Installation & Licensing
2016 3dsMax not installing
3 REPLIES 3
424 Views, 3 Replies
I am unable to install 2016 3ds Max onto my laptop.  I download it and at the end it says that there are errors.  I read through several posts and tried some of the solutions to no avail.  I attempted the Virtual Agent and I downloaded Microsoft Fixit and the file was not located, which makes sense.  However, I selected the not listed option and hoped for the best but it did not work.  I have wasted so much time trying to install this software and would greatly appreciate help in regards to this matter.
Error message:
2016/8/27:18:01:35 Cameron Alexis DESKTOP-Q45NHQ7 === Setup started on DESKTOP-Q45NHQ7 by Cameron Alexis ===
2016/8/27:18:01:35 Cameron Alexis DESKTOP-Q45NHQ7 Path_Length: 153
2016/8/27:18:01:35 Cameron Alexis DESKTOP-Q45NHQ7 Current Directory C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi_en-US
2016/8/27:18:01:35 Cameron Alexis DESKTOP-Q45NHQ7 Launch
2016/8/27:18:01:35 Cameron Alexis DESKTOP-Q45NHQ7 CommandLine /PK 128H1 /SN 900-26373853 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi_en-..."
2016/8/27:18:01:35 Cameron Alexis DESKTOP-Q45NHQ7 Current Directory C:\Users\CAMERO~1\AppData\Local\Temp\_AID49D.tmp
2016/8/27:18:01:57 Cameron Alexis DESKTOP-Q45NHQ7 === Setup ended ===
2016/8/27:18:01:37 Cameron Alexis DESKTOP-Q45NHQ7 Download Play SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SETUPM...
2016/8/27:18:01:38 Cameron Alexis DESKTOP-Q45NHQ7 Download Complete SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SETUPM...
2016/8/27:18:01:39 Cameron Alexis DESKTOP-Q45NHQ7 Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SETUP_...
2016/8/27:18:01:57 Cameron Alexis DESKTOP-Q45NHQ7 Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SETUP_...
2016/8/27:18:01:57 Cameron Alexis DESKTOP-Q45NHQ7 PageOpen LaunchDialog
2016/8/27:18:02:06 Cameron Alexis DESKTOP-Q45NHQ7 PageOpen LicenseDialog
2016/8/27:18:02:06 Cameron Alexis DESKTOP-Q45NHQ7 PageOpen ProductInfoDialog
2016/8/27:18:02:06 Cameron Alexis DESKTOP-Q45NHQ7 PageOpen ProductSelectionDialog2
2016/8/27:18:02:12 Cameron Alexis DESKTOP-Q45NHQ7 PageOpen FullProgressDialog
2016/8/27:18:02:13 Cameron Alexis DESKTOP-Q45NHQ7 Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/STARTM...
2016/8/27:18:02:14 Cameron Alexis DESKTOP-Q45NHQ7 Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/STARTM...
2016/8/27:18:02:15 Cameron Alexis DESKTOP-Q45NHQ7 Download Play VCREDIST2012X86 http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VCREDI...
2016/8/27:18:02:23 Cameron Alexis DESKTOP-Q45NHQ7 Download Complete VCREDIST2012X86 http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VCREDI...
2016/8/27:18:02:23 Cameron Alexis DESKTOP-Q45NHQ7 Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/8/27:18:02:23 Cameron Alexis DESKTOP-Q45NHQ7 Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/8/27:18:02:24 Cameron Alexis DESKTOP-Q45NHQ7 Download Play VCREDIST2012X64 http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VCREDI...
2016/8/27:18:02:34 Cameron Alexis DESKTOP-Q45NHQ7 Download Complete VCREDIST2012X64 http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VCREDI...
2016/8/27:18:02:34 Cameron Alexis DESKTOP-Q45NHQ7 Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/8/27:18:02:35 Cameron Alexis DESKTOP-Q45NHQ7 Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=-2147024546
2016/8/27:18:02:36 Cameron Alexis DESKTOP-Q45NHQ7 Download Play DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/DIRECT...
