Revit Lt 2018 Offline
3pv
Message 1 of 9
3pv
How can I use revit Lt 2018 without an Internet connection! Our office WiFi is rubbish so need to work without internet but when I turn off the WiFi I get 'connection to Internet required to continue' message?
Replies (8)
Message 2 of 9
Otto
Hello michael_kernohan and welcome to the Autodesk community!
We noticed you are attempting to use your product without being connected to the internet. An internet connection is required to sign in and activate, every 30-days you should be connected to the internet at some point (to verify your license & use the software).
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 9
3pv
I have already used it online to sign in and activate. I was trying use the program after this was done.
Thanks for the reply, any other ideas?
Message 4 of 9
Mark.Lancaster
@3pv
There appears to be a few people reporting this same issue this morning.   However we are only users and have no access to troubleshoot this if this is the case.  Work-around solution..  Disconnect from your network/internet and launch your application.  It should put you in a 30 day off-line mode.  Good luck and report back on your progress.
Mark Lancaster
Message 5 of 9
3pv
Hi Mark thanks for the reply, but the problem is I'm already disconnected and it's not going onto offline mode!?!
Message 6 of 9
Mark.Lancaster
@3pv
Sorry I missed the "turned off wifi" statement..  Smiley Sad
So if you launch an Internet browser on this machine you can't get onto the internet?  Are you using this machine to post to the forum?  Have you rebooted and try again?  If there's no true internet access it shouldn't be prompting you at all.  It should just go into the 30 day off-line mode.  To me it still sounds like it sees the internet in the background.   But only speculating at this time.
Mark Lancaster
Message 7 of 9
3pv
Thanks Mark, Im replying to these through my phone! Yea i have rebooted a number of times. Not quite sure how to turn of the wifi other than turning it off lol but will have a hunt on google and let you know.
Message 8 of 9
natasha.l
Hello @3pv,
Sorry for the inconvenience, Autodesk is aware of an issue where Revit 2018 crashes in offline mode, in your case you would like to go offline but please review this information, Revit crashes when not connected to the internet, or to limited internet
Thank for being a part of the community, let me know if you have any questions.
Please "Accept As Solution" if a reply has helped resolve the issue or answered your question, to help others in the community.
Message 9 of 9
natasha.l
Hello @3pv,
I wanted to follow up with you about the cautionary post I provided, the crashes have happened to some users but others have worked successfully offline without a problem. If you choose to work offline you should disconnect from the internet & sign-out of A360 as well in order to do so. You can also try to borrow a license from the network within Revit.
Let us know if you have any issue & are successful disconnecting to work offline. Thanks. Smiley Happy
