Hi I have installed the 2019 autocad free trial but i have realized the my Dell N5110 is not powerful enough - processor Intel(R) Core(TM) i7-2630QM CPU @ 2.00 GHz and RAM 8.00 GB. i eas wondering what i can do? can i uninstall and install an earlier (lighter) version, or can i install the 2019 LT version? Please let me know, thanks! Carlo
Solved by john.vellek. Go to Solution.
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
Here are the system requirements for AutoCAD LT 2019. It can be installed along side of the current AutoCAD 2019 (Sys Rqmnts) you have already installed.
I suspect your current computer is likely fine to run either application for light usage. What kind of drawings do you do?
Hi @Anonymous,
How did you decide to proceed on this issue? Is there anything else I can offer to help?
Hi @Anonymous,
Can you provide a screen capture of the error? I will also move this thread to Installation and Licensing since they are likely more familiar with that process.
Привет, я установил бесплатную пробную версию AutoCAD 2019, но понял, что мой Dell N5110 недостаточно мощный