2016/8/27:18:02:44 Cameron Alexis DESKTOP-Q45NHQ7 Download Complete DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/DIRECT...
2016/8/27:18:02:44 Cameron Alexis DESKTOP-Q45NHQ7 Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/8/27:18:02:46 Cameron Alexis DESKTOP-Q45NHQ7 Install DirectX® Runtime Succeeded
2016/8/27:18:02:47 Cameron Alexis DESKTOP-Q45NHQ7 Download Play CMILM http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CMILM....
2016/8/27:18:08:29 Cameron Alexis DESKTOP-Q45NHQ7 Download Aborted CMILM http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CMILM....
2016/8/27:18:08:29 Cameron Alexis DESKTOP-Q45NHQ7 Install Autodesk® Material Library 2016 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2016/8/27:18:08:29 Cameron Alexis DESKTOP-Q45NHQ7 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2016/8/27:18:08:29 Cameron Alexis DESKTOP-Q45NHQ7 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2016/8/27:18:08:29 Cameron Alexis DESKTOP-Q45NHQ7 PageOpen InstallCompleteDialog
2016/8/27:18:19:46 Cameron Alexis DESKTOP-Q45NHQ7 === Setup ended ===
2016/8/28:14:42:03 Cameron Alexis DESKTOP-Q45NHQ7 === Setup started on DESKTOP-Q45NHQ7 by Cameron Alexis ===
2016/8/28:14:42:03 Cameron Alexis DESKTOP-Q45NHQ7 Path_Length: 153
2016/8/28:14:42:03 Cameron Alexis DESKTOP-Q45NHQ7 Current Directory C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi_en-US
2016/8/28:14:42:03 Cameron Alexis DESKTOP-Q45NHQ7 Launch
2016/8/28:14:42:03 Cameron Alexis DESKTOP-Q45NHQ7 CommandLine /URL "http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi_en-..." /skipPI /SN 900-26373853 /PK 128H1 /akamai
2016/8/28:14:42:03 Cameron Alexis DESKTOP-Q45NHQ7 Current Directory C:\Users\CAMERO~1\AppData\Local\Temp\_AI853F.tmp
2016/8/28:14:42:24 Cameron Alexis DESKTOP-Q45NHQ7 === Setup ended ===
2016/8/28:14:42:04 Cameron Alexis DESKTOP-Q45NHQ7 === Setup started on DESKTOP-Q45NHQ7 by Cameron Alexis ===
2016/8/28:14:42:04 Cameron Alexis DESKTOP-Q45NHQ7 Path_Length: 153
2016/8/28:14:42:04 Cameron Alexis DESKTOP-Q45NHQ7 Current Directory C:\Users\CAMERO~1\AppData\Local\Temp\_AI853F.tmp
2016/8/28:14:42:04 Cameron Alexis DESKTOP-Q45NHQ7 Launch
2016/8/28:14:42:23 Cameron Alexis DESKTOP-Q45NHQ7 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SETUPM...
2016/8/28:14:42:23 Cameron Alexis DESKTOP-Q45NHQ7 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SETUP_...
2016/8/28:14:42:24 Cameron Alexis DESKTOP-Q45NHQ7 PageOpen LaunchDialog
2016/8/28:14:43:49 Cameron Alexis DESKTOP-Q45NHQ7 PageOpen LicenseDialog
2016/8/28:14:44:03 Cameron Alexis DESKTOP-Q45NHQ7 PageOpen ProductInfoDialog
2016/8/28:14:44:03 Cameron Alexis DESKTOP-Q45NHQ7 PageOpen ProductSelectionDialog2
2016/8/28:14:44:15 Cameron Alexis DESKTOP-Q45NHQ7 PageOpen FullProgressDialog
2016/8/28:14:44:16 Cameron Alexis DESKTOP-Q45NHQ7 Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/STARTM...
