don't add the service packs. Service packs are only needed if you are experiencing the problems fixed in the service packs. If not, then there's no reason to break your product. Worth a shot.
