Tried to move Autocad 2021 Directory to another drive. Now it doesn't work.
Hi! So I was transferring the Autocad Directory to another drive. When I tried launching Autocad, it says that acad.exe cannot be found. When I tried to open acad.exe on the directory, it returns some kind of error that "something cannot be found" type. So, I deleted the Autocad directory folder and uninstalled Autodesk. When I tried to reinstall everything, the installer says that Autocad 2021 is still installed on my system. I then proceeded with the installation but only the Autodesk Desktop app is installed. Autocad 2021 is nowhere to be found. What could be the solution for this? Thanks!
imadHabash
I suggest to Perform a clean uninstall . >> Click <<
Imad Habash
pendean
Community Legend
Community Legend
You never do that. Ever.
Remove and reinstall the program, just know that much of it will still install on your OS primary drive.