2016/8/28:14:44:16 Cameron Alexis DESKTOP-Q45NHQ7 Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/STARTM...
2016/8/28:14:44:16 Cameron Alexis DESKTOP-Q45NHQ7 Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VCREDI...
2016/8/28:14:44:16 Cameron Alexis DESKTOP-Q45NHQ7 Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/8/28:14:44:17 Cameron Alexis DESKTOP-Q45NHQ7 Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/8/28:14:44:17 Cameron Alexis DESKTOP-Q45NHQ7 Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VCREDI...
2016/8/28:14:44:17 Cameron Alexis DESKTOP-Q45NHQ7 Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/8/28:14:44:17 Cameron Alexis DESKTOP-Q45NHQ7 Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=-2147024546
2016/8/28:14:44:17 Cameron Alexis DESKTOP-Q45NHQ7 Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/DIRECT...
2016/8/28:14:44:17 Cameron Alexis DESKTOP-Q45NHQ7 Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/8/28:14:44:19 Cameron Alexis DESKTOP-Q45NHQ7 Install DirectX® Runtime Succeeded
2016/8/28:14:44:20 Cameron Alexis DESKTOP-Q45NHQ7 Download Play CMILM http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CMILM....
2016/8/28:14:46:54 Cameron Alexis DESKTOP-Q45NHQ7 Download Aborted CMILM http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CMILM....
2016/8/28:14:46:54 Cameron Alexis DESKTOP-Q45NHQ7 Install Autodesk® Material Library 2016 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2016/8/28:14:46:54 Cameron Alexis DESKTOP-Q45NHQ7 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2016/8/28:14:46:54 Cameron Alexis DESKTOP-Q45NHQ7 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2016/8/28:14:46:54 Cameron Alexis DESKTOP-Q45NHQ7 PageOpen InstallCompleteDialog
2016/8/28:14:53:49 Cameron Alexis DESKTOP-Q45NHQ7 === Setup ended ===
2016/8/28:15:16:28 Cameron Alexis DESKTOP-Q45NHQ7 === Setup started on DESKTOP-Q45NHQ7 by Cameron Alexis ===
2016/8/28:15:16:28 Cameron Alexis DESKTOP-Q45NHQ7 Path_Length: 153
2016/8/28:15:16:28 Cameron Alexis DESKTOP-Q45NHQ7 Current Directory C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi_en-US
2016/8/28:15:16:28 Cameron Alexis DESKTOP-Q45NHQ7 Launch
2016/8/28:15:16:28 Cameron Alexis DESKTOP-Q45NHQ7 CommandLine /URL "http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi_en-..." /skipPI /SN 900-26373853 /PK 128H1 /akamai
2016/8/28:15:16:28 Cameron Alexis DESKTOP-Q45NHQ7 Current Directory C:\Users\CAMERO~1\AppData\Local\Temp\_AI66F.tmp
2016/8/28:15:16:29 Cameron Alexis DESKTOP-Q45NHQ7 === Setup ended ===
2016/8/28:15:16:29 Cameron Alexis DESKTOP-Q45NHQ7 === Setup started on DESKTOP-Q45NHQ7 by Cameron Alexis ===
2016/8/28:15:16:29 Cameron Alexis DESKTOP-Q45NHQ7 Path_Length: 153
2016/8/28:15:16:29 Cameron Alexis DESKTOP-Q45NHQ7 Current Directory C:\Users\CAMERO~1\AppData\Local\Temp\_AI66F.tmp
2016/8/28:15:16:29 Cameron Alexis DESKTOP-Q45NHQ7 Launch
2016/8/28:15:16:29 Cameron Alexis DESKTOP-Q45NHQ7 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SETUPM...
2016/8/28:15:16:29 Cameron Alexis DESKTOP-Q45NHQ7 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SETUP_...
