Still struggling to install Autocad 2016
hi gentleman ,
                     I have laptop with os  windows 10, processor i5,4GB ram brand of HP six month new only ........
                    whenever I try to install auto cad 2016 it has not been successful ..........
                    some it show auotcad 2016 not found this device pls install autocad 2016
                    I access with all article from auto desk forum like uninstall Microsoft software , frame work ,%tem%..............
                    but it does not work can you clarify that how to do it
                     also I attached the screen shot of what I got
                   pls help you people are my lost hope
fieldguy
Mark.Lancaster
@Anonymous
An image of a failed installation is no good to us..  We need your installation log file to determine the root cause.   However I will assume its failing due to the method you're using.
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
However if the installation does fail using this method, please post your installation log file here so we can review it.  Posting info: Sometimes installation log files contain personal information such as your serial #.  Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Mark Lancaster
hi,
today I found this kind of trouble during installation of autocad
2016 as per your suggestion which I attached screen shot
Mark.Lancaster
@Anonymous
Nothing is attached but images are not really going to mean much for installation issues.  We need your actually installation log file, so attach it here.
Mark Lancaster
