Hello @Anonymous,
I have pulled this information together for you. You can call to make sure to see what perpetual licenses you are entitled to, but you retain perpetual license rights for the most recent version of your software that you installed and activated under your maintenance plan.
Maintenance Plans: The end-of-sale of perpetual licenses only impacts the ability to purchase new perpetual licenses with a maintenance plan. If you currently have a maintenance plan, you will continue enjoying the benefits of maintenance as long as you continue to renew. After Autodesk discontinues the sale of perpetual licenses for a product, you will only be able to renew your maintenance plans for previously purchased perpetual licenses. No new perpetual licenses may be added to new or existing maintenance plans after we have discontinued the sale of perpetual licenses for that product.
If your maintenance plan expires you can continue using your perpetual licenses. However, you will lose maintenance benefits such as updates, access to previous versions, technical product support, flexible license rights, and access to select cloud services.
- Version Rights: You retain perpetual license rights for the most recent version of your software that you installed and activated under your maintenance plan. For example, if you originally purchased a 2014 version of your software but upgraded to the 2016 version while your maintenance plan was active, you retain perpetual license rights to the 2016 version after your maintenance plan ends. You should download installation files and record your activation information for the most recent version activated under your maintenance plan for future use if needed.
Thank you for posting.
Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
