Revit 2022: Create offline installer + silent installation for viewer mode
igp_it_support
igp_it_support
we would like to add a revit installation to PCs to provide occasionally needed viewing capabilities for revit files.
By navigating the autodesk website i just find a download for "Revit_2022_Ship_20210224_RTC_Win_64bit_di_ML_setup_webinstall.exe" . But this is just a automated online downloader/installer, i did see how i can create a offline installer with it.
Finally i would like to run a offline installer setup.exe with some parameters like -q to perform a silent install.
AFAIK the installed revit can be started with /viewer to run in view-only mode?
Any tips and pointers how to accomplish this would be helpful. TY!
ennujozlagam
you can try to use the browser download method: https://knowledge.autodesk.com/customer-service/download-install/download/about-download-methods/bro...
igp_it_support
thanks for the tip.
the download itself was not listed, but you can use the chatbot to ask/search for the download. you get 5 parts, 8.5GB.
the combination of install switches working to still see some progress but have it run unattended otherwise has been "--install_mode install --trial_mode --ui_mode basic ", but there is still one pop-up to accept some privacy protection regulation things. any clue how to get rid of it?
using " --offline_mode true" should also work now installing from the full download?
igp_it_support
using "--offline_mode" or "--offline_mode true" the installer silently terminates. is that supposed to happen?
mdavis22569
HI @igp_it_support
Were you able to resolve this?
Mike
Mike Davis
mdavis22569
@igp_it_support  checking in again to see if @ennujozlagam  helped you resolve this issue
Mike
Mike Davis