2016/8/28:15:16:29 Cameron Alexis DESKTOP-Q45NHQ7 PageOpen LaunchDialog
2016/8/28:15:16:50 Cameron Alexis DESKTOP-Q45NHQ7 PageOpen LicenseDialog
2016/8/28:15:17:06 Cameron Alexis DESKTOP-Q45NHQ7 PageOpen ProductInfoDialog
2016/8/28:15:17:06 Cameron Alexis DESKTOP-Q45NHQ7 PageOpen ProductSelectionDialog2
2016/8/28:15:17:10 Cameron Alexis DESKTOP-Q45NHQ7 PageOpen FullProgressDialog
2016/8/28:15:17:10 Cameron Alexis DESKTOP-Q45NHQ7 Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/STARTM...
2016/8/28:15:17:10 Cameron Alexis DESKTOP-Q45NHQ7 Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/STARTM...
2016/8/28:15:17:10 Cameron Alexis DESKTOP-Q45NHQ7 Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VCREDI...
2016/8/28:15:17:10 Cameron Alexis DESKTOP-Q45NHQ7 Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/8/28:15:17:11 Cameron Alexis DESKTOP-Q45NHQ7 Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/8/28:15:17:11 Cameron Alexis DESKTOP-Q45NHQ7 Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VCREDI...
2016/8/28:15:17:11 Cameron Alexis DESKTOP-Q45NHQ7 Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/8/28:15:17:11 Cameron Alexis DESKTOP-Q45NHQ7 Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=-2147024546
2016/8/28:15:17:12 Cameron Alexis DESKTOP-Q45NHQ7 Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/DIRECT...
2016/8/28:15:17:12 Cameron Alexis DESKTOP-Q45NHQ7 Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/8/28:15:17:13 Cameron Alexis DESKTOP-Q45NHQ7 Install DirectX® Runtime Succeeded
2016/8/28:15:17:14 Cameron Alexis DESKTOP-Q45NHQ7 Download Play CMILM http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CMILM....
2016/8/28:15:19:44 Cameron Alexis DESKTOP-Q45NHQ7 Download Aborted CMILM http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CMILM....
2016/8/28:15:19:44 Cameron Alexis DESKTOP-Q45NHQ7 Install Autodesk® Material Library 2016 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2016/8/28:15:19:44 Cameron Alexis DESKTOP-Q45NHQ7 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2016/8/28:15:19:44 Cameron Alexis DESKTOP-Q45NHQ7 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2016/8/28:15:19:44 Cameron Alexis DESKTOP-Q45NHQ7 PageOpen InstallCompleteDialog
2016/8/28:15:20:13 Cameron Alexis DESKTOP-Q45NHQ7 === Setup ended ===
2016/8/28:15:35:37 Cameron Alexis DESKTOP-Q45NHQ7 === Setup started on DESKTOP-Q45NHQ7 by Cameron Alexis ===
2016/8/28:15:35:37 Cameron Alexis DESKTOP-Q45NHQ7 Path_Length: 153
2016/8/28:15:35:37 Cameron Alexis DESKTOP-Q45NHQ7 Current Directory C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi_en-US
2016/8/28:15:35:37 Cameron Alexis DESKTOP-Q45NHQ7 Launch
2016/8/28:15:35:37 Cameron Alexis DESKTOP-Q45NHQ7 CommandLine /URL "http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi_en-..." /skipPI /SN 900-26373853 /PK 128H1 /akamai
2016/8/28:15:35:37 Cameron Alexis DESKTOP-Q45NHQ7 Current Directory C:\Users\CAMERO~1\AppData\Local\Temp\_AI8FD0.tmp
2016/8/28:15:35:38 Cameron Alexis DESKTOP-Q45NHQ7 === Setup ended ===
2016/8/28:15:35:38 Cameron Alexis DESKTOP-Q45NHQ7 === Setup started on DESKTOP-Q45NHQ7 by Cameron Alexis ===
2016/8/28:15:35:38 Cameron Alexis DESKTOP-Q45NHQ7 Path_Length: 153
2016/8/28:15:35:38 Cameron Alexis DESKTOP-Q45NHQ7 Current Directory C:\Users\CAMERO~1\AppData\Local\Temp\_AI8FD0.tmp
2016/8/28:15:35:38 Cameron Alexis DESKTOP-Q45NHQ7 Launch
2016/8/28:15:35:38 Cameron Alexis DESKTOP-Q45NHQ7 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SETUPM...
