First post, and one which is causing us some headaches.
We have 14 PC/Laptops across our office network, using a range of Revit LT Suite 2016 and BDSP 2016. We are trying to update and install the new 2017 versions, and coming across the error above, however we try to install the software.
We have the setup files saved to a network drive for easy access, however as soon as we run setup, we get the black box with "Another Autodesk Install/update is now occurring...." message. If we try and install through the Autodesk Desktop App, it begins to download, then the install fails with a 'Install error 1618' code.
Having browsed, I have also downloaded the parts from the Autodesk virtual agent, and that install fails for the same reasons also.
This happens with any Autodesk products we try to install, so not limited to Revit LT suite or BDSP.
On my PC I have tried uninstalling all versions of Microsoft Visual C++ instances, and that still produced the "Another autodesk install/update..." message.
I have also gone through the task manager and closed out any installers (wher possible) and autodesk services, and nothing will allow us past the "Another Autodesk install/update..." message. So far, we have this on 3 out of the 14 PC's/laptops we have tried, but its looking like a network wide issue, not specific machines.
We have our external IT company looking at it (they only really look after our server, have little knowledge of Autodesk products), and so far they are hitting a wall.
Just wondered if anyone could advise further on what could be telling the Autodesk installers that another install/update is happening, and/or if there is any way to by-pass it.
Thanks in advance for any advice.help offered.
Regards
MJ
