SSO integration
SSO integration
SSO integration
We want to integrate our organization to Single Sign on (SSO integration)  so that every user doesn't need to login using there email accounts,it should be activated automatically.Please let us know if any documentation or step by step process
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community
What type of license and Autodesk product are you talking about?
If this is subscription based single user license, the answer is NO.  The named account used can only be used once at any given time to authorize the application.  Each person requiring access to an Autodesk product must have a named account and the use of the product assigned to them.
Mark Lancaster
@Anonymous: Thank you for the response.
License: Serial Number Based
Product: AutoCAD LT 2017
Each person accessing the product should not need any to authorize/activation of the product. Of course, we will need to assign the product to the user(upon the request, if someone needs the product to be installed and used)
I believe Autodesk would have some option to enable the SSO for such user's and not use the network license ?
simona.golisciano
Hi @Anonymous,
Thanks for your reply.
Actually, what we need to know is whether your license is subscription-based (rental model) or perpetual. Both of these licensing models may correspond to a serialized license.
@Mark.Lancaster already provided the response for the subscription-based license. On the other hand, if it's a perpetual license, the user won't need to sign in to access/activate the software, he'll just need to activate the product with the provided Serial Number and Product Key.
Hope this helps.
Simona Golisciano
