Registry cleaner software remove registry keys
This is the error when I try to start AutoCad
There is a problem with the installation and Autocad cannot continue.
This error may occur if the registry cleaner software has removed or altered registry keys that are required to run AutoCad
With is the case, I did reinstall Autocad but still the same error
DarrenP
did you go through this:  https://knowledge.autodesk.com/customer-service/download-install/remove-products/clean-uninstall?st=...
DarrenP
mdavis22569
@Anonymous
Were you able to get this resolved?
Mike Davis
