Announcements
Revit 2024 - Important Components Missing (Resolved)
chinkian80
Message 1 of 10
chinkian80
Dear all,
Greetings.
Having problem installing Revit 2024.
This is during installation, 63%, keep pop until i select cancel
This message appeared when i attempt to do 2nd installation
This appeared on the completed installation.
Kindly advise how to resolve this issue.
Your kind advise are very much appreciated.
Thanks for the advice so far. I already format the windos for it.
Replies (9)
Message 2 of 10
pendean
Community Legend
Community Legend
I may just not see it in your post, but did you restart your computer and try the installation again yet?
A "2nd installation" tells me you did not, but that error message says to do just that.
Give it a shot.
Message 3 of 10
Simon_Weel
What kind of installation are you trying to perform? From a deployment or from your Autodesk Account page?
The first screenshot says the network location is unavailable, so this leads me to believe you're trying to install from a network deployment and the deployment location is no longer available.
Message 4 of 10
chinkian80
Hi.
Yes, i did several times, the 2nd picture was after restart PC
Message 5 of 10
chinkian80
Hi.
Direct from the website manage.account there.
Message 6 of 10
Darin.Green
@chinkian80 Instead of using the Web Installer, download full installer from here:
Revit 2024 Part 1 of 5
Revit 2014: Part 2 of 5
Revit 2024: Part 3 of 5
Revit 2024: Part 4 of 5
Revit 2024: Part 5 of 5
If this information was helpful, please consider using the Accept Solution
Message 7 of 10
chinkian80
Thanks for assist.
Still same error, restarted after 1st installation, same msg appeared.
Message 8 of 10
Simon_Weel
And what message might that be?
Message 9 of 10
chinkian80
Same as my previous post.
Got no alternative, i d format the window.
Message 10 of 10
Simon_Weel
Ok, so all three screenshots appear again? Reinstalling Windows seems way overdone to tackle this problem IMO. I would suggest you download all installation files, store them on the local drive in a location accessible for the Admin account and run the installer again. Don't forget you need Admin permissions to install...
