Announcements
Using dual accounts on single Autodesk products
Christopher_Geylen
Christopher_Geylen
Good day,
I currently have 2 Autodesk accounts with licenses. One for the company I contract for and one for a project I am working on which only allows us to use licenses with their email domain. The problem I am facing is that every time I switch between projects, I need to log out of Revit, Navisworks, BIM360, etc to log on with the other license. Is there a feature from Autodesk which will allow me to use both licences at the same time? Or any other 3rd party application?
Thanks.
DarrenP
No you can’t mix different Autodesk accounts with different products
You can try creating a windows user just for this other account
DarrenP
handjonathan
Hi @Christopher_Geylen
Thanks a lot for posting your question to the forums!   Has the solution suggested by @DarrenP helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
