Updating to windows 10 from windows 7
  • Do I need to do anything with my autodesk licenses for infrastructure suite premium before i update from windows 7 to windows 10?
leowarren34
You may face incompatability issues with instllation of the suite since none list windows 10 as a system requirements.
However , depending on your version, the newest versions are compatible with windows 8.1 so there's a likelihood they will install fine.
Ultimately what version is your suite?
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
mdavis22569
@leowarren34
Are you sure:
(might want to find out the version first)
@Anonymous
You shouldn't have any licensing issues. I have seen over the last couple of years where the Video Card driver needs to be reviewed. Since you're changing OS's.
You might also need to do a "Reinstall" on some products if you have an issue ... at times some Autodesk required files get overwritten too when updating from W7 to W10
Mike Davis
leowarren34
@mdavis22569
I did check the requirements and the newest ones list windows 8.1 as working.
According to Microsoft: 'Most apps (and other programs, like games or utilities) that were created for earlier versions of Windows will work in the most recent version of Windows 10, but some older ones might run poorly or not at all.'
Hence why I said likely and not certainly.
As you said it depends on the version.
Leo Warren
mdavis22569
Don't forget to recommend the FixIT tool....  😉
Collections still show as Suites sometimes in their Account Portal. So while their Infrastructure Design Suite might be the AEC collection they will still see the IDSP.  Which would be good on W10 ...
@Anonymous  What year software are you using so we can be 100% (and Certain vs likely)
Mike Davis
leowarren34
Well played 😆
You have to make mistakes to learn and get better.
You are a fountain of knowledge @mdavis22569.
Leo Warren
