Unable to Install AutoCAD Map 3D
I've been trying to install AutoCAD Map 3D for a number of days now, i've tried various different versions of the program thinking that might help, but alas I am still getting errors. I have AutoCAD Architecture and AutoCAD LT successfully installed already, here is the error code of installation. Hopefully someone will be able to help! 🙂
2016/11/20:11:28:43 Holly.Cooper HOLLY-PC === Setup started on HOLLY-PC by Holly.Cooper ===
2016/11/20:11:28:43 Holly.Cooper HOLLY-PC Path_Length: 157
2016/11/20:11:28:43 Holly.Cooper HOLLY-PC Current Directory C:\Autodesk\Autodesk_Map_2015_R1_English_Win_64bit_WI_en-us
2016/11/20:11:28:43 Holly.Cooper HOLLY-PC Launch
2016/11/20:11:28:43 Holly.Cooper HOLLY-PC CommandLine /PK 129G1 /SN 900-79059896 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAP/WI/Autodesk_Map_2015_R1_English_Win_64bit_WI_en-us_S..."
2016/11/20:11:28:43 Holly.Cooper HOLLY-PC Current Directory C:\Users\Holly\AppData\Local\Temp\_AI8B66.tmp
2016/11/20:11:29:14 Holly.Cooper HOLLY-PC === Setup ended ===
2016/11/20:11:28:48 Holly.Cooper HOLLY-PC === Setup started on HOLLY-PC by Holly.Cooper ===
2016/11/20:11:28:48 Holly.Cooper HOLLY-PC Path_Length: 157
2016/11/20:11:28:48 Holly.Cooper HOLLY-PC Current Directory C:\Users\Holly\AppData\Local\Temp\_AI8B66.tmp
2016/11/20:11:28:48 Holly.Cooper HOLLY-PC Launch
2016/11/20:11:28:50 Holly.Cooper HOLLY-PC Download Play SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/SETUP_x64....
2016/11/20:11:29:12 Holly.Cooper HOLLY-PC Download Complete SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/SETUP_x64....
2016/11/20:11:29:12 Holly.Cooper HOLLY-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Holly\AppData\Local\Temp\_AI8B66.tmp\Setup\AcSetup.dll
2016/11/20:11:29:12 Holly.Cooper HOLLY-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/11/20:11:29:14 Holly.Cooper HOLLY-PC PageOpen LaunchDialog
2016/11/20:11:29:35 Holly.Cooper HOLLY-PC PageOpen LicenseDialog
2016/11/20:11:29:35 Holly.Cooper HOLLY-PC PageOpen ProductInfoDialog
2016/11/20:11:29:35 Holly.Cooper HOLLY-PC PageOpen ProductSelectionDialog2
2016/11/20:11:30:04 Holly.Cooper HOLLY-PC PageOpen FullProgressDialog
2016/11/20:11:30:05 Holly.Cooper HOLLY-PC Download Play VCREDIST2012X86UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/VCREDIST20...
2016/11/20:11:30:13 Holly.Cooper HOLLY-PC Download Complete VCREDIST2012X86UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/VCREDIST20...
2016/11/20:11:30:13 Holly.Cooper HOLLY-PC Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2015\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Holly\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2016/11/20:11:30:16 Holly.Cooper HOLLY-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2016/11/20:11:30:17 Holly.Cooper HOLLY-PC Download Play VCREDIST2012X64UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/VCREDIST20...
2016/11/20:11:30:26 Holly.Cooper HOLLY-PC Download Complete VCREDIST2012X64UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/VCREDIST20...
2016/11/20:11:30:26 Holly.Cooper HOLLY-PC Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2015\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Holly\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2016/11/20:11:30:27 Holly.Cooper HOLLY-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2016/11/20:11:30:28 Holly.Cooper HOLLY-PC Download Play DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/DIRECTX.ta...
2016/11/20:11:30:36 Holly.Cooper HOLLY-PC Download Complete DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/DIRECTX.ta...