2016/8/28:15:35:38 Cameron Alexis DESKTOP-Q45NHQ7 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SETUP_...
2016/8/28:15:35:38 Cameron Alexis DESKTOP-Q45NHQ7 PageOpen LaunchDialog
2016/8/28:15:35:42 Cameron Alexis DESKTOP-Q45NHQ7 PageOpen LicenseDialog
2016/8/28:15:36:15 Cameron Alexis DESKTOP-Q45NHQ7 PageOpen ProductInfoDialog
2016/8/28:15:36:15 Cameron Alexis DESKTOP-Q45NHQ7 PageOpen ProductSelectionDialog2
2016/8/28:15:36:40 Cameron Alexis DESKTOP-Q45NHQ7 PageOpen FullProgressDialog
2016/8/28:15:36:40 Cameron Alexis DESKTOP-Q45NHQ7 Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/STARTM...
2016/8/28:15:36:40 Cameron Alexis DESKTOP-Q45NHQ7 Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/STARTM...
2016/8/28:15:36:40 Cameron Alexis DESKTOP-Q45NHQ7 Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VCREDI...
2016/8/28:15:36:40 Cameron Alexis DESKTOP-Q45NHQ7 Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/8/28:15:36:48 Cameron Alexis DESKTOP-Q45NHQ7 Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/8/28:15:36:48 Cameron Alexis DESKTOP-Q45NHQ7 Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VCREDI...
2016/8/28:15:36:48 Cameron Alexis DESKTOP-Q45NHQ7 Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/8/28:15:36:48 Cameron Alexis DESKTOP-Q45NHQ7 Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=-2147024546
2016/8/28:15:36:48 Cameron Alexis DESKTOP-Q45NHQ7 Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/DIRECT...
2016/8/28:15:36:48 Cameron Alexis DESKTOP-Q45NHQ7 Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/8/28:15:36:58 Cameron Alexis DESKTOP-Q45NHQ7 Install DirectX® Runtime Succeeded
2016/8/28:15:36:58 Cameron Alexis DESKTOP-Q45NHQ7 Download Play CMILM http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CMILM....
2016/8/28:15:38:44 Cameron Alexis DESKTOP-Q45NHQ7 Download Aborted CMILM http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CMILM....
2016/8/28:15:38:44 Cameron Alexis DESKTOP-Q45NHQ7 Install Autodesk® Material Library 2016 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2016/8/28:15:38:44 Cameron Alexis DESKTOP-Q45NHQ7 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2016/8/28:15:38:44 Cameron Alexis DESKTOP-Q45NHQ7 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
3 REPLIES 3
Darin.Green
The issue is with using the web installer. Download the software from the Autodesk Virtual Agent
Once there, use the Download Links option to navigate to the application you need to download.
NOTE: If there are multiple parts for the download, you'll need to click each part to download them, once they are downloaded double-click Part1 (which will automatically extract the remaining parts) to begin the installation.
If this information was helpful, please consider using the Accept Solution
Mark.Lancaster
@Anonymous
Welcome to the community...
In addition to @Darin.Green information (to use the Autodesk Virtual Agent)..
Although you were probably unaware of this, but when you post or share stuff here, please make sure it doesn't include your personal information such as your serial #. This is a world wide user forum and that type of info should not be included in your posting. Granted the installation log file helped us to determine your root cause (but it did contain your serial #)... So in the future remove or blur it out before posting. I will have the moderator remove it in order to protect your information.
Mark Lancaster
in reply to: Mark.Lancaster
Thank you for catching that and notifying the moderator, duly noted.
Administrator Productivity
