Silent installtion of AutoCAD LT 2017 with standalone license
We are going to deploy AutoCAD LT 2017 for our users. Is it possible to create an unattended SCCM package that installs and registers license key?
best regards
kep
Mark.Lancaster
@Anonymous
Welcome to the community..
Is this license a perpetual license on a maintenance plan or it is term based license?
Mark Lancaster
Darin.Green
@Anonymous,
There's no way of activating the software through any means (SCCM, GPO, Deployments) except manually launching the application I've tried...Smiley Wink However, If you do find a way, please share with the community.
If you just purchased the software, then that would mean you have a Sing-User Term license. Those license require users to select Serial Number during the first launch, then type in their numbers. Once that's complete, they're asked to sign into the software with their Autodesk login information. <-- This will most likely require users to launch the application themselves.
Hope that helps, Good Luck!
If this information was helpful, please consider using the Accept Solution
thanks for the replies.
i will check more when i am at work on monday
