uninstalling and reinstalling Autocad 2014
Ponder2.com
Ponder2.com
What's the procedure for uninstalling and reinstalling standalone ACAD on the same computer when the original install was a download?
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
It might depend on the reason why you are reinstalling it...
The general procedure for a clean uninstall is described >>>here<<<
Use the same downloaded files to reinstall the product.
If you don't have the download any more you can go to Autodesk Virtual Agent to redownload it >>>click<<<
To install AutoCAD follow then to install any other software too: login as admin, turn off antivirus, start the installer with right-click the installer-exe ==> start as administrator
Good luck, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Ponder2.com
I finally worked up the nerve to try it and it worked perfectly. Thank you!
