Revit Install Error
Revit Install Error
Revit Install Error
I am trying to install Revit 2020 and am receiving the following error below.revit error.PNG
I had a similar or identical error trying to install AutoCAD 2020, however I was able to successfully download and install it via the AutoDesk Desktop App. However, because I am attempting to download a trial for Revit 2020 the option to install does not appear in my Desktop App.
I am using Windows 10. I have tried purging all temporary files. I have uninstalled previous versions of Revit LT from my system. I attempted to install in safe mode and with antivirus off. I have selected "Run as Administrator" when trying to launch the insulation exe file. I've tried with and without the Download manager. I have had the same error each time.
EDIT:
After digging into my Temporary Files folder a little more I found this log file:
2019/4/15:11:25:12	Drafting Workstation	DESKTOP-5S5SBBT	=== Setup started on DESKTOP-5S5SBBT by Drafting Workstation ===
2019/4/15:11:25:12	Drafting Workstation	DESKTOP-5S5SBBT	Path_Length: 115
2019/4/15:11:25:12	Drafting Workstation	DESKTOP-5S5SBBT	Current Directory C:\Users\Drafting Workstation\AppData\Local\Temp\_AI7672.tmp
2019/4/15:11:25:12	Drafting Workstation	DESKTOP-5S5SBBT	Launch
2019/4/15:11:25:12	Drafting Workstation	DESKTOP-5S5SBBT	CommandLine
2019/4/15:11:25:12	Drafting Workstation	DESKTOP-5S5SBBT	Another Autodesk install/update is now occurring on this computer.  Please wait for that to complete and then click Retry.2019/4/15:11:25:14	Drafting Workstation	DESKTOP-5S5SBBT	=== Setup ended ===
2019/4/15:11:24:38	Drafting Workstation	DESKTOP-5S5SBBT	=== Setup started on DESKTOP-5S5SBBT by Drafting Workstation ===
2019/4/15:11:24:38	Drafting Workstation	DESKTOP-5S5SBBT	Path_Length: 115
2019/4/15:11:24:38	Drafting Workstation	DESKTOP-5S5SBBT	Current Directory C:\Autodesk\Revit_2020_G1_Win_64bit_dlm
2019/4/15:11:24:38	Drafting Workstation	DESKTOP-5S5SBBT	Launch
2019/4/15:11:24:38	Drafting Workstation	DESKTOP-5S5SBBT	CommandLine
2019/4/15:11:24:38	Drafting Workstation	DESKTOP-5S5SBBT	Current Directory C:\Users\Drafting Workstation\AppData\Local\Temp\_AI7672.tmp
2019/4/15:11:25:18	Drafting Workstation	DESKTOP-5S5SBBT	=== Setup ended ===
2019/4/15:11:25:23	Drafting Workstation	DESKTOP-5S5SBBT	=== Setup started on DESKTOP-5S5SBBT by Drafting Workstation ===
2019/4/15:11:25:23	Drafting Workstation	DESKTOP-5S5SBBT	Path_Length: 115
2019/4/15:11:25:23	Drafting Workstation	DESKTOP-5S5SBBT	Current Directory C:\Users\Drafting Workstation\AppData\Local\Temp\_AI7672.tmp
2019/4/15:11:25:23	Drafting Workstation	DESKTOP-5S5SBBT	Launch
2019/4/15:11:25:23	Drafting Workstation	DESKTOP-5S5SBBT	CommandLine
2019/4/15:11:25:23	Drafting Workstation	DESKTOP-5S5SBBT	Current Directory C:\Users\Drafting Workstation\AppData\Local\Temp\_AI26E6.tmp
2019/4/15:11:25:27	Drafting Workstation	DESKTOP-5S5SBBT	=== Setup ended ===
DarrenP
try this: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Instal...
DarrenP
Many thanks! That worked!
I have the same issue and I did all the steps but still, it won't work.