2016/11/20:11:30:36 Holly.Cooper HOLLY-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2016/11/20:11:30:55 Holly.Cooper HOLLY-PC Install DirectX Runtime Succeeded
2016/11/20:11:30:55 Holly.Cooper HOLLY-PC Download Play CM http://edutrial.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/CM.tar.lzm...
2016/11/20:11:31:17 Holly.Cooper HOLLY-PC Download Complete CM http://edutrial.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/CM.tar.lzm...
2016/11/20:11:31:17 Holly.Cooper HOLLY-PC Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2015" SETUP_PACKAGECODE={B4C0BF45-1B56-4F43-A5B2-73A8D9230ACB} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/11/20:11:31:56 Holly.Cooper HOLLY-PC Install Autodesk Material Library 2015 Succeeded
2016/11/20:11:31:56 Holly.Cooper HOLLY-PC Download Play CMILB http://edutrial.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/CMILB.tar....
2016/11/20:11:32:23 Holly.Cooper HOLLY-PC Download Complete CMILB http://edutrial.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/CMILB.tar....
2016/11/20:11:32:23 Holly.Cooper HOLLY-PC Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2015" SETUP_PACKAGECODE={B4C0BF45-1B56-4F43-A5B2-73A8D9230ACB} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/11/20:11:33:22 Holly.Cooper HOLLY-PC Install Autodesk Material Library 2015 - Base Image Library Succeeded
2016/11/20:11:33:22 Holly.Cooper HOLLY-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2015\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2015" SETUP_PACKAGECODE={B4C0BF45-1B56-4F43-A5B2-73A8D9230ACB} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/11/20:11:33:52 Holly.Cooper HOLLY-PC Install Autodesk Content Service Succeeded
2016/11/20:11:33:52 Holly.Cooper HOLLY-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2015" SETUP_PACKAGECODE={B4C0BF45-1B56-4F43-A5B2-73A8D9230ACB} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/11/20:11:34:10 Holly.Cooper HOLLY-PC Install Autodesk Content Service Language Pack Succeeded
2016/11/20:11:34:10 Holly.Cooper HOLLY-PC Installing Microsoft SQL Server Native Client 11.0: IACCEPTSQLNCLILICENSETERMS=YES ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2015" SETUP_PACKAGECODE={B4C0BF45-1B56-4F43-A5B2-73A8D9230ACB} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/11/20:11:34:18 Holly.Cooper HOLLY-PC Install Microsoft SQL Server Native Client 11.0 Succeeded
2016/11/20:11:34:18 Holly.Cooper HOLLY-PC Download Play ACADMAP http://edutrial.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/ACADMAP_x6...
2016/11/20:11:38:28 Holly.Cooper HOLLY-PC Download Aborted ACADMAP http://edutrial.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/ACADMAP_x6...
2016/11/20:11:38:28 Holly.Cooper HOLLY-PC Install Autodesk® AutoCAD® Map 3D 2015 Failed Download Failed, Installation aborted, Result=1603
2016/11/20:11:38:32 Holly.Cooper HOLLY-PC Rollback Microsoft SQL Server Native Client 11.0 Succeeded
2016/11/20:11:38:36 Holly.Cooper HOLLY-PC Rollback Autodesk Content Service Language Pack Succeeded
2016/11/20:11:38:47 Holly.Cooper HOLLY-PC Rollback Autodesk Content Service Succeeded
2016/11/20:11:39:13 Holly.Cooper HOLLY-PC Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2016/11/20:11:40:17 Holly.Cooper HOLLY-PC Rollback Autodesk Material Library 2015 Succeeded
2016/11/20:11:40:17 Holly.Cooper HOLLY-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/11/20:11:40:18 Holly.Cooper HOLLY-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2016/11/20:11:40:18 Holly.Cooper HOLLY-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
Darin.Green
This issue is caused by the method you're using to download/install the application.
Solution:
Download the software from the Autodesk Virtual Agent
  • Once there, use Download Links and navigate to the application you need to download.
NOTE: If there are multiple parts for the download, you'll need to click each part to download them, once they are downloaded double-click Part1 (which will automatically extract the remaining parts) to begin the installation.
If this information was helpful, please consider using the Accept Solution
