Proxy problem
Proxy problem
Message 1 of 18
Proxy problem
Hello!
I have a problem downloading files though Autodesk web site. They ask me "proxy autenticathions".
I don't have any proxy activated, I already unistalled my antivirus, I tried already every solution I read in the forum and online.
I'm desperate! please help
Replies (17)
Message 2 of 18
Alfred.NESWADBA
Please show a screenshot of that message, but I'm quite sure that this question is from your network and not from the one from Autodesk.
You might try another Internet-Browswer or try to download the software from >>>Autodesk Virtual Agent<<< and install then from the local file(s).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 18
natasha.l
Hello @Anonymous,
Welcome. As @Alfred.NESWADBA try using the Autodesk Virtual Agent. You should temporarily disable your firewall as well.
Windows Firewall Issues
Locate > Control Panel\All Control Panel Items\Windows Firewall\Customize Settings
Please keep us posted. Smiley Happy
Message 4 of 18
@Alfred.NESWADBA @natasha.l
Thanks guys! I did it through Autodesk Virtul Agent as you recommend. Thanks a lot!
But now I've one more problem. I complete the autocad installation correctly but in the moment I try to open it it block like thisImmagine.jpg
Message 5 of 18
natasha.l
Hello @Anonymous,
Sorry for the issue you are encountering at launch. This may be due to corrupt licensing, internet block, antivirus block, Internet Explorer LAN incorrect setting.
Try the following series of steps:
-Delete C:\ProgramData\FLEXnet
-Turn off Antivirus & Firewall and retry
-Enable detect settings
  1. Clear the browser cache
  2. Browse to Control Panel\All Control Panel Items\Internet Option
  3. In the Advanced tab > Reset button to reset Internet Explorer's settings to the defaults
  4. In the Security tab, select Reset All Zones to Default level
  5. In the Content tab, select Clear SSL state
  6. Select Apply
In the Control Panel >> Internet Options >> Connections tab >> LAN settings >>  Automatically detect settings enabled
If the following does not resolve the issue please provide a log. Download Link:  http://www.autodesk.com/aida  > Select "Create Zip File"
Thank you.
Message 6 of 18
@natasha.l
I did everything but still the same problem. Intalled AIDA but, i feel retard sorry, i don't know how to use it. can u help me please?
this is the current stituation
Message 7 of 18
Mark.Lancaster
@Anonymous
Based on the "red" section for the AIDA information.  It appears you don't have proper "rights" to your machine.  Are you sure you have Admin rights on your machine?
Mark Lancaster
Message 8 of 18
natasha.l
Hello @Anonymous,
Welcome! The information you provided is fine. Yes, it seems like a Windows User permissions issue, users must have Full Control permissions (Administrator) to all files and folders in the C:\Users\USERNAME%  directory and registry keys.
 Run through these steps:
 -Sign in as Administrator orCreate a New User Account(Full Control user)
-Reboot the machine
-Temporarily disable Antivirus
-Delete Temp items C:\Users\xxxxx\AppData\Local\Temp folder
- Re-install the software by Right Clicking on the part1.exe file downloaded and select “Run As   Administrator”.
(This will automatically extract both parts and begin the installation process)
Please keep us posted on the progress. Thank you. Smiley Happy
Message 9 of 18
natasha.l
Hello @Anonymous,
I wanted to check-in with you, I hope you were able to resolve the issue.
If so, please select a response that resolved the issue and click "Accept As Solution" button to help others in the community.
Thank you.
Message 10 of 18
yes yes i'm sure.. I've just one user in my pc and it is administrator
Message 11 of 18
I'm sorry for the delayed response. Wich one do I need to delete? cause I'ce planty of themImmagine.png
Message 12 of 18
Mark.Lancaster
Delete as many files and folders in your personal temp location.  That folder location should always be cleaned out every so often.  You will not be able to delete everything but try to clean out as much as possible.
Mark Lancaster
Message 13 of 18
natasha.l
Hello @albertoceccon,
I wanted to check-in with you, I hope you were able to resolve the issue. Did emptying the temp folder help?
Thank you.
Message 14 of 18
I didn't solve it. I'm gonna try the last one: format c: . I will let u know as soon as possible
Message 15 of 18
Alfred.NESWADBA
A proxy is by default not installed on a local workstation, so formatting your workstation probably is not the solution.
A proxy is a device in the network typically between your server and the internet connection (or maybe between your workstation and the internet connection.
- alfred-
Alfred NESWADBA
Message 16 of 18
Yes, the point is I didn't set any proxy and from a day to another Cad was gone. By the way I did format c: and now everything is working again
Message 17 of 18
natasha.l
Hello @Anonymous,
Glad you resolved the issue and that you are up and running. Smiley Happy
Thank you for posting.
Message 18 of 18
@natasha.l Thanks a lot for your help! Smiley Wink
