Here is something I encountered while creating my firm's Revit 2021 deployment image:
Creating a valid deployment is an iterative process which requires testing at each step. Repeated installation, uninstallation, and reinstallation is part of our process.
I have confirmed a behavior on three different Win 10 computers and one Win 7 computer. After uninstalling Revit 2021 and then reinstalling Revit 2021, the "C:\Program Files\Autodesk\Revit 2021\Samples" (and content) is missing.
The first time Revit 2021 is installed, "C:\Program Files\Autodesk\Revit 2021\Samples" (and content) is installed. This issue is new for the 2021 version. Repeated uninstalls/reinstalls of the previous 2020 version does not exhibit this behavior. Even signing in to Windows as a different Admin level user does not result in a 2021 Samples folder on a reinstall.
I am unable to locate which installation log file tracks the Sample folder installation so I am unable to track this issue. I starting looking through several of the (over) 40 log files but finally gave up.
I kept a copy of the Samples folder from one of the successful first-time installs so I have rigged up a work-around in my deployment using an "if exist" script to copy over my saved (successful) Samples folder when necessary. While this solution works for us, my preference is a valid (re)installation without the need to intervene.
Has anyone else encountered this issue? And, have you found the cause?
TIA
Michael Partenheimer
