[Remove] fatal error:
Edit: please remove due to posting in wrong section.
Thanks @Mark.Lancaster
Otto
Hello jhalfpenny696P5 and welcome to the Autodesk community!
We noticed you were receiving a fatal error. The fatal error message can indicate several issues. A video card driver update will typically help with this, but fatal errors usually are generic errors, give these steps a try.
  1. Update to the latest certified graphics drivers & Adjust Global Setting to run it
  2. Check the system requirements for the software & make sure you have the required OS updates
  3. Verify the Microsoft Products (Visual C++, Libraries, .NET) properly installed by checking the install log or Control Panel (uninstall/reinstall)
  4. Conduct a Clean Uninstall of the program use MSfixitTool to complete the uninstall
  5. Download all of the parts Autodesk Virtual Agent & Re-Install the product
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
If this is happening on a single drawing I would suspect there's some corruption in it.
I would start AutoCAD and open a blank DWG and run the RECOVER command. Select the problematic file. AutoCAD will attempt to recover the file and open it.
Also this type of question should've been asked over in the AutoCAD forum.  This is not an installation or licensing issue.
Mark Lancaster
