Support Content location causes "Faulting module name: KERNELBASE.dll"
My AutoCAD 2018 deployment would install fine, but when I tried to open the program, nothing would happen.  In the Event Viewer I would see "Faulting module name: KERNELBASE.dll" for acad.exe.
I tried three different kinds of hardware, I tried all the suggestions listed here, but nothing helped.  It turns it out it was caused by the "Support Content" folders being something other than the default location.  Autodesk has a short article about it: How do I use support content folders in a deployment?  I had selected the second option.  I don't know why these options exist if they break the program...
I hope Autodesk can fix this, or it helps someone else with the same problem.
natasha.l
Hello @Anonymous,
Thank you very much for sharing this information with us, we appreciate your contribution to the community. Smiley Happy
Thanks! I was just beating my head against the wall on this one.  I had kind of assumed it was a graphics driver problem and was going to head down that path but you saved me hours and hours of work in figuring this out.
@Anonymous wrote:
...you saved me hours and hours of work in figuring this out.
I'm glad my post wasn't in vain.
Now that we know it's not an isolated issue, what will Autodesk do about it?  I suspect this behavior is by design, but it should say where you select it and/or display an error or warning message when you try to open it.
