Recap Pro Fails to install
DavidDustin4627
DavidDustin4627
Users,
I have tried all day to install Recap Pro. It gets to about 20% then fails.
I have tried custom installs, running as an admin... I have tried everything I can think of but no joy.
The log file just says it failed to install the bundle.
Any help is appreciated.
David
klarinda.gunadi.widjanarko
Hi David,
May I know which ReCap version are you trying to use?
Can you try to download and install ReCap Pro 2022 from this page?
May I know if you are able to see the following screen?
Also may I know what is your system? Is it Windows 10?
Do you have other Autodesk products installed?
Can you send us screenshot of the failed installation and the log file?
Klarinda
Klarinda Gunadi Widjanarko
Senior Software Engineer
Try downloading from this link:
Recap Pro 2022
Switch off your antivirus and make sure you have Windows admin rights before attempting to install.
DavidDustin4627
Anti Virus can't be shut off (company policy).
I have windows admin rights (Windoze 10)
No other AutoDesk programs on this computer.
Yes I see the screen you showed.
Here is the failure screen.
As far as the log file..
Here is the content of the log file. It appears to contain the deployment information (I tried using the deployment too).
2021-06-16T15:14:26.170 [Deployment: 9136, single] [LM2L5CD9165YWG INFO] Deployment started...
2021-06-16T15:14:39.588 [Deployment: 9136, single] [LM2L5CD9165YWG INFO] Deployment started...
2021-06-16T15:14:53.266 [Deployment: 9136, single] [LM2L5CD9165YWG INFO] Installing: Autodesk Licensing Installer 1.0
2021-06-16T15:14:53.267 [Deployment: 9136, single] [LM2L5CD9165YWG INFO] Installing: Faro SDK
2021-06-16T15:14:53.268 [Deployment: 9136, single] [LM2L5CD9165YWG INFO] Installing: ODIS Installer
2021-06-16T15:14:53.269 [Deployment: 9136, single] [LM2L5CD9165YWG INFO] Installing: Universal C Runtime (KB2999226)
2021-06-16T15:15:36.792 [Deployment: 9136, single] [LM2L5CD9165YWG INFO] Installing: ReCap Photo
2021-06-16T15:15:37.989 [Deployment: 9136, single] [LM2L5CD9165YWG ERROR] {765FB3F3-2E89-3253-824D-0F72FD2C7A61} : 80
2021-06-16T15:15:37.989 [Deployment: 9136, single] [LM2L5CD9165YWG ERROR] Deployment failed!
2021-06-16T19:42:10.793 [Deployment: 9136, single] [LM2L5CD9165YWG INFO] Deployment exits
David
DavidDustin4627
Yes installing recap pro 2022.
Windows 10.
No other AD products installed.
[image: image.png]
David
Hi David,
I'm not expert in installation.
But from the log file, it seems that installing ReCap Photo gives error.
So can you try to uncheck "ReCap Photo"? Hopefully it succeed.
Otherwise, can you try to download and install using the link on my previous msg?
Klarinda
DavidDustin4627
Klarinda,
I have tried that too but no Joy.
David
